So I have to check out my wiper washer sprayer motor. It's on a 88 tbird and im thinking it's behind the driver side tire?
its located in the bottom of the washer tank.
Thanks under the hood or behind the driver side tire?
It's in the bottom of the washer bottle, which is in the driver's wheel well. You'll have to pull the wheel AND the wheel well liner.
much much easier to take off the whole fender,, honestly it is. you will be staring at the washer bottle in 30min tops.
turn your wheel all the way to the left or right before you start so a stubby phillups can be used to remove the phillups screws on the fender skirt.
Raise up the body slightly to get to the fender skirt screws along the top middle section of the fender well.
remove two or three phillups screws along the forward part of the fender well.
remove 1 phillups screw directly underneath your driver door.
use a socket / wratchet for all the bolts.... it honestly takes very little time at all.
