I went this morning to pick up my car from the park and I fired it up and a guy came running toward me telling me to shut it off. here is what I found....
(http://i71.photobucket.com/albums/i143/88turbocoupe/2012-09-23_12-26-40_792_zpsab244791.jpg)
(http://i71.photobucket.com/albums/i143/88turbocoupe/2012-09-23_19-17-10_758_zps2ed45cc0.jpg)
Holy S@#T!! Hadn't ever seen one do that!
me either!! of all places why the car show?!?!?! lol
How dirty is your oil?
Hmmm...I've not seen that since I blew out a few of those myself. But in my case, I had either a faulty or the wrong type of oil pump. Upon a cold startup, the first semi-mashing of the gas pedal resulted in this same situation. Changed the pump, never had a problem again.
Based upon that, I would guess the issue might lie in the crankcase somewhere...oil pump, pickup clogged, etc.
Something seems to be building up pressure and finding the weakest point to release--in this case, the filter.
Hope you were using at least a synthetic blend...
this engine in my opinion is about worn out. I plan to build another over the winter/spring and get the car together again. As far as the oil, I have been having a problem with pressure at operating temp. I have been using a 15-40 oil and I dont know if this would of caused this to happen or not but at this point with this engine I really dont care.
i have never, ever seen a fl-1a have a failure like that. i believe there is another issue. i could totally understand if that was a fram. but not a motorcraft/purolater.
use the motorcraft fl-1-hp filter. it has much highr burst pressure.
Well the thing is, this was on a cold start up. Otherwise.... the car has normal oil pressure
IIRC, it takes 200-300PSI over normal to unroll the seam on an oil filter. (Useless knowledge from my auto parts days...lol)
