General => User Rides => Topic started by: canadiancarguy on February 27, 2013, 01:43:37 AM
Title: Not a fox, but it was cheap!
Post by: canadiancarguy on February 27, 2013, 01:43:37 AM
I picked up a slightly rusty 83 Chevy S10 lowrider truck for $1700 the other day. It has a carbed 305 with a TH350 trans. The thing is pretty tired, has blowby and other problems, the edelbrock carb being one of em. It came with a stock 400 small block from a truck that was running propane. I have a set of pro comps, mug thumpr cam, air gape intake, quickfuel manual secondary 750 carb, 1.6 rockers a nice rad with fans just sittin in the shop that I bought for another project I ended up selling. Any idea how the 400 will run with this stuff? I never had a small block chev before other than 305s that were just as doggy and tired and a soso 283 in a camaro. Got the interior gutted (leaking from the roof antenna, thought it was the windshield), and the suspension needs attention. Will post some pics tomorrow.
Post by: STANG8U on February 27, 2013, 01:45:04 AM
Pics
Post by: canadiancarguy on February 27, 2013, 08:44:14 PM
Can't take pics yet! Forgot the girlfriend took my camera!! Just cause its pink she thinks its hers:)
Post by: STANG8U on February 27, 2013, 08:58:55 PM
Rofl
Post by: Haystack on February 27, 2013, 09:03:36 PM
If its pink, i'd assume it was for her too ;).
We had several propane powered trucks at my last work. They ended up bypassing them all or just running them on gas instead. There's a bit less power and sometimes they have to start off of gas and switch over after a coupleseconds.
In utah, propane for cars is regulated at $1.27 a gallon, so I would jump on it if you had the complete setup.
Post by: canadiancarguy on April 09, 2013, 11:38:05 AM
XX
Here are a couple pix of the floor
Title: Pulling the cab and box off the chassis
Post by: canadiancarguy on April 09, 2013, 11:39:57 AM
XXX
Title: The body
Post by: canadiancarguy on April 09, 2013, 11:42:52 AM
Here are a couple shots of the cab and box being worked on. After looking everywhere online for cab mount cups I went to the local gm dealer and they had em in stock go figure....
XX
Post by: canadiancarguy on April 09, 2013, 11:50:16 AM
Here is the chassis getting fixed up. I like to use rubberized rock guard paint mixed with gloss black acrylic enamel paint to add gloss. I prefer spraying rock guard over rubberized undercoating. I will be using a gloss black polyurethane enamel (Cordoba Rust Scat) paint for under the cab and engine bay. Anyone use a hardener or catalyst with polyurethane paint?? If so what kind, I have some acrylic enamel hardener but not sure if that works with polyurethane.
XXX
Post by: canadiancarguy on April 09, 2013, 11:52:59 AM
The body mounts were rough so I got some steel washers and welded em on to level the cab with the box.
XX
Post by: STANG8U on April 09, 2013, 12:21:23 PM
Sweet
Post by: Big B on April 09, 2013, 09:52:46 PM
Cool Truck! Those floorpans look decent.
I rarely ever see any northern vehicles around which are older than 10-15yrs and are not rusted out POS's. Nice Score there!
Post by: canadiancarguy on April 09, 2013, 11:17:29 PM
I can't wait to see how it will look with a rino lined floor.
Post by: turbotrav on April 10, 2013, 09:21:32 AM
LSX swap????
Post by: canadiancarguy on April 10, 2013, 05:58:50 PM
No, just a 400 small block. I can't afford nice stuff like that:) I am kinda into old carbed v8s right now, getting sick of the turbos.....
