Technical => Engine Tech => Topic started by: al green on February 18, 2013, 08:06:24 PM
Title: I think I have a senor problen
Post by: al green on February 18, 2013, 08:06:24 PM
I have a 5.0 in a 88 Crown Vic.  The car run good after it warm. However when I first start it up, I must keep giving it gas for about 4 minutes. Unless I pull off right after starting. Need a little help.
Post by: daminc on February 18, 2013, 10:14:15 PM
run your codes. it'll tell you whats going on
Post by: Haystack on February 19, 2013, 02:29:03 PM
If you want, I'll even do a youtube showing how to do codes on my 88 wagon. It takes 5 minutes.
Post by: al green on February 20, 2013, 08:26:27 PM
They say you can learn something new everyday. I did not know we had a code reader. Could tell me where its located at. An what kind of code reader to get
Post by: al green on February 20, 2013, 08:29:01 PM
That would be great. I will be waiting.
Post by: TOM Renzo on February 20, 2013, 08:46:31 PM
Al Jump the ALDL connector and read the SES light BLINKS. Those are the service codes. Al all you need is a PAPER CLIP OR A JUMPER.
Post by: TOM Renzo on February 20, 2013, 08:48:45 PM
Post a little more info. Does the engine idle increase when COLD YES/NO? Or does it bog down or run rich when cold. Check the exhaust for black smoke. Just a couple of fast tips!!
Post by: Haystack on February 20, 2013, 10:11:59 PM
I got a pm fromMr. Green. I'll post a video for him tomorrow. Mainly because the test port is in a different location on the panther chassi. Maybe do a quick write up and do one for the bird too. We get way to many questions about codes.
Post by: Haystack on February 20, 2013, 10:15:12 PM
http://sbftech.com/index.php/topic,2471.0.html
Here is a writeup on how to run them. The test port is located on the drivers side fram rail, near the headlight harness if I remember correctly.
Post by: Haystack on February 24, 2013, 08:44:09 PM
Breif key on engine running test.
I show the volt meter, and read out the codes. 94 and 44 repeated. This is all smog related, traced down to a bad vac line.
https://www.youtube.com/watch?v=9QSiS6wf7oU&feature=youtube_gdata_player
Working on uploading the koeo test where I show better how the volt meter is hooked up. I accidently had it backwards, but it still functions fine. You can also use a test light or any 12v light bulb, or if your check engine light works, sit in the car to run the test. Just connect the paper clip as shown.
I can't get the crown vic video to load for some reason,but the test is ran the exact same way.
Sorry for the delay.
Post by: Haystack on February 24, 2013, 09:15:15 PM
Sorry it took so long to get around to it.
https://www.youtube.com/watch?v=z0ehA8cFTkc&feature=youtube_gdata_player
http://oldfuelinjection.com/?p=13
Link above shows codes and what they mean, as well as a write up of how to run them.
I got a double 11 meaning system pass from the k(ey)o(n)e(ngine)o(ff), and then a continuous memory (stored code) of 12, meaning the rpm's were too high to run a self test. First time I ran the codes, I accidently had my foot on the gas pedal so the computer couldn't lower the rpm's when the test was ran. This was user error.
