General => User Rides => Topic started by: bodyman on May 12, 2012, 09:05:14 PM
Title: My 85 TBird
Post by: bodyman on May 12, 2012, 09:05:14 PM
This was my 85 turbo coupe  and my friends 84 Cougar XR7 about 15 years ago. The bird had a 289 and C4, the cougar had a 351 and a C6. Tore the bird down 12 years ago with the intention of redoing it with fuel injection and overdrive trans. Decided it was time to get started.
(http://i1060.photobucket.com/albums/t456/bodymann/tbirdandcougar.jpg)
What it looked like when it was pushed into the shop in Feb.
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00098.jpg)
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00100.jpg)
My fuel injection and overdrive, 2003 SVT cobra 4.6 and T56
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00101.jpg)
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00129.jpg)
Title: My 85 TBird
Post by: V8Demon on May 12, 2012, 09:10:15 PM
I do believe this thread will ve watched by many.  Very nice!
Title: My 85 TBird
Post by: bodyman on May 12, 2012, 09:20:53 PM
Thank you, I will be posting more pics soon.
Title: My 85 TBird
Post by: 86T-bird on May 12, 2012, 09:50:44 PM
Great to see a Terminator swap in a 4 eye!  Quite the shop too.
Title: My 85 TBird
Post by: MY83T on May 12, 2012, 10:18:56 PM
radical build, love it!
Title: My 85 TBird
Post by: cougarman on May 12, 2012, 10:22:48 PM
Subscribed. Wanna watch this!!
Title: My 85 TBird
Post by: 5.0 tbird on May 13, 2012, 01:04:14 AM
Nice, looking forward to this build!
Title: My 85 TBird
Post by: bodyman on May 13, 2012, 05:29:12 PM
Thanks guys, did a lot of looking on the net to research this project and could only find some 4 cam swaps into fox mustangs and newer birds, though I am sure it's been done. I am using the 2003 mustang K member, cooling componets, hydro boost, wiring for engine management only ( I think), spindles, brakes, and steering rack.
I will do my best to show what i am doing. Look forward to any questions, comments, or suggestions. I have been slowly working on it for a couple months but have not been able to post until recently. The plan is to get everything fabricated and running, then tear it down and make it look good. Here we go.
Please refer to post #106 for correct hydro boost install and brake pedal ratio.
Had to rebend line to clear wiper motor
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00110-1.jpg)
Only mods to the k member was to shorten the rear lower mounting tabs and locate and drill  the holes for the bolts. My research showed that I needed a 1/2 spacer plate between the k member and body, but mine seemed to measure 3/8 of an inch so thats what I went with.
03 on left, 85 on right
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00123.jpg)
Title: My 85 TBird
Post by: Sinista Chicken on May 13, 2012, 06:15:08 PM
I want your motor:bowdown:  Will def be watching this thread:popcorn:
Title: My 85 TBird
Post by: 1BadBird on May 13, 2012, 07:49:00 PM
Nice project!! Looks somewhat familiar although mines not as powerful....... LOL.... I likey :D
Title: My 85 TBird
Post by: Beau on May 13, 2012, 09:53:59 PM
Nice! Can't wait to see it all done up!
BTW....also the Cobra front control arms are better than the originals...I'm sure you're aware of that though ;)
Title: My 85 TBird
Post by: 50tbrd88 on May 13, 2012, 10:02:34 PM
Wow!  This would be one of my 1st choices for a powertrain swap someday.  This should get tons of attention when you get it done and park it somewhere with the hood popped.
Make sure to post plenty of pics and progress, I can't wait to see this as it progresses.
Title: My 85 TBird
Post by: bodyman on May 13, 2012, 11:21:09 PM
1BadBird
Nice project!! Looks somewhat familiar although not as powerful....... LOL.... I likey
I checked out your photos, very nice, thats gonna be one clean engine bay. I had to trim my k member lower mount and relocate the holes , you can just see the front of the orginal holes, didn't look like you had to trim yours.
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00124.jpg)
ThunderbirdSport302
Not sure what fCA's I am going to run. I am afraid that with the 03 k member, FCA's, and spindles that the frt track width will be to wide. Thinking I might have to use the 13 inch FCA's from a 93 mustang.
After mounting the hydroboost I removed the transmission crossmember mounts to move them rearward for the longer T56. Won't know exactly where to mount them until I get the new mount and crossmember bolted in.
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00117.jpg)
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00119-1.jpg)
Then I set the motor and trans assy onto the k member and put them on some rollers, lifted the frt of the car and rolled it into place. Ended up having to cut the sway bar mounts out of the car to clear the alternator. Put some temporary 3/8 inch spacers between the upper mount and k member and bolted it in.
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00128.jpg)
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00131-1.jpg)
Title: My 85 TBird
Post by: Beau on May 14, 2012, 05:58:05 AM
Bad-ass. :)
Title: My 85 TBird
Post by: turbotrav on May 14, 2012, 07:23:02 AM
I always wanted a Terminator motor in my XR7.... too much $$.  So I decided on a 351 with turbo instead.  Good luck with your mega swap.  It will be sweet when done.
Travis
Title: My 85 TBird
Post by: bodyman on May 14, 2012, 11:34:07 PM
After getting the motor set in  modified the factory mount for the intercooler pump and made a bracket for the body.
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00146-1.jpg)
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00145-1.jpg)
To mount the intercooler i trimmed up the factory brackets and made some tabs to mount it to the frt bumper rebar. Before welding the brackets up I installed the frt cover, used some plywood as a spacer for clearance, positioned and welded on the tabs. Still need to fab up some brackets to help support the rear of the cooler. Was able to use all of the mustang hoses and tubing, just had to shorten the hoses some here and there. It fits really well in the lower grille opening of the turbo coupe cover.
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00151-1.jpg)
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00155.jpg)
Title: My 85 TBird
Post by: flylear45 on May 18, 2012, 07:16:18 AM
Nice work. Lovin' this!
Title: Nice Work!!
Post by: 1BadBird on May 18, 2012, 09:15:51 AM
Quote from: bodyman;389872
Ya, I have to trim mine the same as you did yours. I got ahead of myself and painted the k-member before tpuppies it. I had marked it but ........  I'm liking your progress. Very nice work!!
John
Title: My 85 TBird
Post by: bodyman on May 20, 2012, 02:05:03 AM
Mounting the AC cond was not too bad. Had to make some lower brackets and used the 2003 mustang insulators. Also used the 03 mustang upper mounts and insulators. Had to relocate the left upper mounting hole, widen the support on both sides, and modify the upper support for the extra width. Still need to do some finish work here and there.
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00198.jpg)
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00197.jpg)
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00200.jpg)
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00202.jpg)
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00201.jpg)
Title: My 85 TBird
Post by: bodyman on May 20, 2012, 12:46:23 PM
Not sure using the 03 mustang rad and tanks were the right decision but I did get them in there, may have been easier to use a rad meant for the t bird and had a custom tank made for the intercooler. I ended up having to drill off the upper half of the lower rad support and replacing it with a piece with less rise. I could get the radiator in there without doing this but there was no room for any type of insulator. If I moved my top mounting plate up any the tanks would not clear the hood. The cap for the intercooler tank comes within 1/4 in of the hood bracing and I did not want to have to cut the hood any.
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00193.jpg)
Relief is for fan clearance
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00195.jpg)
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00207.jpg)
Also had to remove the  from the top of the rad support, better shot of that in the condenser pic.
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00180.jpg)
Mount to support rear of rad tank
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00181.jpg)
Title: My 85 TBird
Post by: 1BadBird on May 21, 2012, 02:55:34 PM
That's some killer work!!
Title: My 85 TBird
Post by: Sinista Chicken on May 21, 2012, 03:44:12 PM
That's quite a bit of fab work, but the end result sure looks factory
Title: My 85 TBird
Post by: bodyman on May 21, 2012, 11:23:03 PM
Thanks guys. If someone didn't know better I want it to look like Ford may have put it in there. On sunday was able to get everything mounted and hoses hooked up. Supported the back of the intercooler to the bracket fabbed up for the power steering cooler.
Did some searching on here about subframe connectors. Liked the looks of the thru the floor connectors, but was wondering about carpet fit and seat interference. Also liked the look of Aerocoupes (Darren) tubular set up, may go with something like that.
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00211.jpg)
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00212.jpg)
Title: My 85 TBird
Post by: mcb82gt on May 22, 2012, 12:11:55 AM
Wow!  Amazing work, I wish I had those skills.
Title: My 85 TBird
Post by: Drewstang on May 26, 2012, 09:06:35 AM
I'm taking notes on this.
Title: My 85 TBird
Post by: bodyman on May 29, 2012, 12:16:27 AM
Was able to get the transmission mounts welded in this weekend. Moved the mounts back 3.75 inches. Any more than that and the floor pans changed enough that the mounts did not fit well without major modifications. I did have to cut them a little bit to get them flush with the floor. On the L mount I cut in about 2 inches and rebent from the end of the cut to the edge. It was bent from the angle to where I began the cut.
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00216.jpg)
The R mount just needed the upper s cut to be able to fit flush with the foor pan.
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00217.jpg)
Even with the mounts set back the ford motorsport crossmember is maxxed out to the rear and the transmission mount bolts are almost to the rear most location.
