Technical => Drivetrain Tech => Topic started by: 86cougar on April 18, 2013, 10:05:45 PM
Title: Rear axle id
Post by: 86cougar on April 18, 2013, 10:05:45 PM
For the life of me I can't seem to find "jcassity's" list of information! I am trying to read the axle information tag and I cannot find the correct codes. I would appreciate it if someone could help me.
Tag reads: V4978
              3L45  75  5C18
Thanks!
Title: Rear axle id
Post by: Dan B. on April 18, 2013, 10:26:04 PM
Looks to me like you have a 7.5" rear w/ 3.45 gears.
Title: Rear axle id
Post by: Haystack on April 18, 2013, 10:28:10 PM
x2. must be a turbo bird/cat?
Title: Rear axle id
Post by: STANG8U on April 18, 2013, 11:11:07 PM
Yea the l stands for limited slip but don't recall a 3.45 gear you sure it's not a 5 .......3.55
Title: Rear axle id
Post by: 86cougar on April 19, 2013, 01:38:44 AM
Perfect! Yep, it's a limited slip with 3.45 gears from a turbo coupe. That's what I paid for. Thanks!
Title: Rear axle id
Post by: STANG8U on April 19, 2013, 02:51:59 AM
Did they make 3.45 gears ? I have done a few just did a 3.73 swap for a buddy 7.5
Just never herd of a 3.45
Title: Rear axle id
Post by: Dan B. on April 19, 2013, 07:15:39 AM
1st generation Rangers had lots of 7.5" rears w/ 3.45's in them......that's where I'm framiliar with them.  My fox cars have all had 8.8's.
Title: Rear axle id
Post by: 1BadBird on April 19, 2013, 09:56:14 AM
If my memory serves me right, (just don't ask the wife about that LOL) That's what I had in my 86 TC before the LSC swap.
Title: Rear axle id
Post by: 86cougar on April 19, 2013, 10:28:58 AM
Right now all I have in my possession is a set of factory Ford Mustang shorty's and this rear axle then I can start working on the interior. Being my car has an AOD transmission I doubt that I will have much wheel hop. I am seriously considering Aerocoupe's suggestion to buy a set of CHE control arms for this axle. I still need to find out who sells the horizontal shocks. Thanks!
Title: Rear axle id
Post by: Masejoer on April 19, 2013, 12:39:54 PM
Quote from: 86cougar;413534
I think local parts stores carry, or can bring in, the quad shocks. 4-5 years ago I picked up some from Autozone. I think they were Monroes or Gabriels.
Edit:
Gabriel 14039
http://www.autozone.com/autozone/parts/Gabriel-Steering-Damper/1988-Ford-Mustang/_/N-ihy8aZ8oxi5?itemIdentifier=8593_481907_20203_
http://www.amazon.com/Gabriel-14039-Steering-Damper/dp/B001AM5P48
Title: Rear axle id
Post by: 86cougar on April 19, 2013, 03:10:03 PM
Looks like they are easily available. I'm going outside to start getting this axle cleaned up for installation. I can't wait to see what a difference it will be from my stock 2.73 gear axle to this limited slip 3.45 gear quad shock axle will be like! Thanks!
Title: Rear axle id
Post by: STANG8U on April 19, 2013, 03:38:06 PM
I put a track lock and 3.73 in my buddy's 96 v6 auto mustang
He had stock 2.73 and the 3.73 woke the turd up ..... Still a turd though lol
I'm sure you will enjoy the difference don't forget your speedo will be off some
Title: Rear axle id
Post by: 86cougar on April 19, 2013, 07:17:05 PM
Quote from: STANG8U;413552
My poor car hasn't had a good cleaning in about a year when I started this project, cool thing is the engine compartment is cleaner than the rest of the car for a change. My new rebuilt "87" Mustang HO engine has about 200 miles on it now. I had the front end aligned along with rotation and balance today. I took off most of the garbage off the axle, so now it's about ready to clean up and paint. I'm trying to figure out which "CHE" package I should buy for this axle. I like having the option of being able to raise and lower the rear end. I bought the stiffest springs I could find (cargo on rear) so that I could cut 1/2 - 1 coil off to lower my car, then put 225/(50 or 55)/16 tires on it. An suggestions are appreciated!  Thanks!
