Technical => Engine Tech => Topic started by: ramair351 on September 02, 2012, 12:00:29 PM
Title: boost valve question
Post by: ramair351 on September 02, 2012, 12:00:29 PM
i have one of those cheapie ebay boost controller valves on my  88TC,  which is basically a controlled vacuum leak.  since putting this on my cruise control surges, does this make sense that is the cause?    would the Gillis valve be better and not cause this?
Post by: bryan163 on September 02, 2012, 02:03:09 PM
I have an ebay one on my car too, but no problems. Maybe you are stealing to much vacuum from the cruise control actuator. I have mine on a dedicated barb directly off the intake and I have it piped so there's no vacuum leak because I'm using a external 2 port waste-gate. I think if you give yours its own direct line to the intake manifold it will solve your problem though.
