Technical => Electrical Tech => Topic started by: KnightHawk on November 02, 2012, 06:55:22 PM
Title: Chime box
Post by: KnightHawk on November 02, 2012, 06:55:22 PM
Where is the chime box located that chimes when the door is open with the key in, or the headlights are on.. I can barely hear mine, it's very faint.
Thanks
Title: Chime box
Post by: EricCoolCats on November 02, 2012, 07:31:42 PM
It's probably dying or dead. Common problem as these cars get older.
On your car, the chime module is under the dash, driver's side, above the fuse panel. You may need to drop the under dash insulation panel, and the panel under the column, to even see it. Should be either light blue in color, or a black box with a light blue section. I believe there's only one harness going to it. (The box with two harnesses will be the wiper motor governor).
Title: Chime box
Post by: KnightHawk on November 02, 2012, 09:08:17 PM
Cool, thanks
Title: Chime box
Post by: Masejoer on November 02, 2012, 10:27:12 PM
Quote from: EricCoolCats;401824
I like our chimes :(
Title: Chime box
Post by: jcassity on November 03, 2012, 02:04:45 AM
Scoot your seat all the way back on the driver side
Lay on your back and have a flashlight and shine almost like up above your Fuse box
Way the heck up in there on top of a metal bracket resides your chime box
It's really not all that bad to get out to take some patients, have fun open it up and figure out what's not beeping right
I've had mine out before and they are fairly simple boxes easy enough to work on so just troubleshoot find the speaker see if there's corrosion what happened
Title: Chime box
Post by: dragon574444 on November 03, 2012, 08:09:24 PM
Not to hijack (I seem to be doing this a lot lately), but where would the box be located in my 84?
