Can any one tell me how the balanced weight on the flex plate is supposed to be clocked? I noticed that their are three "slots" inline with the weight and I know that there must be proper way to install the darned thing, but before I wasted time on researching the subject, I thought I'd ask you guys.
Thanks!
If you mean how to install the flexplate, the holes only line up one way. :)
Um..ok. So are you saying that the 6 holes, that would appear to be equidistant are not, and thus the flex plate can only be bolted to the crank one way?
Try it and see. The flexplate/flywheel will only bolt on one way, and I recommend red loctite with 60 ft-lbs torque.
Ok, thanks. I have spent my vacation yanking and replacing Dad's Exploder motor, so I didn't want to have to do it twice.