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00222.jpg)
Title: My 85 TBird
Post by: bodyman on May 29, 2012, 12:57:24 AM
Also made some headway on getting the suspension figured out. First I found out that the steering shaft hits the header, so that needs some attention. Then I found out that the 275/40/r17 and svt cobra rims do not fit inside the fender. I have Maximum motor sport caster camber plates, coil overs, 03 spindle and brakes on 13" lower control arms with the SN95 ball joints. The caster camber plates are maxed out and the top of the tires still need to come in, I know with the 14" control arm that the camber will work out, but that still doesn't get the tire inside the fender. An easy fix would be some 8" frt rims with smaller tires, but I have not seen these rims in that width. May consider moving the camber caster mount holes in board if my alignment guy thinks this will get the tires inside the fender.
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00226.jpg)
On a good note the mustang width 9 inch rear with crown vic rear disk brakes and the same 275/40/R17s fit nicely, could even get a little more tire in there. They could use about a 1/4" spacer to move the tires out. I have SN 95 length rear springs, will be getting some adjustable RLCA to bump up the ride height.
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00225.jpg)
Title: My 85 TBird
Post by: 1986Élan on May 29, 2012, 05:28:08 PM
Nice work Bodyman
i have a question are you gonna keep your original cluster?
i was wondering how to deal with the t 56 digital signal of the vss in order to make the original speedometer work
id like to do a coyote swap  in the future but want to retain to stock cluster
Title: My 85 TBird
Post by: bodyman on May 29, 2012, 11:46:23 PM
Nice work Bodyman
Thanks,
I am having a custom cluster built by a friend. He is going to mount the mustang movements to a custom face. I would think you could find and electronic speedo that reads what yours does, or whatever you want,  and mount it to your face plate in place of the mechanical one. Should be able to use your needle and probably have to get a custom face printed to match, unless the sweep is exactly the same. May have to do that with all the guages. Unless your cluster is digital, then I don't have a clue.
Title: My 85 TBird
Post by: bodyman on January 01, 2013, 08:52:17 PM
It's been "awhile" but finally got some work done on the bird. Ended up going with a Glenns Performace sleeper sump fuel tank and a return type fuel system. Built a bracket to mount the fuel pump to the front of the tank and started to route fuel lines to the front. Glenn's instructions state to mount the pump at the same level as the tank outlet.  I need to get a 120 degree fitting for the end of the fuel pump to help keep the fuel line tucked in closer to the body.
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00254_zpsad467ebb.jpg)
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00256_zpse8645ed4.jpg)
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00257_zps6813d2ce.jpg)
Title: My 85 TBird
Post by: STANG8U on January 01, 2013, 09:07:27 PM
Very nice
I have a buddy that has done this swap on his 4 eye mustang and another buddy with a notch
Lots of work
Title: My 85 TBird
Post by: bodyman on January 01, 2013, 09:43:29 PM
STANG8U
Very nice
Lots of work
Thanks, It is proving to be a lot of work, but knew it would be. Hope your buddies thought it was all worth it.
Was also able to get some subframe connectors bent up and installed. Based them off of the Global West versions, they may be a bit shorter because of moving my trans brackets rearward.
(http://i1060.photobucket.com/albums/t456/bodymann/TBIRD006_zps1b271c93.jpg)
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00262_zps0d5116d5.jpg)
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00261_zps9156ffbf.jpg)
Title: My 85 TBird
Post by: STANG8U on January 01, 2013, 10:00:57 PM
I like those
Yea it's a bitchin car drivin it a few times one time was at the track it broke lose in 3rd and I almost smacked the wall thank god I saved it
http://www.carcraft.com/featuredvehicles/ccrp_1006_1981_ford_mustang/viewall.html
Title: My 85 TBird
Post by: bodyman on January 01, 2013, 10:39:18 PM
http://www.carcraft.com/featuredvehi...g/viewall.html
Good to hear. Cool write up on your buddies car, I remember seeing it when doing some research into the swap. I am however going to try to be satisfied with the 400 hp from the factory. For a while anyway.
Title: My 85 TBird
Post by: 1BadBird on January 01, 2013, 10:49:40 PM
Quote from: bodyman;406006
i am however going to try to be satisfied with the 400 hp from the factory. For a while anyway.
roflmfao
Title: My 85 TBird
Post by: STANG8U on January 01, 2013, 10:51:21 PM
Yea a stock termi is nothin to shake a stick at lol
Title: My 85 TBird
Post by: 83TB on January 03, 2013, 11:52:46 AM
Very nice build your doing, I think all the hard work your putting in will pay off, looks great.  How is the cluster coming?
Title: My 85 TBird
Post by: bodyman on January 03, 2013, 11:41:54 PM
83TB
Thanks, I think so too. Not sure about the cluster. Talked to my buddy tonight and it didn't come up and I didn't ask. He's about 3 hours away and I have not seen it for a while, he has some good ideas, so I will leave it up to him. Don't need it for some time, can get it running using the mentor to watch the vitals.
Title: My 85 TBird
Post by: bodyman on January 13, 2013, 12:57:55 PM
Couple pics my friend sent a while back. One is a possible layout for the guages and the other is a tbird emblem he milled for the turn signal indicators.
Also sent my dash pad off to Just Dashes. They said 6-8 week turn around.
(http://i1060.photobucket.com/albums/t456/bodymann/DSC01246_zps4492f019.jpg)
(http://i1060.photobucket.com/albums/t456/bodymann/DSC01245_zps94228e32.jpg)
Title: My 85 TBird
Post by: Drewstang on January 13, 2013, 10:38:15 PM
Nice work so far, keep it up and get this thing done.
Title: My 85 TBird
Post by: STANG8U on January 13, 2013, 10:49:46 PM
Nice
Title: My 85 TBird
Post by: 83TB on January 14, 2013, 09:06:12 AM
Very cool!!
Title: My 85 TBird
Post by: Crazy88 on January 14, 2013, 06:50:53 PM
Quote from: bodyman;406812
What was the cost of the Just Dashes service?
Title: My 85 TBird
Post by: bodyman on January 14, 2013, 08:51:12 PM
They quoted me $750.00 over the phone. When they get the dash they said they will contact me with the actual price, but that it should be as quoted. It is much more than I want to pay,(I don't think I paid that much for the whole car back in 1994) but for what I am putting into the rest of the car I am not going to look at a dash cap, cover, or cracks. I will post some before and after photos when I get it back.
Drewstang
I have high hopes of driving it this summer. It comes down to funding and ambition. Back when I had all kinds of ambition, I didn't have the funding. Now that funds are not so hard to come up with, I have half the ambition, I am not sure where, or when I lost it, but if anybody runs across it let me know.
Title: My 85 TBird
Post by: 88turbo on January 14, 2013, 09:39:59 PM
very nice work!!  I really cant wait to see this finished ;)  and that bird emblem your buddy milled is amazing....
Title: My 85 TBird
Post by: Drewstang on January 14, 2013, 10:11:03 PM
Quote from: bodyman;407009
Your project is making me want another 4 eye bird in a bad way. I found one in decent shape somewhat local and I'm trying to figure out what I want to do. I'm taking notes from your build because a Coyote 5.0 is the plan if I go through.
Title: My 85 TBird
Post by: STANG8U on January 14, 2013, 10:46:02 PM
A new 5.0 swap would be cool as hell
Title: My 85 TBird
Post by: bodyman on January 14, 2013, 11:46:10 PM
A new 5.0 would be cool. Does the 4.6 and the new 5.0 share bell housing patterns and motor mounts?
Title: My 85 TBird
Post by: STANG8U on January 14, 2013, 11:49:09 PM
I do not know off the top of my head but I do think they share the same 4.6 k member
Title: My 85 TBird
Post by: Drewstang on January 15, 2013, 07:32:11 PM
Yes the K-member, bellhousing, motor mounts, starter can all be used from the 4.6 family. Throw in a T56 or T45 and the Ford Racing hot rod harness and roll out.
Title: My 85 TBird
Post by: STANG8U on January 15, 2013, 08:00:07 PM
If you pick up this moths car craf my buddy's 4.6 notch made it in
Title: My 85 TBird
Post by: bodyman on January 20, 2013, 11:37:42 PM
Finally recieved my custom set of RLCA's from Maximum Motor Sports. Their normal adjustable arms for the Tbirds have a curved tube for the stock length spring. They built me a set with a straight tube so I could use the mustang length spring. They said they would be listing this item for sale on their website.
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00268800x600_zpsad609ccd.jpg)
I have also been working on the frt suspension to get the 9" svt rims with the 275/40 tires tucked under the fender. I moved the c/c plates inboard 1 inch further than the factory holes would allow. I had to cut out some of the inside of strut towers because the springs were hitting them. Then hauled it across town to the alignment shop to see if I could hit the specs. Was able to get to about 1 degree negative camber, street specs were .5 negative. I was not so lucky on the caster, was only able to get to about 1.3 degrees. I think with some 3/4 in forward offset lower control arms, and moving the c/c plates as far back on the strut tower as possible I will be able to get to the 4.5 degree spec. Once I get some flca's it will be back to the alignment rack to make sure I can hit the specs before the strut towers get rebuilt.  Right now the car is set with the RLCA's at the lowest point, so as the car gains some weight I should be able to keep the ride height where it is.
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00269_zpscbaceb52.jpg)
Also made a bracket to mount the cruise control servo. Utilized two holes aready in the body of the car. This is the area it is located on the 2003 mustang.
