Technical => Suspension/Steering => Topic started by: ISTLCRUZ on December 15, 2012, 08:10:43 PM
Title: Tire size(s)
Post by: ISTLCRUZ on December 15, 2012, 08:10:43 PM
I got a set of wheels from a Mustang guy and need to know what size tire i should go with? They are staggerd 17x8 & 17x9. What are some of you guys running? They will be going on my 87 LX  Bird.
Title: Tire size(s)
Post by: TheFoeYouKnow on December 15, 2012, 09:12:41 PM
The most direct +3 is 245/45R17 this will be virtually the same circumference as your originals, there should be no speedometer accuracy issues.
Title: Tire size(s)
Post by: ISTLCRUZ on December 16, 2012, 07:45:02 AM
Foe, Can i run that size front and rear? The rear will be 9 inch wide, wasnt sure if that would be an issue? Runninig same size will help the wallet tho!  :)
Title: Tire size(s)
Post by: TheFoeYouKnow on December 16, 2012, 08:09:49 AM
You can, and you should, but while that will fit nice on the 17x8's, it might look a little funky on the 17x9's.
