Technical => Engine Tech => Topic started by: Fordracer08 on September 01, 2012, 01:15:28 PM
Title: What cam to use with MAF EFI
Post by: Fordracer08 on September 01, 2012, 01:15:28 PM
If you were going to use a MAF EFI system on a 289/302 with a flat tappet cam what would be a good choice for a cam? This would be a daily driver that I expect good mileage out of and 5.0 HO type performance. Any suggestions appreciated.
Post by: TOM Renzo on September 01, 2012, 02:52:03 PM
YES better stay MILD. Another words 500+ L mild duration 220-230. And wide LS Like 112*
Post by: Fordracer08 on September 01, 2012, 10:51:22 PM
Definitely mild, something that is compatible with the factory tune in the MAF ECM. The car will have a C4 trans with stock converter/stall and stock 2.75 gearing in the rear. I have wondered how a stock (early) 351W cam would work.
