Marketplace => T-Bird/Cougar Parts & Cars WANTED => Topic started by: 85bird on July 25, 2012, 01:42:50 PM
Title: EDIT: FOUND ONE 83-86 tbird Coin Tray - smooth finish
Post by: 85bird on July 25, 2012, 01:42:50 PM
I was wondering if anybody had a coin tray with a non textured.. or Smooth finish?  My center console button area is smooth, and I currently have a textured coin tray.
Thanks!
Kyle
Post by: 88turbo on July 25, 2012, 02:54:57 PM
There's one at the local yard, I will see how much on Friday
Post by: 85bird on July 26, 2012, 12:31:51 PM
Awesome! thanks.  I appreciate it.
Post by: 88turbo on July 27, 2012, 12:37:58 PM
looks like I can do it for $20 shipped.
Post by: 85bird on July 27, 2012, 03:26:39 PM
[COLOR="darkred"][/COLOR]Deal...and
THANKS 1,000,000 !
Post by: 88turbo on July 27, 2012, 04:07:30 PM
anything I can do to help ;)
Post by: 85bird on August 07, 2012, 11:32:57 AM
(http://thumbs4.ebaystatic.com/m/mOo2jgixwTCUUOuqiaqxckQ/140.jpg)
Hey 88 turbo... I cannot reply to your PMs becasue your have exceeded your message limit. That is the wrong piece.  I am looking for the one that goes at the bottom... under my ash tray and switches... under the stereo.  See above picture for the part that I need.
Sorry for the mis communication....
Post by: 88turbo on August 07, 2012, 03:21:29 PM
I have no leads on one of those.......
Post by: 85bird on August 07, 2012, 04:33:07 PM
crud
Post by: Crazy88 on August 07, 2012, 04:57:20 PM
When you say smooth, do you mean to say that someone refinished it by sanding and then painting it, since I believe that it is made from cast aluminum?  If so, you might consider masking your coin tray (the inner recessed coin part) and using 400-800 grit wet/dry sand paper, wet sand the "grain" surround to be smooth.  I believe that piece is molded dark gray plastic and if you take your time, the results would be acceptable.
Post by: 85bird on August 08, 2012, 11:34:24 AM
I am looking for a coint/tray molded plastic piece that has a smooth finish like the center console piece that houses my window and mirror switches.  My switch console has a smooth finish  and not a bumpy/textured finish like the picture below.  I just figured  this was a common issue.
I DO have a switch console that IS molded like my tray... but it has the round mirrow adjustment switch and not the Square switch like my current smooth one has.  So I figured that there has to be a console tray that has the smooth finish.  Perhaps I'm wrong??
(http://i.ebayimg.com/t/1983-Thunderbird-Console-Coin-Tray-Panel-/00/s/MTA2NlgxNjAw/$(KGrHqV,!h8E-v!oN52bBP9JT4W4Mw~~60_57.JPG)
Notice the texture on this tray... it is bumpy... not smooth.  I am looking for one that is smooth.... If it is not possible, then does anybody have a bumpy one that I can sand down to smooth?
Post by: BCA on August 08, 2012, 05:56:42 PM
Kyle,
I believe the textured ones were used on '83 an possibly '84 models (not positive about '84 but Eric may know). '85 and newer had the smoother finish.
Brent
Post by: 85bird on August 10, 2012, 02:02:45 PM
good info.... thanks!
Post by: Loaded87IROC on August 10, 2012, 08:43:13 PM
I think I have one of the smoother ones you are looking for.  I will check for you when I get back home on Sunday.
Post by: 85bird on August 11, 2012, 03:47:14 PM
Sounds like a winner, thanks!
Post by: Kitz Kat on August 11, 2012, 05:52:41 PM
I'm pretty sure I have one to, I'll check shortly let you know.
Post by: Loaded87IROC on August 12, 2012, 04:07:38 PM
I do have one.  If you are ever in the area and feel like picking it up you can have it for free.
Post by: MY83T on August 12, 2012, 08:08:53 PM
my 83 has the textured tray, and i had a 84 that also had the textured......
Post by: Kitz Kat on August 13, 2012, 03:34:03 AM
I can't find the one I have.
Post by: 85bird on August 14, 2012, 01:41:26 PM
Deal!