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00272_zps1bb1735a.jpg)
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00274_zps674d1033.jpg)
Title: My 85 TBird
Post by: STANG8U on January 20, 2013, 11:56:38 PM
I like the lowers
Title: My 85 TBird
Post by: 1BadBird on January 21, 2013, 09:39:18 AM
LUVIN IT !!! :bowdown:
Title: My 85 TBird
Post by: 347Thunder on January 21, 2013, 02:24:15 PM
 fine work, glad to see more birds being cared for, now if they would just show up at some car shows!!!
Title: My 85 TBird
Post by: bodyman on January 27, 2013, 06:32:23 PM
Spent about 20 hours going over the cobra wiring harness the last few days. Seperated what's needed and what's not, and started to fit the harness to the car. While it took a long time to cut open the harness and go over the wiring diagrams, there are not that many wires that will need to be hooked up. I am going to use the 2003 mustang battery junction box and ccrm.  I have had the pcm reprogrammed to remove the EGR, emission controls, PATS, and set up for a return fuel system. Discovered that the gauges, with the exception of engine oil pressure, are fed info over the same 2 data wires that go to the data link connector, may have to rethink my instument cluster plans. I will post specifics about the wiring when the car is up and running.
Complete mustang harness
(http://i1060.photobucket.com/albums/t456/bodymann/TBIRD008_zpscf74ee59.jpg)
What's left. The section to the left is the cruise control, starter circuit, and power feed wires into the car. Most of the wires that are labeled in that group are not needed, just not going to depin them until the car is running. Same goes for the bunch to the right near the pcm connector. The longer wires to the right are the wires that power the pcm, data link connector wires, back up lamp, air cond wire to hvac control switch, fuel pump relay trigger wire, and wires to the instrument cluster.
(http://i1060.photobucket.com/albums/t456/bodymann/DSC00276_zpse0967070.jpg)
Title: My 85 TBird
Post by: thundr306 on January 31, 2013, 07:52:55 PM
Great looking project. Can't wait to see it finished.
Title: My 85 TBird
Post by: bodyman on February 03, 2013, 12:26:09 AM
Spent most of the evenings this week working on the wiring. Have all the connections temporarily made but the cruise control deactivation wires, need to mount another switch on the brake pedal assy and rewire the clutch position switch. Also reworked my fuel pump mount, used the factory mount for better protection of the pump and wiring.
(http://i1060.photobucket.com/albums/t456/bodymann/TBIRD015_zps86f1e941.jpg)
(http://i1060.photobucket.com/albums/t456/bodymann/TBIRD014_zps2f124ebf.jpg)
Also mounted up the new 3/4" forward offset lower control arms and moved the c/c plates as far back on the strut towers as possible. Maximum Motor Sports thought with this set up I should be able to get about 3.75 degrees caster, a little shy of the 4.5 street setting they recommend, but so much better than the stock setting that it will be fine. Will fit the fenders and tires tomorrow to see how it looks with the tires set forward.
(http://i1060.photobucket.com/albums/t456/bodymann/TBIRD011_zps491d6239.jpg)
Title: My 85 TBird
Post by: bodyman on February 03, 2013, 10:35:24 PM
Mounted up the 2003 mustang swaybar today. To get the motor in I had to cut the original mounts out of the car. The 03 mounts under the rails and clears all the hoses and such under the frt of the 4.6. It also has shorter arms from the body mount point to the swaybar endlink hole for better tire clearence while turning. First had to clean the old mount reinforcement off the rails, then I mocked it up to find where to locate it, moved it as far back as I thought possible. Used the tbird mount that I cut out to mark and locate the holes. Also was able to use the tbird nut-plate and insert it into the rails. Because the k member is shimmed, the swaybar also needs shimmed.
Old mounting reinforcement with spot welds drilled
(http://i1060.photobucket.com/albums/t456/bodymann/TBIRD010_zpsad4b6c74.jpg)
Removed
(http://i1060.photobucket.com/albums/t456/bodymann/TBIRD012_zps2aff194d.jpg)
Also used old mount for guide to file square hole for clip
(http://i1060.photobucket.com/albums/t456/bodymann/TBIRD016_zps955562c6.jpg)
Had to enlarge an existing hole to get nut-plate installed
(http://i1060.photobucket.com/albums/t456/bodymann/TBIRD017_zpsa5be4609.jpg)
(http://i1060.photobucket.com/albums/t456/bodymann/TBIRD019_zpsaecc77c7.jpg)
Title: My 85 TBird
Post by: bodyman on February 11, 2013, 12:01:47 AM
Was able to get a few things done this weekend. Made a bracket to mount the 03 battery junction box, only issue was to make sure it cleared the neck for the washer solvent tank.
(http://i1060.photobucket.com/albums/t456/bodymann/tbird033_zpsf29cf1b8.jpg)
(http://i1060.photobucket.com/albums/t456/bodymann/tbird035_zpse4ef35a4.jpg)
Installed the new fuel rails, pressure regulator, and ran some fuel lines. Fuel lines are conductive core ptfe that Glenns Performance supplied with the tank, pump and regulator.
Return lines to regulator.
(http://i1060.photobucket.com/albums/t456/bodymann/tbird031_zps15a487c8.jpg)
Y block and feed lines to back of rails. Still need to run return line up to regulator. Also need to make some more clearance around the fuel lines.
(http://i1060.photobucket.com/albums/t456/bodymann/tbird030_zps113d0264.jpg)
Also remedied the swaybar endlink angle issue. The 3/8 rod ends look a bit small to me, but are rated at 8500 lbs. Will put some spacers on both sides of the rod end so there is no binding against the bracket or nut, that and some grade 8 bolts with lock nuts during final assy.
(http://i1060.photobucket.com/albums/t456/bodymann/tbird037_zps79f42e8c.jpg)
Title: My 85 TBird
Post by: Pro SC on February 12, 2013, 08:55:02 AM
Thats a really nice job you are doing, looking forward to seeing it done.
Title: My 85 TBird
Post by: bodyman on February 13, 2013, 12:40:47 AM
Thanks for all the compliments guys.
Plan A for hooking up the heater core and evaporator lines was to install the 03 components into the hvac assy so it would be plug and play. While the demensions looked good on paper neither piece would fit without making major modifications to the hvac case. So plan B was to put the 85 components back in and modify the 03 coolant lines and air cond lines. Coolant lines to the heater core were not to difficult to make work. I will have to make some custom lines to get the air cond worked out. No pics at the moment.
I have been working on getting everything hooked up so I can try to start it. If things go well I may be ready for the weekend. I think I am down to reinstalling the dash, the return fuel line, power steering cooler lines, a couple vacuum lines, and a recheck of the wiring. Still plenty of other things that need done, just can't wait to hear it run.
Title: My 85 TBird
Post by: bodyman on February 14, 2013, 09:35:52 PM
Well, I was just to close to it running to wait for the weekend. Last night I finished with the connections and hoses, changed the oil, and  filled the fluids. Today between the customers and phone calls I was able to install a make shift exhaust, fix a couple fuel leaks, set the fuel pressure, and she started right up. Idled a bit high and found the tps was loose, once that was set all seems to be ok. Ran it just long enough to get to temp to make sure the fan would kick in. The only negative of the day is a radiator leak. As many times as I have had that rad in and out it's hard to believe I didn't notice the small crack at the lower hose outlet. It's an aluminum tank, so I should be able to get it welded up. The motor will still have to come out a couple of times before it stays in for good, but I am thrilled knowing that the wiring needed to get it running worked.
Title: My 85 TBird
Post by: STANG8U on February 14, 2013, 09:55:07 PM
That's awesome
Title: My 85 TBird
Post by: Beau on February 14, 2013, 10:12:53 PM
Righteous. Can't wait to see more pics.
Title: My 85 TBird
Post by: bodyman on February 17, 2013, 03:29:19 PM
A few pics of the engine bay. Not much room left.
(http://i1060.photobucket.com/albums/t456/bodymann/tbird053_zps81e3068f.jpg)
(http://i1060.photobucket.com/albums/t456/bodymann/tbird052_zpscfe76f64.jpg)
(http://i1060.photobucket.com/albums/t456/bodymann/tbird051_zps1715ddc0.jpg)
Found a switch that will work for the brake cruise cancel. The 03 needs power thru this circuit until the pedal is depressed. It was not quite long enough to put a nut on both sides for adjustment, but using a washer as a shim worked out well.
Top is 85 vacuum switch, lower is the replacement with shim for the spacing and another for in front of the mount bracket so that the nut will not bottom out on the switch before it's tight.
(http://i1060.photobucket.com/albums/t456/bodymann/tbird045_zps9baa5ff3.jpg)
The bump out on the switch fits nicely into the mount bracket to center it.
(http://i1060.photobucket.com/albums/t456/bodymann/tbird046_zpsb8fad3b3.jpg)
Mounted up in the bracket
(http://i1060.photobucket.com/albums/t456/bodymann/tbird047_zps70def588.jpg)
Title: My 85 TBird
Post by: bodyman on February 21, 2013, 11:30:37 PM
I was hoping that the air conditioning was going to be plug and play, but since the 03 evap didn't fit in the case I modded a few pieces to get things hooked up.
All the fittings and hose were purchased at the local napa, and the tig welds were done at the welding shop next town over. I charged the system and everything is working, first time I have had air in the bird.
I used the 85 drier and cut off the long hose up to the compressor and had the fitting from the 03 drier tig welded on.
