General => Lounge => Topic started by: vinnietbird on September 22, 2012, 04:40:40 PM
Title: How much is it worth?
Post by: vinnietbird on September 22, 2012, 04:40:40 PM
How much is a good T-5 and bell housing assembly worth from a '94/'95 Mustang GT?
Post by: jangus on September 22, 2012, 09:39:14 PM
Well, the bellhousing is longer, as is the input shaft on the trans. Trans is nothing special, so the going rate should be whatever a fox T5 goes for in your area. If you wan't to use it in a fox, you'll need to swap the input shaft, and the bellhousing is useless. However, if you want to move your shifter location back a bit further, they'll work fine.
Post by: jcassity on September 23, 2012, 12:45:13 AM
Id pay 5 bills
Post by: vinnietbird on September 23, 2012, 09:12:49 AM
I was told that you don't have to change the shaft if you use the SN-95 bell housing. And the distance it moves back is negligible.
Post by: mcb82gt on September 23, 2012, 10:32:14 AM
T5...... hhhmmmmmm.....
Post by: vinnietbird on September 23, 2012, 10:37:27 AM
Yep. T-5. I'm thinking about grabbing it and selling it for a small profit. Not a lot, just enough to make it worth my time.
