Technical => Engine Tech => Topic started by: Artsydude on May 29, 2012, 11:18:40 AM
Title: Need camshaft for 1985 2.3 XR7 Turbocoupe
Post by: Artsydude on May 29, 2012, 11:18:40 AM
Hi Group..I'm in dire need of a camshaft and followers for a turbocoupe; my mechanic says none are available.  I'm assuming he means through normal outlets, but what about aftermarket or high performance suppliers? Any help...etc.
Post by: 88turbo on May 29, 2012, 11:54:41 AM
All situation parts stores will have the Cam and followers. Most of us Turbocoupe guys have gone to the 94ish ranger roller Cam.  The Cam is about $85 and the followers about $12 each if you buy new.
Post by: Artsydude on May 31, 2012, 12:32:37 PM
Do you have a part number or anything I can get for my mechanic? I can change oil and plugs, etc...but I let the heavy stuff for the experts. Thanks for your help.
Post by: TOM Renzo on May 31, 2012, 09:23:01 PM
Their are hundreds of cams for the stock 2.3 FORD. I use custom grinds from schneider . BO makes 5 or 6 . And just about every cam grinder on the planet makes at least one or two. If this mechanic cant find a cam for a 2.3 and tells you they are not available run like hell from him. He is totally not familiar with this engine. Pick any cam you want as long as it is a roller. Personally i would not use anything smaller than 460LIFT 220 duration and lobe separation at 110-112*  with a stock head.
And normally i run cams in the 530-550 lift area for my street 2.3 the MIDNIGHTER. :hick::burnout:
Post by: 88turbo on May 31, 2012, 10:52:57 PM
I agree 100% with Tom, don't trust him.  A Cam swap is easy and pretty straight forward.
Post by: Artsydude on June 07, 2012, 12:36:06 PM
Thanks guys; I got one through Auto Zone [Melling part #CL-SYB-37A] for $160 complete with followers and lifters. Should be done in a day or two, according to the garages schedule.
Post by: 88turbo on June 07, 2012, 08:34:21 PM
Welcome, did you get the roller Cam?