(http://i1060.photobucket.com/albums/t456/bodymann/tbird060_zpsdd6c1d5d.jpg)
The 03 hose from the condenser to the evap I cut the end off and had the correct fitting for the 85 evap tig welded on. The fitting was striaght and had to be carefully bent to about a 45 degrees to clear the valve cover. I used a larger piece of alum tube to make a sleeve.
(http://i1060.photobucket.com/albums/t456/bodymann/tbird056_zps39b5c3ce.jpg)
(http://i1060.photobucket.com/albums/t456/bodymann/tbird057_zps45b54876.jpg)
The  hose from the compressor to the drier I purchased a 45 degree #10 male spring lock fitting, a crimp in fitting with a low side port and 12" of 5/8 ac rated hose. I cut the hose crimp off one side of the low side port and had it tig welded to the 03 fitting near the compressor. The low fitting pipe fit inside the factory pipe with some minor filing . Then it was just index the fittings and hose and crimp.
(http://i1060.photobucket.com/albums/t456/bodymann/tbird054_zpse744e72a.jpg)
(http://i1060.photobucket.com/albums/t456/bodymann/tbird061_zpsf9f2da10.jpg)
(http://i1060.photobucket.com/albums/t456/bodymann/tbird063_zpse6692b4a.jpg)
Then I flushed the hoses
(http://i1060.photobucket.com/albums/t456/bodymann/tbird058_zpsb2776bc1.jpg)
Everything hooked up, the 03 switch works on the 85 drier. The only thing visible that wouldn't pass as factory is the sleeved hose, and I don't think it looks too bad.
(http://i1060.photobucket.com/albums/t456/bodymann/tbird064_zps77b7dffb.jpg)
(http://i1060.photobucket.com/albums/t456/bodymann/tbird065_zps0dcb8c8b.jpg)
Title: My 85 TBird
Post by: 347Thunder on February 21, 2013, 11:39:07 PM
 you are bad ass
Title: My 85 TBird
Post by: bodyman on March 11, 2013, 10:50:08 PM
347Thunder
 you are bad ass
Not sure about that, just willing to add parts to the s pile if something doesn't work out.
My dash pad from Just Dashes showed up today on UPS. Looks good.
Before
(http://i1060.photobucket.com/albums/t456/bodymann/TBIRDDASH001_zps8327f121.jpg)
After
(http://i1060.photobucket.com/albums/t456/bodymann/tbird080_zps6e14abcb.jpg)
Also have been working on getting the rear housing put together. Sand blasted the housing, center section, caliper brackets, backing plates and etch primed everything. Decided to go ahead and paint the caliper brackets and backing plates. Made some tabs to hold the brake hoses, which are from a S10 pickup. The rear disc brake set up is from a 2000 crown vic. Also got the drive shaft, shortened crown vic police.
(http://i1060.photobucket.com/albums/t456/bodymann/tbird074_zpsdf8fafea.jpg)
(http://i1060.photobucket.com/albums/t456/bodymann/tbird076_zps38cbbfc3.jpg)
(http://i1060.photobucket.com/albums/t456/bodymann/tbird078_zps2da0389f.jpg)
(http://i1060.photobucket.com/albums/t456/bodymann/tbird081_zps0c9bb67e.jpg)
Title: My 85 TBird
Post by: Thunderbird88 on March 12, 2013, 02:27:01 AM
Amazing work! Love it!
Title: My 85 TBird
Post by: STANG8U on March 12, 2013, 02:35:00 PM
That's very nice !!!!!!!!!!!!!!!!!
Title: My 85 TBird
Post by: bodyman on April 17, 2013, 11:51:17 PM
My buddy was up and we have some instrument cluster progress. We ended up using the whole mustang instrument cluster and mounting it to a piece of alum he machined and sprayed with some translucent black powder coat. I have the mustang connectors wired in and with the exception of the fuel gauge everything works as it should. These are GT gauges, now that I know this is going to work out I am going to get the white face SVT gauge set. With the trim plate installed the lower part of the bottom gauges are not visible, so the bird he milled will have to go, may remove the green inserts and move it over to the passenger side.
Alum blank with no powder coat.
(http://i1060.photobucket.com/albums/t456/bodymann/IMG_1574_zps13dfcda6.jpg) (http://s1060.photobucket.com/user/bodymann/media/IMG_1574_zps13dfcda6.jpg.html)
Powder coated and installed, had to remove some of the dash to get it all in there.
(http://i1060.photobucket.com/albums/t456/bodymann/tbird087_zps79956027.jpg) (http://s1060.photobucket.com/user/bodymann/media/tbird087_zps79956027.jpg.html)
Title: My 85 TBird
Post by: STANG8U on April 18, 2013, 12:15:31 AM
 that's bad bro .... I like it
Very trick
Title: My 85 TBird
Post by: bodyman on May 26, 2013, 11:17:09 PM
Not much progress as of late, about 2 months ago my help decided he had had enough of the body shop, he was with me for 12 years. He left for a sales position at the local lumber yard. For the first time in 14 years I do not have an employee and have been running hard to keep up. I did find some time to work on the e brake system today. I am running crown vic rear discs, on the vics the l caliper is on the back side of the axle and the r caliper is on the front side. I am going to run the r side upside down to get both calipers on the rear side of the axle. The only issue I see with this is that the r caliper will have to be removed to be bled. It also allows me to use a traditional e brake set up. I ordered 2 left side crown vic e brake cables and sent them to Madison Power Systems to have them cut to the correct length. The rest of the system is stock.
Shortened cables
(http://i1060.photobucket.com/albums/t456/bodymann/tbird088_zpscc7a8486.jpg) (http://s1060.photobucket.com/user/bodymann/media/tbird088_zpscc7a8486.jpg.html)
Mount relocated to the subframe connector
(http://i1060.photobucket.com/albums/t456/bodymann/tbird093_zpsed6f02d3.jpg) (http://s1060.photobucket.com/user/bodymann/media/tbird093_zpsed6f02d3.jpg.html)
Left side
 (http://i1060.photobucket.com/albums/t456/bodymann/tbird098_zps099e913f.jpg) (http://s1060.photobucket.com/user/bodymann/media/tbird098_zps099e913f.jpg.html)
(http://i1060.photobucket.com/albums/t456/bodymann/tbird090_zps4a960ffa.jpg) (http://s1060.photobucket.com/user/bodymann/media/tbird090_zps4a960ffa.jpg.html)
Right side
(http://i1060.photobucket.com/albums/t456/bodymann/tbird099_zpsaebf1c0e.jpg) (http://s1060.photobucket.com/user/bodymann/media/tbird099_zpsaebf1c0e.jpg.html)
(http://i1060.photobucket.com/albums/t456/bodymann/tbird091_zps244e4838.jpg) (http://s1060.photobucket.com/user/bodymann/media/tbird091_zps244e4838.jpg.html)
Connectors from Rock Auto, had to grind down the cable crimps to get them to fit into the connector.
(http://i1060.photobucket.com/albums/t456/bodymann/tbird096_zps22a66326.jpg) (http://s1060.photobucket.com/user/bodymann/media/tbird096_zps22a66326.jpg.html)
Title: My 85 TBird
Post by: STANG8U on May 27, 2013, 12:39:50 AM
looking good
i need to get some t bird rear arms one day
Title: My 85 TBird
Post by: Big B on May 28, 2013, 03:30:00 AM
All great work here!
Love that instrument cluster overlay with the Engine Turning on it, and the milled bird. Trick Indeed.
This has to be one of the most bad-ass Bird's on the entire site. You sir, are inspiring me right now.
Title: My 85 TBird
Post by: bodyman on May 28, 2013, 02:31:19 PM
Thanks guys.
There are many builds on this site that keep me motivated, I am still drooling over 86-Tbirds latest photos. With my lack of employee situation it probably won't see the road this summer, it was a pretty lofty goal anyway. Next up is to get the exhaust system parts ordered and fabbed up.
My friend does make some very trick parts with his cnc mill, I don't even want to know how many hours it takes to measure and set up a program to create these parts. Here is his latest part, dash for a bike he just picked up. He had this part anodized, we may end up doing this to my parts as well.
(http://i1060.photobucket.com/albums/t456/bodymann/AnoDash_zps9c1521c5.jpg) (http://s1060.photobucket.com/user/bodymann/media/AnoDash_zps9c1521c5.jpg.html)
Title: My 85 TBird
Post by: 1BadBird on May 29, 2013, 09:17:50 AM
Quote from: bodyman;416158
Ahhhh gee whizz...... quit ...... you're making me blush LOL
On the other hand my wife said to stop because your making my head swell :P
As in not enough employees? That sucks.
Title: My 85 TBird
Post by: SirChirpAlot on June 01, 2013, 03:59:16 PM
Your doing some very nice work there BodyMan
I have been away from this site way to long...
Title: My 85 TBird
Post by: 347Thunder on June 01, 2013, 04:04:12 PM
Them some sweet ass welds
Title: My 85 TBird
Post by: bodyman on June 12, 2013, 09:09:19 PM
After hours of youtube exhaust clips and other internet research I finally decided on some exhaust components. Went with Magnaflows 2.5 in 304 stainless builder kit, Mac Prochamber, and SLP Power flo lers. Was going to go with high-flo cats and a mac prochamber but read some bad things about running the cats with emmisions delete in the tune.
