Technical => Misc Tech => Topic started by: TOM Renzo on February 03, 2013, 04:24:00 PM
Title: New parts must be inspected
Post by: TOM Renzo on February 03, 2013, 04:24:00 PM
Well by now you guys know i have lost my mind. So here goes. My Chevelle is being wormed over with a new Stainless gas tank and hardware. So i gathered all the parts needed to complete the fuel storage mechanisms. So with that because i always totally inspect every part with a fine tooth comb once again i found something. I never run any of my toys in the winter. Salt is a killer. So i found out that the new fuels even when stabled have a nasty habit of getting stale. So with that i normally do not run a sock in the tank with a carbed engine. YES my Chevelle is carbed. With that i use a frame mounted pump with a 100 MICRON before pump filter. So i do not have to remove the tank in case of a fuel issue. But as usual i inspect everything very closely. And what do you know. This massively expensive SS sender had an issue. Metal Flashing or burrs just waiting to get stuck in my fuel system. Here is a photo of the issue.
(http://i740.photobucket.com/albums/xx46/proguns/004_zpsd8883c28.jpg)
Notice the flashing after removing the sock. I am not thrilled about this one BIT!!!
(http://i740.photobucket.com/albums/xx46/proguns/002_zps06ff1ea8.jpg)
(http://i740.photobucket.com/albums/xx46/proguns/003_zps4c19fa19.jpg)
And here again on the outlet
This totally pissed me off but typical of the parts today. THOUGHTS???
Post by: Beau on February 03, 2013, 04:37:08 PM
Made in the USA?
Post by: TOM Renzo on February 03, 2013, 05:04:17 PM
Actually i do not KNOW??? But will check that out
Post by: 87 T-BIRD on February 03, 2013, 05:21:33 PM
Wow! That would make me mad also, seems like these days the prices are going up and the quality is going down........
Post by: TheFoeYouKnow on February 03, 2013, 06:44:19 PM
Seems like something they cut with a chop saw.  Maybe a band saw, but a band saw burrs a tube evenly, and this is burred more in 1 area.  Seems that this is a part that should be cut with a tube cutter or even better, a cold saw.
Post by: TOM Renzo on February 03, 2013, 07:37:45 PM
I agree and i am going to do the ends over naturally not leaving any BURRS.
Post by: TOM Renzo on February 03, 2013, 07:39:21 PM
Quote from: 87 T-BIRD;408742
Totally correct. This part was plenty expensive over a NSS unit. I chose it because it was 304 SS according to the maker. I am not so certain it is. Got took i think. Well live and learn.
Post by: SLEEPER T-BIRD 87 on February 03, 2013, 08:04:09 PM
welcome to repop part junk
my lower 57 fender doesnt even match the wheel arch and its made in the USA!
Post by: jcassity on February 04, 2013, 02:10:47 AM
That looks an awful lot like to chrome is  flaking around where they flared the Tube And it's just waiting to flake off
 My thoughts?
s
Post by: jcassity on February 04, 2013, 02:13:37 AM
Might as  will check that variable resistor as well because you know it's going to be a piece of shiznit to
Post by: 86cougar on February 05, 2013, 03:00:36 PM
So, even if you have a pile of money to spend on a quality part, it's hard to find ANYONE who takes pride in their work any more. That's where I believe forums like this are important. So, IF and WHEN you do find a good vendor, let all of us know. A part like this one might save you a few bucks at first, but if you get enough shavings in your engine, it will likely cost you in the future.
Post by: TOM Renzo on February 06, 2013, 05:41:07 AM
Actually 86 the part was not CHEAP as the matter of fact it was quite expensive. But as usual the maker says it is the best thing since they stopped making the VEGA. With that like i always say aftermarket stuff is . Not all but most and i got SNOOKERED. Thanks
Post by: 86cougar on February 06, 2013, 09:45:09 AM
Tom,
        I'm sure you do buy the best that's out there. That's my point, even when you are willing to pay top dollar the choices that are available you either buy NOS (if you can find it) or some mass produced part. The part you bought seems to be well made, but it appears the problem was with Quality Inspection. Looks like somebody was taking a nap. You are absolutely right in pointing out the fact that we all need to do our own inspection. That was a good catch!
