Marketplace => T-Bird/Cougar Parts & Cars FOR SALE => Topic started by: TheFoeYouKnow on March 13, 2013, 09:36:31 AM
Title: Start of the Part-Out - 88 Thunderbird 5.0
Post by: TheFoeYouKnow on March 13, 2013, 09:36:31 AM
First item up was found in the trunk in original packaging and in 99% new condition.  This is a "Bra" for 87-88 T-Bird, it seems to have been installed at one point, but removed shortly after as the leather is clean, un-cracked, and has original folding creases in it. (if it had spent a great amount of time on the car, these would have flattened out) This is as close to NOS as it gets with one of these.  Google "E7SZ-19A413-A"; nobody has this.  I've got the original Ford Genuine Accessories Box that's slightly water-stained on the bottom as you'll see below, and both pieces of the cover, also below.
I'd like to start at $80, If I'm just batshiznit crazy at that price we'll talk about coming down a bit.
XX
Post by: TheFoeYouKnow on March 13, 2013, 09:37:36 AM
The Cover itself:
XX
Post by: STANG8U on March 13, 2013, 10:47:36 AM
Old school
Post by: TheFoeYouKnow on March 13, 2013, 11:11:43 AM
There's plenty of old school guys here.  Ain't no school like the old school.
Post by: thewestie on March 13, 2013, 11:26:20 PM
I'm tempted already a lot of chips in the nose. Would be nice on long highway trips like to carlisle this year
Post by: TheFoeYouKnow on March 13, 2013, 11:41:41 PM
Got 4 of these, too, with the key tool.  Really nice condition.  Only selling the whole set.  I'll get pics if anybody wants to see them.XXX
Post by: TheFoeYouKnow on March 18, 2013, 09:02:04 AM
Swapped the EATC, Cluster and dash harness Saturday, so I've got a base cluster  which indicates 71,000 miles (which I unlock modded) a radio (new display bulb), an AC control, a clean rearview with the auto dim sensor, I've got an autolamp module, assorted switches, and the entire heater/AC plenum box with all the parts (bad heater core).  I've got the dash harness and all that stuff also.  A few pics: (Update, the mirror is sold)
XXX
Post by: TheFoeYouKnow on March 18, 2013, 09:06:51 AM
XXX
Post by: TheFoeYouKnow on March 27, 2013, 06:32:37 PM
Bump
Post by: CougrrrFiveO on March 27, 2013, 08:13:32 PM
Your PM box is full. How much do you want for the mirror?
Post by: TheFoeYouKnow on March 27, 2013, 08:41:30 PM
Sorry, the mirror is just freshly gone.  I've got 3 standard mirrors sitting around, though.
Post by: TheFoeYouKnow on March 27, 2013, 08:45:51 PM
New items:  Radio and instrument cluster bezels,  inner and outer front lamp housings, and left and right tail light housings in "B" condition.  I've got 2 pocket housings (such as would take the place of the graphic EQ, and a pair of good door windows
Post by: TheFoeYouKnow on May 05, 2013, 06:08:17 PM
Bump, Tail light pics in this (http://"http://www.foxtbirdcougarforums.com/showthread.php?35754-87-88-Tail-light-housings&daysprune=365")thread
Post by: Dougy_Fresh on July 03, 2013, 02:14:15 AM
do you have an engine harness?
Post by: TheFoeYouKnow on July 03, 2013, 07:01:36 AM
Gone, sorry.
Post by: My10-80 on July 06, 2013, 06:43:11 PM
Still got the odometer cluster assembly?
Post by: TheFoeYouKnow on July 06, 2013, 06:56:56 PM
I do.  Speedo is speed modded (will display to 199), odo reads 187k or something.  I can tell you how to swap the odometer chip, but it takes some balls.
Post by: My10-80 on July 07, 2013, 06:17:04 AM
Do you know if I can take just the water gauge out of it?.  My Speedo is fine but my temp gauge doesn't work properly.
Post by: TheFoeYouKnow on July 07, 2013, 07:35:30 AM
You sure it's the gauge?
Post by: My10-80 on July 07, 2013, 02:35:12 PM
No, not for sure,  it appears to start to work as I run the engine, but only goes about 1/3 the way.  I tap on the plastic and it moves a little higher but just doesn't seem to get to the normal range.    If not the gauge any ideas.  Is there a way to test the gauge itself?  I suppose after all this time the thermostat could be out and its just not heating up properly.
Post by: vinnietbird on July 08, 2013, 09:50:33 AM
Do you have the front and rear side fendert trim? I need some nice pieces. All 4.
Post by: TheFoeYouKnow on July 08, 2013, 10:21:10 AM
Sorry, I don't. I tried to remove them for someone else and I destroyed them, so they went with the rest of the car to s.
Post by: TheFoeYouKnow on July 08, 2013, 10:27:40 AM
What I still have is the manual HVAC box, the moonroof frame and glass, the moonroof motor and overhead console, the visors, the c-pillar interior lamps and switch, the radio, the base digital cluster, the clock, the keyless entry module, right side inner and outer front park/turn lamp housings, the left inner front park/turn lamp housing, leather nose cover and wire wheel covers with tool, caps and mounts. Underlined for quick browsing, will add more to this post if I remember/find anything else.
