Technical => Body/Appearance/Interior => Topic started by: STANG8U on January 22, 2013, 11:05:02 PM
Title: Hood spring problem
Post by: STANG8U on January 22, 2013, 11:05:02 PM
Idk if anyone else has had this problem but when I got my 88 TC the back of the pasanger side of the hood would not close all the way down I knew it was the spring also the hood would not open up very far and makes working on the motor a pita
So I picked up a prop off a fox mustang today disconnected the springs bolted the prop on and it fixes every thing hood closes right and opens up a lot further
The prop is a bolt on peice one 8mm bolt and the core already has a threaded hole and the hood actually has a prop hole also
Just a FYI for anyone having this problem
(http://i1131.photobucket.com/albums/m550/pooppoop13/88653B9B-46C8-492A-9BAA-D72A0B1925AD-3395-0000027BBBF772FB.jpg)
Post by: mcb82gt on January 23, 2013, 10:46:34 AM
Thanks for the tip.  My hood hinge does that too.
Post by: STANG8U on January 23, 2013, 10:49:35 AM
Yeah it drove me nuts lol
Post by: mcb82gt on January 25, 2013, 10:15:22 AM
I looked at the hinges, what did you do to modify them?
Post by: STANG8U on January 25, 2013, 10:34:26 AM
There is a part of the hinge held on with a clip take the clip off and slide it off it takes the weight of the hood off the springs
Post by: STANG8U on January 25, 2013, 02:50:59 PM
I just left them disconected for now they do not get in the way but I might cut them off down the road
(http://i1131.photobucket.com/albums/m550/pooppoop13/A12C3390-1AC5-43A8-A216-607CD00131FF-571-000000673021EC96.jpg)
Post by: mcb82gt on January 26, 2013, 08:34:40 AM
Mine are all greasy and funky dirty.  Thank you for the pics.
Post by: jcassity on January 26, 2013, 11:16:20 AM
there is an adjuster to the rear of the hinge that changes the elevation of the hood.
also, stuff in between the coils will occupy space when the spring coils up as you open the hood, preventing it from fully opening.
your going to hate the hood prop over time.
Post by: Loaded87IROC on January 26, 2013, 11:40:54 AM
My car came with the prop rod mod from the factory.  I think all 83-86 cars did in case anybody needs to find a prop rod.
Post by: mcb82gt on January 26, 2013, 01:02:00 PM
Quote from: jcassity;408046
Tell me more of this adjuster, please.
Post by: STANG8U on January 26, 2013, 04:09:36 PM
The udjuster did not work and the springs are week and only held the hood open to halve of what it is with the prop
I'm friggin happy with it lol
Post by: thunderjet302 on January 26, 2013, 06:03:08 PM
Do you mean the two mounting bolts on the hinge or the rubber "bolt" of the back on the hinge that the hood sits on when closed?
Post by: TOM Renzo on January 26, 2013, 09:24:42 PM
DAD always told me never buy a car with 4 LUGS a non self supported hood or a Turbo. The Midnighter has 2 good quality according to DAD. The hood is self supporting and it is 5 lug. Just saying!!
Hood sticks are YUCKIE. They are always in the way. Just me
Fixing those hinges is no big deal. And there is an adjustment screw. Getting the hinges to work properly is no big deal. But whatever turns you on. Hood holding devices are about 400 Billion on the list of things that i think about. If it dont make HP i spend no time thinking about it!!  Just Me.
 :flame:
Post by: STANG8U on January 26, 2013, 09:58:32 PM
Well to swap hinges you have to remove the fenders and that's a job avoided buy just using a prop
I'm happy having my hood open all the way lol
Post by: jcassity on January 26, 2013, 10:47:35 PM
Quote from: thunderjet302;408079
i think the answer is yes , to your quote but my pic points to the adjuster
Post by: EricCoolCats on January 26, 2013, 11:02:48 PM
Quote from: STANG8U;408092
Ummmm...no.
Post by: STANG8U on January 27, 2013, 12:03:27 AM
Is there a trick ?
I tried to remove a set and they were hung up in the fender like there was a bolt inside the fender area
Post by: jcassity on January 27, 2013, 01:28:26 AM
i cant speak to it, i cant remember, i recall there being an underhanded sneaky clippidy do thingy that is made on the hinge and it hooks into a slot then  you add bolts.
i do know the hinges come off without fender work though, ive only had them off once ever and that was in like 2003.
Post by: Kitz Kat on January 27, 2013, 06:36:39 AM
They come off without moving the fender,there's 3 bolts, one is hidden by a rubber trim piece.
Post by: TOM Renzo on January 27, 2013, 01:25:30 PM
No need to remove the fender. Thanks for the support guys. SUPPORT??? THAT IS THE ISSUE AT HAND!!! Just kidding the rod mod is a good one cheap and dirty and if it works for you that's great, Good idea. BUT the broom stick from the wicked witch will also suffice for hood PROPPING. Just me i am nuts anyway!!!
Post by: STANG8U on January 27, 2013, 02:19:03 PM
It's a ez fix and it bolts right to the car who can go wrong with that lol
I did not chop anything up and I can put springs on later down the road
But there has to be a trick to remove those hinges I took all the bolts out and there was a part of the hinge stuck in the fender
Post by: thunderjet302 on January 27, 2013, 04:02:13 PM
Quote from: jcassity;408096
Yep that's what I was talking about.