The Magnaflow kit and the SLP lers are very nice pieces. I read a lot of good things about the Mac Prochamber, and liked the exhaust tone, but for what it costs I am disapointed. For starters they do not have just the chamber for sale, had to buy one for an application, the cheapest version was for the 05-09 mustang. Then when I opened the box and saw welding spatter all over it, then looked at what it was and how it was put together, I thought to myself I could build that for 1/3 the cost and make it look at least as good if not better. Thinking about sending it back...
(http://i1060.photobucket.com/albums/t456/bodymann/tbird100_zpsf9452aac.jpg) (http://s1060.photobucket.com/user/bodymann/media/tbird100_zpsf9452aac.jpg.html)
(http://i1060.photobucket.com/albums/t456/bodymann/tbird102_zpscabac36f.jpg) (http://s1060.photobucket.com/user/bodymann/media/tbird102_zpscabac36f.jpg.html)
(http://i1060.photobucket.com/albums/t456/bodymann/tbird103_zpsa7c0abda.jpg) (http://s1060.photobucket.com/user/bodymann/media/tbird103_zpsa7c0abda.jpg.html)
Title: My 85 TBird
Post by: Big B on June 13, 2013, 05:04:50 PM
If you have access to a mandrel bender, I'd send their  back, and build something I could be proud of...
Stainless pipe is fairly cheap to buy in straight 8ft lengths.
Title: My 85 TBird
Post by: bodyman on June 13, 2013, 09:12:40 PM
Big B
Not sure how far away the nearest mandrel bender is, maybe a couple hours, I'm kind of in the middle of nowhere. The Magnaflow kit is nice, it's just the Mac Prochamber that leaves a little to be desired. I will be checking into their return policy.
Title: My 85 TBird
Post by: 1BadBird on June 13, 2013, 09:55:08 PM
I hope it works out for ya. That's a nice looking box of parts :)
Title: My 85 TBird
Post by: Big B on June 14, 2013, 01:47:51 PM
If you don't have easy MB access, you might be better off keeping it then. Those are the bends that you want to have, in that box. I will use any excuse I can find to build my own setup, lol. Either way, Stainless exhaust is always  nice to have.
Title: My 85 TBird
Post by: Clayton on June 17, 2013, 03:46:03 PM
When i got my lers from MAC they had what you describe also. They also turned my hands silver from the coating on them. I didnt care it wire brushed off the sound is amazing. Theyre quiet until about 2500-3000 rpms. Unlike the flowmaster super 40's i had on it before.
Your progress and attention to detail is amazing. It will be one super cool 85 when youre done with it. Planning on keeping it the same colors?
Title: My 85 TBird
Post by: bodyman on June 17, 2013, 07:42:40 PM
87thunderbirdBlackJack
Yes, still red with white racing stripes, but not the viper red that is on there now. It had too much of an orange cast out in the sun for me, thinking about going with the E4 red that is on my ford pickup in post #52, or the newer ford race red, not sure of the code at the moment.
After checking into Mac's return policy I will be keeping the prochamber. By the time I pay shipping and the restock fee, buy some materials to make one, I may as well invest some time in sanding off the welding spatter and cleaning it up the best I can.
Title: My 85 TBird
Post by: bodyman on July 13, 2013, 12:15:30 AM
Big B
 I'd send their  back
I should have taken this advice.  Started work on the exhaust and when I tried to do some practice tig welds on some cut offs I discovered that the magna flow kit is 409 stainless, I had assumed it was 304. I couldn't believe it, but I checked the magna flow website and all it says is 100% stainless, doesn't say it is 304. Costly mistake. Any rate here is the little I had accomplished.
(http://i1060.photobucket.com/albums/t456/bodymann/tbird007_zps584bd44e.jpg) (http://s1060.photobucket.com/user/bodymann/media/tbird007_zps584bd44e.jpg.html)
(http://i1060.photobucket.com/albums/t456/bodymann/tbird006_zpsf561aea8.jpg) (http://s1060.photobucket.com/user/bodymann/media/tbird006_zpsf561aea8.jpg.html)
(http://i1060.photobucket.com/albums/t456/bodymann/tbird005_zps4b63951d.jpg) (http://s1060.photobucket.com/user/bodymann/media/tbird005_zps4b63951d.jpg.html)
On a good note I found a way to get some vented rear rotors in place of the 96-02 crown vic non vented. In 03 the vics started running a vented rear that is .4" larger in  diameter (11.65 compared to 11.25). I had one turned down to the 02 diameter. The 03 rotor is also .2" thicker, but the wider 03 caliper bolts up with the 02 pads installed.
(http://i1060.photobucket.com/albums/t456/bodymann/tbird_zps5fb8093e.jpg) (http://s1060.photobucket.com/user/bodymann/media/tbird_zps5fb8093e.jpg.html)
Title: My 85 TBird
Post by: Aerocoupe on November 17, 2013, 01:54:48 PM
Not sure how the hell I missed this build thread but wow, what a challenging build and super clean! Any progress or did I miss something since your last post?
Darren
Title: My 85 TBird
Post by: STANG8U on November 17, 2013, 02:06:51 PM
Would love to see any updates
Title: My 85 TBird
Post by: bodyman on November 18, 2013, 01:22:45 PM
Unfortunately nobody has missed anything since the last update. Have not been able to touch it since early spring. Hopefully I can get back to it after the first of the year. Have not lost interest, just have not had the time to work on it after my employee moved on this spring, it took a couple of months for me to find a new employee and am still trying to catch up.  Now that I have all my wood cut and in for the shop, the deer hits are rolling in and will keep me really busy for a couple of months.
Aerocoupe
Darren
Thanks!
Title: My 85 TBird
Post by: 83TB on November 22, 2013, 02:15:09 PM
Dude loving the build, the car suspension is what I like reading about.  The mods and everything look top notch.
Title: My 85 TBird
Post by: flylear45 on November 22, 2013, 08:42:23 PM
I was just going back over your build and saw this quote. I laughed out loud because it is SO, so true.
Awesome project, man. Keep digging on it.
Title: My 85 TBird
Post by: Bob on November 22, 2013, 10:09:35 PM
Quote from: bodyman;424541
Thanks!
I missed your thread too bodyman,  just seen it tonight for the first time.. awesome work! I'm looking forward to seeing more.
Title: My 85 TBird
Post by: xjeffs on December 22, 2013, 09:28:23 AM
Great to see another mod fox swap.  I just finished the hydroboost conversion too, only I modded the pedal instead of the mounting plate.  I see a lot of the same work but also a lot of great ideas that you did too.  Good stuff.
http://www.foxtbirdcougarforums.com/showthread.php?18403-88-Cougar-XR7-4-6L-3V-update-12-27-2011-Engine-trans-and-TC-rear-end-in
I'm also a little over an hour away, too. If you're ever in Waterloo, stop by.
Title: My 85 TBird
Post by: bodyman on December 22, 2013, 05:08:07 PM
Thanks for the link to your build, some how I missed it. Had no idea there was another mod swap going on so close. Does look like a lot of the same work, always like seeing different ways of getting something done.
I do get through Waterloo once in a while, would make a good road trip for the bird when I get it done. If you find yourself up here in the middle of nowhere the same goes, stop on by.
Title: My 85 TBird
Post by: bodyman on June 01, 2014, 11:34:49 PM
The bird finally has some progress. Made the trip across town to the alignment shop on Friday. With the 3/4" forward offset front lca's and the c/c plates moved rearward as much as possible it ended up at 4.2 degrees caster, just shy of the 4.5 degrees Maximum Motor Sports recommends. Still was able to get 1 degree negative camber, MM recommends .5 negative for street use, so good I am good there.
Sat afternoon I pulled the motor and trans back out so I could weld up the strut towers from the modifications and fix a few other issues. Did not get to any of that but have been working on some cold air intake mods. I have never attempted anything like this but so far am pleased with the results. With a fan a few feet in front of the bumper there is good airflow through both outlets. The driver side will only have an outlet for the brakes, unless I can think of something else to aim some air at.
(http://i1060.photobucket.com/albums/t456/bodymann/004_zpsceebf4c5.jpg) (http://s1060.photobucket.com/user/bodymann/media/004_zpsceebf4c5.jpg.html)
One outlet for the air cleaner, one for brake cooling.
(http://i1060.photobucket.com/albums/t456/bodymann/001_zpsbc5d0ff3.jpg) (http://s1060.photobucket.com/user/bodymann/media/001_zpsbc5d0ff3.jpg.html)
Covered with 3M 8115 mixed with pulled apart fiber mat. Sanded down after cure, will finish it smooth later.
(http://i1060.photobucket.com/albums/t456/bodymann/009_zps7effade4.jpg) (http://s1060.photobucket.com/user/bodymann/media/009_zps7effade4.jpg.html)
Mounted in the fog lamp location, had to trim a little off of the bumper support.
(http://i1060.photobucket.com/albums/t456/bodymann/005_zps06f4de4e.jpg) (http://s1060.photobucket.com/user/bodymann/media/005_zps06f4de4e.jpg.html)
(http://i1060.photobucket.com/albums/t456/bodymann/011_zps412f3d6c.jpg) (http://s1060.photobucket.com/user/bodymann/media/011_zps412f3d6c.jpg.html)
(http://i1060.photobucket.com/albums/t456/bodymann/012_zps11aa6980.jpg) (http://s1060.photobucket.com/user/bodymann/media/012_zps11aa6980.jpg.html)
Title: My 85 TBird
Post by: STANG8U on June 02, 2014, 09:22:29 AM
Very cool .... Lol
Title: My 85 TBird
Post by: MechanicMatt on June 02, 2014, 10:13:52 PM
Thats like mechanic paper-mache, I love it.
Title: My 85 TBird
Post by: bodyman on June 02, 2014, 10:58:10 PM
STANG8U
Very cool .... Lol
I hope so... Lol. I never understood the cold air intake kits that just lay an open filter in the hot engine bay.
MechanicMatt
Thanks, I always did enjoy art class. :D
Title: My 85 TBird
Post by: JeremyB on June 03, 2014, 05:56:32 PM
First time to see this. Very nice build!
Title: My 85 TBird
Post by: bodyman on June 23, 2014, 12:31:50 AM
JeremyB
Thank you!
Some progress the last couple of weeks. I was able to get the other scoop for the brake ducts made. Also made a air deflector to keep the air moving thru the intercooler.
(http://i1060.photobucket.com/albums/t456/bodymann/0111_zps244f88b7.jpg) (http://s1060.photobucket.com/user/bodymann/media/0111_zps244f88b7.jpg.html)
This weekend started the mods to the strut towers. Moved the mounting points for the c/c plates inboard 1" and back as far as possible. The coil over springshiznit the inside of the strut towers before getting to the desired camber spec because of the mustang length (13") lca's. Used 12 gauge metal across the top and down the side, with the original metal spot welded to it.  R side done, just started L side.
(http://i1060.photobucket.com/albums/t456/bodymann/0042_zps3e58bdea.jpg) (http://s1060.photobucket.com/user/bodymann/media/0042_zps3e58bdea.jpg.html)
(http://i1060.photobucket.com/albums/t456/bodymann/0093_zps153645cf.jpg) (http://s1060.photobucket.com/user/bodymann/media/0093_zps153645cf.jpg.html)
(http://i1060.photobucket.com/albums/t456/bodymann/010_zpsfe20dbe7.jpg) (http://s1060.photobucket.com/user/bodymann/media/010_zpsfe20dbe7.jpg.html)
Title: My 85 TBird
Post by: Aerocoupe on June 23, 2014, 10:53:09 PM
Not sure if this would have fixed the issue but Maximum makes a tool that is sometimes used to relieve the driver's side shock tower when it comes to coil over spring interference:
http://www.maximummotorsports.com/Coil-Over-Spring-Clearance-Tool-P1413.aspx
I think yours was a little more of an issue than normal and it sounds like the problem was on both sides.  I like your solution as it will look like it was never not factory when you are finished.
Darren
Title: My 85 TBird
Post by: bodyman on June 23, 2014, 11:15:03 PM
They actually included that tool in the coil over kit I purchased from them. The interference was up higher in the tower because of relocating the c/c plate. On the R side the interference was minimal, probably could have added an extra spacer to move the spring down and been fine. The L tower is a different story. The inner bolt for the c/c plate ended up where there was no tower to put it. I figured if I was going to have to mod one, might as well do both.  I hope to get to the L tower this weekend, the photos will better show what the problem was.
Title: My 85 TBird
Post by: Aerocoupe on June 24, 2014, 07:52:45 AM
I figured it was more than that tool was meant to handle. Back to the modding and looking forward to more build pictures.
Darren
Title: My 85 TBird
Post by: Jack Hidley on June 25, 2014, 04:02:23 AM
Mr. Sass,
One question and one comment.
Have you had a chance yet to jack up the rear of the chassis to see how much droop travel the rear suspension has with the Mustang shocks at the ride height that you have the car at?
I think you are going to have one problem with the hydroboost installation. All of the 1987-88 T-Birds have a 3.5:1 pedal ratio. That is the pedal pad moves 3.5 units for each unit that it pushes the m/c pushrod. I do not have the data for your 1985 2.3l turbo, but I assume it is the same. You can check you pedal ratio be measuring the physical brake pedal dimensions and dividing one by the other.
The Mustang that you pulled the hydroboost unit from has a pedal ratio of 4.75:1.
Since you appear to have connected the hydroboost unit pushrod to the 3.5:1 pedal pin, the required pedal effort and travel is going to be quite a bit different than what Ford designed. The brake pedal effort is going to be 36% (4.75/3.5) higher. The travel at the pedal pad is going to be reduced by the same amount.
To correctly fix this, the pin on the brake pedal should be moved upwards slightly less than 1" (0.97") and the hydroboost unit should be raised on the firewall to correctly align the pushrod so it is straight.
On second thought, since your rear brake calipers have 60% more piston area than the Mustang rear calipers the hydroboost system was designed around, I would only raise the pin on the brake pedal 0.75".
Title: My 85 TBird
Post by: bodyman on June 25, 2014, 10:47:17 AM
Jack,
Thank you for taking the time to check out my build thread here.
I will check into the brake pedal ratio and make the needed adjustments.
If you think the vic rear calipers are going to be an issue I am not against getting something else fitted up, or finding a better suited m/c.  Better now than later.
I have not checked rear axle travel, I will install my shock adapters and do so.
Thanks again, Joe
Title: My 85 TBird
Post by: phils88gt on June 26, 2014, 10:14:11 AM
I also am in the same boat and it very certain I have almost no droop travel on my 88. What is your ride height from some static point and I can compare to mine.
Title: My 85 TBird
Post by: Jack Hidley on June 26, 2014, 03:49:52 PM
Mr. Sass,
I don't think the Crown Vic rear calipers will create a major problem on your car. There do have larger pistons than what is ideal for your application. This creates two problems.
1) Increases the amount of rear brake bias. Most of this can be dealt with through the adjustment of the proportioning valve. Since your car is going to have a staggered tire setup, that helps compensate some also.
2) It will make the brake pedal have more travel and require less effort. As noted above this is being countered by the fact that that the pedal ratio in the car is to low. It could also be corrected with a different m/c diameter, but there are no other diameter m/c that will fit on the hydroboost unit.
With the pin on the pedal raised 0.75" I think it will be fine.
Title: My 85 TBird
Post by: bodyman on June 27, 2014, 04:37:23 PM
Jack,
Thanks for your input on this, I will give the vic brakes a try.
I will not have any tire stagger for now, it will be 275 40's all around. I was not brave enough to order the 315's to see if they would fit.
phils88gt
It will be a while before I check, but I will post what I find when I do.
Title: My 85 TBird
Post by: bodyman on July 06, 2014, 07:22:16 PM
Here are the mods to the L strut tower. The hydro boost just clears during installation, if it ever needs replaced the motor will have to be pulled, which may have been the case anyway.
(http://i1060.photobucket.com/albums/t456/bodymann/LSTRUTTOWER3_zps24f14fe4.jpg) (http://s1060.photobucket.com/user/bodymann/media/LSTRUTTOWER3_zps24f14fe4.jpg.html)
Fabricated cap
(http://i1060.photobucket.com/albums/t456/bodymann/LSTRUTTOWER4_zps7e6f1893.jpg) (http://s1060.photobucket.com/user/bodymann/media/LSTRUTTOWER4_zps7e6f1893.jpg.html)
Inside seams welded, ground, sandblasted and coated with 3M weld thru primer
(http://i1060.photobucket.com/albums/t456/bodymann/LSTRUTTOWER6_zps72362f12.jpg) (http://s1060.photobucket.com/user/bodymann/media/LSTRUTTOWER6_zps72362f12.jpg.html)
Bolted and clamped, ready to weld
(http://i1060.photobucket.com/albums/t456/bodymann/LSTRUTTOWER9_zps4be61215.jpg) (http://s1060.photobucket.com/user/bodymann/media/LSTRUTTOWER9_zps4be61215.jpg.html)
Welded up and finished off
(http://i1060.photobucket.com/albums/t456/bodymann/LSTRUTTOWER11_zpsd184320c.jpg) (http://s1060.photobucket.com/user/bodymann/media/LSTRUTTOWER11_zpsd184320c.jpg.html)
(http://i1060.photobucket.com/albums/t456/bodymann/LSTRUTTOWER12_zpsf758d8ad.jpg) (http://s1060.photobucket.com/user/bodymann/media/LSTRUTTOWER12_zpsf758d8ad.jpg.html)
Like the R side all the original metal was welded to the new.
(http://i1060.photobucket.com/albums/t456/bodymann/LSTRUTTOWER13_zpsae2f38b7.jpg) (http://s1060.photobucket.com/user/bodymann/media/LSTRUTTOWER13_zpsae2f38b7.jpg.html)
Title: My 85 TBird
Post by: bodyman on July 07, 2014, 10:55:40 PM
Jack Hidley
The 85 does have a pedal ratio of 3.5:1. It measured 13" from the center of the brake pedal pad to the center of the of the pivot and 3.7" from the center of the pedal pin to the pivot which comes to 3.51. Not sure how accurate the measurements are but definitely close enough to confirm 3.5:1.
Following the above advice I moved the pin up .75" for a ratio of 4.42:1. Pretty straight forward, grind off the weld that holds the pin and drive it out. The pin is larger than 1/2" and smaller than 5/8" and since I do not own a drill bit between I drilled the hole to 1/2" and carefully reamed it out with a die grinder until the pin was a press fit. Welded it in and filled in the old hole. Had to relocate the brake light switch so that the switch pad would hit it. Still need to reinstall the pedal assy and mount up the hydro boost to see how well the pushrod lines up with the pin.