Title: Rear axle id
Post by: TOM Renzo on April 20, 2013, 07:49:44 AM
Just a point!!!
Pull the cover count the teeth and devide. This will accomplish 5 things
1 The rear ratio
2 If it has POSI
3 Change the cruddy oil and gasket and flush out all the particles. There is always some
4 Measure the ring gear for size. Should be a 7.5 and 3.45 ratio by the tag
5 Check the unit for wear and back lash
A 10 dollar gasket is all that is needed with a couple QUARTS of 75-140
Win Win Situation and problem solved !!!
Title: Rear axle id
Post by: 86cougar on April 20, 2013, 10:01:38 AM
Quote from: TOM Renzo;413583
Just a point!!!
1 The rear ratio
2 If it has POSI
Tom,
        That's the fun part of cleaning, I get to open it up. I also take a can of brake cleaner and clean it out. I've noticed that the new gear oil is synthetic now and like you said 75-140w not just 90w.I did notice some oil dripping from the front of the pumpkin yesterday (where the u joint connects). Is there a seal there that will need to be replaced? Thanks for your help!
Title: Rear axle id
Post by: STANG8U on April 20, 2013, 01:23:13 PM
That's the pinion seal
Title: Rear axle id
Post by: BLKBRD88 on April 20, 2013, 03:45:20 PM
Quote from: STANG8U;413523
Early SVOs came with 3.45 ratio.
Ron
Title: Rear axle id
Post by: STANG8U on April 20, 2013, 03:47:10 PM
Learn somthing new every day lol
Title: Rear axle id
Post by: 86cougar on April 20, 2013, 05:46:31 PM
I had the axle upside down and laying forward on the ground, so that is probably why it leaked. Thanks!
Title: Rear axle id
Post by: TOM Renzo on April 20, 2013, 06:51:57 PM
Pinion seal needs to be replaced. But special procedures are required not to mess up the crush sleeve!!
No 7.5 came with 3.55 final drive ratio as far as i know!
Title: Rear axle id
Post by: TurboCoupe50 on April 20, 2013, 07:45:50 PM
Quote from: BLKBRD88;413601
Ron
Along with all '83 to '86 Turbo coupes and no doubt some 4cyl Stangs......
Title: Rear axle id
Post by: Haystack on April 20, 2013, 09:20:30 PM
every 4 banger stang I've seen was 3.73 locker.
7.5 ratio rear only has 3,45 gears. 8.8 has 3;55. has to do with tooth count on the rear.
Title: Rear axle id
Post by: 1BadBird on April 20, 2013, 09:46:34 PM
Quote from: Haystack;413621
every 4 banger stang I've seen was 3.73 locker. 7.5 ratio rear only has 3,45 gears.
The mustang 7.5s also had 3:08s
Title: Rear axle id
Post by: Haystack on April 20, 2013, 10:52:33 PM
should have specified...
the closest 3,55 ratio for a 7.5 is 3.45...
has almost  every other 8.8 ratio.
Title: Rear axle id
Post by: BLKBRD88 on April 21, 2013, 12:48:25 PM
Quote from: 1BadBird;413623
And 3.27s in some 5.0s
Title: Rear axle id
Post by: 86cougar on April 21, 2013, 08:04:21 PM
Quote from: Seek;413540
Edit:
Gabriel 14039
Autozone had the Gabriels listed at $24.99 w/3 month warranty, O'reilly auto parts had the Monroes for $27.99 w/lifetime warranty. I bought the Monroes. They also come with shock boots.
Title: Rear axle id
Post by: TOM Renzo on April 21, 2013, 10:06:16 PM
LOL every gear ratio has to do with TOOTH COUNT!!!!!!!!!!
:hick::mullet::toilet:
