Technical => Engine Tech => Topic started by: STANG8U on January 06, 2013, 02:00:59 AM
Title: What is this?
Post by: STANG8U on January 06, 2013, 02:00:59 AM
New to 2.3 turbos what is this ?
(http://i1131.photobucket.com/albums/m550/pooppoop13/783FAFDD-3680-40F4-9303-E46236A098CF-6843-000005EA62F59B32.jpg)
Post by: SR71blackbird on January 06, 2013, 03:40:16 AM
That is what controls the boost. You need to connect vacuum hoses from the turbo and wastegate up to it.
Post by: Beau on January 06, 2013, 11:38:30 AM
Unless you've done so already, go aftermarket.
Post by: STANG8U on January 06, 2013, 01:10:10 PM
Yea the car has a boost controller
Cool thanks guys
Post by: Shannun on January 07, 2013, 01:08:14 AM
IF im not wrong... thats also the annoying little thing that sets off the overboost buzzer if you turn up the boost
Post by: STANG8U on January 07, 2013, 01:29:47 AM
Also my stock boost gauge dose not work dose it have something to do with that if not where is that sender
Post by: SR71blackbird on January 07, 2013, 01:40:01 AM
well check your vacuum hoses. It should come off your intercooler. Its black with orange stripes. It runs along the firewall and under the vacuum tree. See if that is hooked up still.