(http://i1060.photobucket.com/albums/t456/bodymann/BRAKEPEDALMOD2_zps14859911.jpg) (http://s1060.photobucket.com/user/bodymann/media/BRAKEPEDALMOD2_zps14859911.jpg.html)
(http://i1060.photobucket.com/albums/t456/bodymann/BRAKEPEDALMOD1_zps69fb8c96.jpg) (http://s1060.photobucket.com/user/bodymann/media/BRAKEPEDALMOD1_zps69fb8c96.jpg.html)
Also worked on the header to steering shaft issue. Cut the header tube and overlapped the metal to make some clearance. Not going to weld it up until I reinstall to make sure that it clears. The BBK long tubes were on the motor when I purchased it and the header was already flattened for the steering shaft, just not quite right for the bird. Thinking about sending the headers in to have them coated, possibly to Jet Hot.
(http://i1060.photobucket.com/albums/t456/bodymann/HEADERMOD_zps859b9513.jpg) (http://s1060.photobucket.com/user/bodymann/media/HEADERMOD_zps859b9513.jpg.html)
(http://i1060.photobucket.com/albums/t456/bodymann/HEADERMOD3_zps99c0a0b9.jpg) (http://s1060.photobucket.com/user/bodymann/media/HEADERMOD3_zps99c0a0b9.jpg.html)
Title: My 85 TBird
Post by: Aerocoupe on July 08, 2014, 07:35:26 PM
I would think that the pinch in the two primaries will affect those cylinders performance. For the pain in the ass long tubes are I would try and reroute the primary do that the flow is not restricted.
Darren
Title: My 85 TBird
Post by: bodyman on July 08, 2014, 11:17:21 PM
Aerocoupe
 Darren
Only one tube is pinched, but I agree it has to affect that cylinders performance somewhat. Not too much good said about the bbk headers over on some of the mustang sites. I am going to live with them as is for now. I need MUCH more practice with my tig, but would like to build a stainless steel set for it someday.
Title: My 85 TBird
Post by: bodyman on July 13, 2014, 11:26:12 PM
Only progress worth noting this weekend was mounting up the hydro boost and pedal assy to check for alignment. I was expecting to have to move the hydro boost on the firewall but it turned out that with the pedal pin raised .75" and the prior mods to the booster mounting plate that the rod lined up almost perfectly straight. I knew  the rod was at an angle prior to changing the pin height, but thought it was better than it was, and I quote,
I moved the holes in the mounting plate upward 1 inch, this moved the booster down so that it was more in line with the brake pedal rod mount and lined up with the hole in the firewall. Could have moved it down a little farther so that the rod was better lined up with the pedal mount, but it did hook up.
To be correctly aligned I should have moved it down much further. Hard to believe that doing a poor job of doing it wrong worked out for the best.
(http://i1060.photobucket.com/albums/t456/bodymann/rodalignment_zpsaf9fd941.jpg) (http://s1060.photobucket.com/user/bodymann/media/rodalignment_zpsaf9fd941.jpg.html)
(http://i1060.photobucket.com/albums/t456/bodymann/rodalignment2_zps83c8c636.jpg) (http://s1060.photobucket.com/user/bodymann/media/rodalignment2_zps83c8c636.jpg.html)
(http://i1060.photobucket.com/albums/t456/bodymann/boostertower_zpsc9577b51.jpg) (http://s1060.photobucket.com/user/bodymann/media/boostertower_zpsc9577b51.jpg.html)
Title: My 85 TBird
Post by: MobileBill23 on September 10, 2014, 10:24:36 PM
Beautiful work Bodyman.  Seeing your car progress makes me want to get out and work on my Bird.
Title: My 85 TBird
Post by: bodyman on September 12, 2014, 09:24:56 AM
Thank you. Mine has been in a steady holding pattern the last couple of months.
Title: My 85 TBird
Post by: bodyman on January 31, 2015, 11:55:48 PM
Bit of an update. Over the Christmas holiday I was able to reinstall the motor/trans. Unfortunately the mods to the right lower firewall for header clearance, and the header tube for steering shaft clearance were not enough. The plan today was to pull it back out and try again, but I got side tracked and started building the strut tower brace. I used some elec conduit for a couple of test runs and then bent up the 1 1/4" tube and built some mounting plates. There is 3/8" between the tube and blower and about 1/4" between the tube and the hood, hopefully that is enough. If not I will have to make one from 1" tube. I will use some 1" tube to make the braces back to the firewall.
(http://i1060.photobucket.com/albums/t456/bodymann/IMG_0315_zpsebuppgjd.jpg) (http://s1060.photobucket.com/user/bodymann/media/IMG_0315_zpsebuppgjd.jpg.html)
(http://i1060.photobucket.com/albums/t456/bodymann/IMG_0316_zpsm5ciho25.jpg) (http://s1060.photobucket.com/user/bodymann/media/IMG_0316_zpsm5ciho25.jpg.html)
(http://i1060.photobucket.com/albums/t456/bodymann/IMG_0314_zpsqzqqlh2d.jpg) (http://s1060.photobucket.com/user/bodymann/media/IMG_0314_zpsqzqqlh2d.jpg.html)
Title: My 85 TBird
Post by: Aerocoupe on February 01, 2015, 04:48:35 PM
Are you going to solid mount the motor?  I would worry that there is not enough clearance between the blower case and the 1-1/4" rod for when you have the motor wound up and trying to tear out the driver side motor mount.  Other than that the brace looks fantastic!
Darren
Title: My 85 TBird
Post by: bodyman on February 01, 2015, 06:28:49 PM
Aerocoupe
 Darren
 I am concerned about the clearance. Going to try some good polyurethane mounts. Something like these,  http://www.energysuspensionparts.com/proddetail.asp?prod=4.1127  I was going to build it from 1" tube, which would have given me 5/8" clearance, but liked the look of the 1 1/4" tube so much better. I used 3/8" spacer between the rails and the k member, I might just make that 1/2".
Also considering cutting the bottom of the tube out above the blower case and welding in a flat piece. If I did this and move the k member down the extra 1/8",  I might be able to get somewhere near 3/4" and 7/8" clearance. Thoughts on how much is enough?
Title: My 85 TBird
Post by: Aerocoupe on February 02, 2015, 04:09:13 PM
I was going to measure the Maximum Motorsports strut tower brace I have on my 93 Coupe but it does not pass over the top of the intake.  Rather it pushed forward from the strut towers a couple of inches and then goes in front of the intake and across the top of the distributor but towards the back of the cap.
Could you rework it to be more like what they install on the Cameros?  By running the bar to the back of the motor it may give you more clearance and be easier to work on things but I am just guessing here.
X
Darren
Title: My 85 TBird
Post by: bodyman on February 02, 2015, 09:33:42 PM
Attachment 35711
 Darren
That's not a bad idea. I held one of my conduit test runs in place and it has potential. If in the end what I am doing doesn't work I will have to give this route a try.
I am not ready to give up on what I have just yet though. I found a few posts of guys with newer mustangs running about 3/8" clearance between their intake cover and the strut tower brace. Couple of them say that it does touch under hard acceleration, they can just see where it rubs. That being said, there is a difference between a intake cover hitting and the case of the blower. It also seems that most that have installed polyurethane motor mounts claim that it will raise the motor at least 1/2", so that's not going to work either. I went ahead and marked the tube 7/8" above the blower, cut it out and welded it up. This looks like plenty of clearance, tempted to weld in another 1/8" strip. I have no idea how much this weakens the tube, but it still seems plenty stout. When it's all said and done I will have to use some clay and check the clearance after a good launch or two.
Filler metal is same thickness as the tube
(http://i1060.photobucket.com/albums/t456/bodymann/IMG_0317_zpsl58tmwzk.jpg) (http://s1060.photobucket.com/user/bodymann/media/IMG_0317_zpsl58tmwzk.jpg.html)
(http://i1060.photobucket.com/albums/t456/bodymann/IMG_0318_zpstbzl2yqw.jpg) (http://s1060.photobucket.com/user/bodymann/media/IMG_0318_zpstbzl2yqw.jpg.html)
(http://i1060.photobucket.com/albums/t456/bodymann/IMG_0321_zps2dsiuxkq.jpg) (http://s1060.photobucket.com/user/bodymann/media/IMG_0321_zps2dsiuxkq.jpg.html)
Title: My 85 TBird
Post by: Aerocoupe on February 02, 2015, 10:06:37 PM
If the shock towers ever push in towards each other it may kink it but I say in your case it's worth a shot. If it was me and my no welding ass then I would persue the other option just because it would take me a week to get my buddy to weld up another one plus he doesn't work for free. He doesn't charge me full boat but it just sucks I cannot weld. Anyhow, give it a shot and see what happens. Maybe don't paint it until it proves out?
Darren
Title: My 85 TBird
Post by: bodyman on February 04, 2015, 12:09:39 AM
Aerocoupe
 Darren
I am fairly confident that it won't kink. Have been over at the corner carvers site reading up on some of their opinions on how much force, or lack of force, is actually put on the strut tower brace. There is also some good info on the fox body  rear suspension over there that is a good read.  Here is what Jack Hidley had posted about the strut tower brace.
I can't give out numbers, but I can tell you what the general deflections are like.
The most extreme strut tower deflection occurs under hard braking. The strut towers move towards the firewall. There is some deflection outwards, but not much. Most people seem to get overly concerned about STBs keeping the camber from changing dynamically. We've seen no evidence that they have any positive effect on this.
