Technical => Engine Tech => Topic started by: CougarSE on June 16, 2005, 02:31:07 AM
Title: intake screws in pretty plate
Post by: CougarSE on June 16, 2005, 02:31:07 AM
Anyone have any tricks on getting those  screws out of the cover on the intake manifold?  Those  four torx screws wont come out.  I just twist bits off trying to get them out.
Title: Re: intake screws in pretty plate
Post by: cougarman on June 16, 2005, 07:43:04 AM
Try putting the bit in the bolt and then hit it sharply with a hammer, they have thread lock on them. Usually works if you hammer them one time first, then try turning them. :D
Post by: Bob on June 16, 2005, 08:08:32 AM
HAHAHHA you beat me to it... same technique ;)
Post by: CougarSE on June 16, 2005, 05:02:35 PM
Actually I beat you both.  I've tried that and only one has come out.  Three are still stuck.
Post by: 4thqtr on June 16, 2005, 05:21:43 PM
Had the same problem with my Cougar, finally just drilled them out and left the plate off. I thought to myself, "Who needs to look good when you have so many other problems?"  :giggle:
Post by: V8Demon on June 16, 2005, 07:04:05 PM
Here's a trick.  Try to see if they'll tighten.... Sometimes they're froze into place and if you tighten 'em just a hair you can back 'em out afterwards
Post by: black ct on June 16, 2005, 08:56:52 PM
Here's what always works for me with stuck screws.  Using a dremel with a thin cutoff bit cut a slot in the top of each screw, then use a flat screwdriver on them.  The little bit of heat from cutting helps loosen them too.  I just used this trick on my ignition switch inside the steering column since Ford uses those stupid torx screws with the pin in the centre that requires a hollow torx bit.
 :canada:
Post by: CougarSE on June 16, 2005, 10:55:55 PM
Well I just drilled them out.  They were stuck good.
Post by: srv1 on June 16, 2005, 11:38:34 PM
Use a propane torch and they will come right out.
James
Post by: brizer on July 03, 2005, 09:49:02 AM
actuallly, all you need is a screw extractor kit.. Drill to bottom of screw head but not to far or your screwed too. Then take the extractor take a hammer hit it real hard down into the screw and use anything  you got to turn it. its simple and you dont have to go and drill them out. if you have to you can put it back on, its alittle thing called self tappin screws.
Post by: Haystack on July 03, 2005, 11:07:12 AM
yeah if I ever get around to getting the screws out of mine, I will put in some kind of no stick stuff. Why do you need the intake cover to have thred lock?