From a handling standpoint, I think the main benefits are this: When the strut towers move rearwards or outwards, the toe changes quite a bit. This is going to occur primarily under braking or trail braking, times when you want a stable front end. Is the difference going to drop your lap times 0.5 seconds? I seriously doubt it, but good handling has as much to do with predictability as it does with grip.
From an NVH standpoint, there is definitely an improvement as the center of the firewall is triangulated to the strut towers, which reduces cowl shake. In my opinion, the car also becomes more response during high rates of steering yaw.
Obviously, all of these comments only apply to an STB design that is good enough to actually brace the nodes that it is attached to. I've used STBs that had no effect because they weren't well designed.
I know there are plenty of people on this board that are skeptical. For them, I have one piece of evidence that I think is too difficult to refute. Why would Ford add a $20 part (STB) to the SN95 Mustang if it had no positive benefit to the car? If it didn't have some significant positive benefit, Ford would view this as throwing away $20 of profit in each Mustang made. Why did they stop putting them on? I don't know, but my guess is someone did a cost/benefit buttstuffysis where the increased build and warranty cost of having to work around the STB was weighed against the increased sales volume of Mustangs due to the improved driving experience, and the STB lost. I'm intentionally making this comparison as simple as possible.
__________________
Jack Hidley
Maximum Motorsports Tech Support
Almost finished fabricating, just a few more welds and some more clean up.
(http://i1060.photobucket.com/albums/t456/bodymann/IMG_0323_zpswhhip1yf.jpg) (http://s1060.photobucket.com/user/bodymann/media/IMG_0323_zpswhhip1yf.jpg.html)
(http://i1060.photobucket.com/albums/t456/bodymann/IMG_0324_zpsh3w51uzl.jpg) (http://s1060.photobucket.com/user/bodymann/media/IMG_0324_zpsh3w51uzl.jpg.html)
Title: My 85 TBird
Post by: Aerocoupe on February 04, 2015, 12:28:25 AM
With Jack's 0.02 I would say your design is good to go. After reading what he said and thinking of how the towers would want to move under hard cornering and braking it makes sense. Always learning something new is a great thing!
I like the gussets for the firewall to shock tower struts. How do the struts attach to the firewall? The Maximum brace on my Coupe uses a piece of pipe welded perpendicularly to the struts and a large diameter bolt passes through them and bolts it to the factory tabs on the firewall.
Anyhow, good looking brace man!
Darren
Title: My 85 TBird
Post by: bodyman on February 04, 2015, 12:57:14 AM
Thanks Darren
If MM offered a STB for this application I would have certainly purchased it. I probably have 12 hours in this and it's still not quite done.
It is attached to the firewall at the pinch weld with a 1/2" bolt at that factory tab location. I used a 1/2" bolt because that's what fit nicely thru the hole in that tab. I used a press and just flattened the tube. I looked at many photos of the MM bar while building mine and did notice the perpendicular pipe at that location, but took the easy way out.
Title: My 85 TBird
Post by: bodyman on February 08, 2015, 02:04:32 AM
Spent the last couple of evenings and most of Sat making a air intake box. The front and the side are both open. After painting I will put on some sort of rubber edging and maybe a heat barrier on the inside.
(http://i1060.photobucket.com/albums/t456/bodymann/IMG_0339_zps64dugxdt.jpg) (http://s1060.photobucket.com/user/bodymann/media/IMG_0339_zps64dugxdt.jpg.html)
(http://i1060.photobucket.com/albums/t456/bodymann/IMG_0346_zpsvvfn4d95.jpg) (http://s1060.photobucket.com/user/bodymann/media/IMG_0346_zpsvvfn4d95.jpg.html)
Had to rework the rear lower corner to clear the ac tube
(http://i1060.photobucket.com/albums/t456/bodymann/IMG_0345_zps9l68kdkp.jpg) (http://s1060.photobucket.com/user/bodymann/media/IMG_0345_zps9l68kdkp.jpg.html)
Title: My 85 TBird
Post by: bodyman on February 15, 2015, 08:49:22 PM
Got around to pulling the motor back out this weekend. At the top of the list was the steering shaft and header issues. So I cut into the header tube some more and bent it in thinking that it would be more than enough. Reinstalled the motor and it still touched. Motor came back out and decided that the tube was already restricted too much to go any further. Ended up rerouting the tube to the other side of the steering shaft. This better work.
Crushed tube moved in more than 1/4", still needed at least that much more. Would have ended up less than half the original diameter.
(http://i1060.photobucket.com/albums/t456/bodymann/IMG_0358_zpsas1zqctu.jpg) (http://s1060.photobucket.com/user/bodymann/media/IMG_0358_zpsas1zqctu.jpg.html)
Tacked into place, going to reinstall and check for issues before fully welding
(http://i1060.photobucket.com/albums/t456/bodymann/IMG_0360_zpsb0r2mkyp.jpg) (http://s1060.photobucket.com/user/bodymann/media/IMG_0360_zpsb0r2mkyp.jpg.html)
Title: My 85 TBird
Post by: 1BadBird on February 15, 2015, 08:53:00 PM
Nice work on the air box and headers. May I suggest some Lizard skin thermal barrier on the inside of the box, that way you can paint the outside to match.
Title: My 85 TBird
Post by: bodyman on February 15, 2015, 09:04:49 PM
1BadBird
Thanks. Was thinking about a heat barrier on the inside, will have to check into the Lizard skin, never heard of it.
Did you get back up north yet for that Bird? I am gaining on ya. lol.
Title: My 85 TBird
Post by: bodyman on February 22, 2015, 08:42:01 PM
1 step forward, 3 steps back, or something like that. Reinstalled the motor/trans to find that the steering shaft now hit the tube on the other side. It was the right idea but needed a tighter bend. Ordered a u bend on a tighter radius and it worked out. The steering shaft finally has all kinds of clearance.
(http://i1060.photobucket.com/albums/t456/bodymann/IMG_0396_zpshtr1rfie.jpg) (http://s1060.photobucket.com/user/bodymann/media/IMG_0396_zpshtr1rfie.jpg.html)
Now the 3 steps back. Installed some new ford motor mounts before the last install. Not only did it raise the motor around 1/4" they also moved it rearward. The r mount was slightly bent, and both mounts had the rubber slightly torn, I assume from the accident the donor car was in. You would think a guy that fixes wrecks for a living would know better.  As tight as things are this relocation caused some issues. 1) r header is smashed up against the firewall. 2) The strut tower brace no longer clears the intake tube. 3) The air intake tube no longer reaches the air box. So dropped the motor back out and reamed out the motor mount holes in the k member forward 1/4", should have went  1/8" further. This helped the header to firewall issue some.  To help with the difference in height I am going to increase the spacer between the k member and body from 3/8" to 1/2" or 5/8" if needed. Then will see what else is needed from there.
A two post lift sure would be nice for this but here is how I am getting the motor/trans in and out. I am getting pretty good at it.
(http://i1060.photobucket.com/albums/t456/bodymann/IMG_0356_zpslzvbn9pp.jpg) (http://s1060.photobucket.com/user/bodymann/media/IMG_0356_zpslzvbn9pp.jpg.html)
(http://i1060.photobucket.com/albums/t456/bodymann/IMG_0357_zpsbksdbxeh.jpg) (http://s1060.photobucket.com/user/bodymann/media/IMG_0357_zpsbksdbxeh.jpg.html)
Title: My 85 TBird
Post by: thunderjet302 on February 22, 2015, 09:54:47 PM
Post lift. Fork lift. What ever works ;).
Title: My 85 TBird
Post by: 1BadBird on February 22, 2015, 11:55:46 PM
Quote from: bodyman;444700
Hey Joe, That Lizzard skin is some great stuff. Check out this demo on youtube. https://www.youtube.com/watch?v=_f9z_XlP4dY
 Here's a link http://www.eastwood.com/lizard-skin-ceramic-insulation-2-gallon-pail.html you might find it cheaper somewhere else though
Haven't made it up there yet but I'm working on it. You'll probably pass me up at this rate. lol
Title: My 85 TBird
Post by: bodyman on February 24, 2015, 12:21:14 AM
thunderjet302
Post lift. Fork lift. What ever works .
Yeah, it's a little cumbersome but it gets the job done.
1BadBird
 Here's a link http://www.eastwood.com/lizard-skin-...llon-pail.html you might find it cheaper somewhere else though
Thanks for the links, watched the vid and a few others. May have to give it a try.
Spent some time tonight and shimmed the k member to 5/8", and after shifting the motor in the k member (rotated up on the l side) was able to get the intake tube back under the strut tower brace. I will need to make a 3/8" spacer to get the mass air flow bolted back up to the air intake box. Once I get the dash out I will tackle the header to firewall issue.
Title: My 85 TBird
Post by: bodyman on March 11, 2015, 10:23:20 PM
Have been working on the exhaust now that the motor is setting in it's final resting place. Finished up the mid pipe tonight. My prochamber doesn't look much better than the MAC, but is a little smoother on the inside.
(http://i1060.photobucket.com/albums/t456/bodymann/IMG_0448_zpsm6jt04av.jpg) (http://s1060.photobucket.com/user/bodymann/media/IMG_0448_zpsm6jt04av.jpg.html)
Inside the MAC
(http://i1060.photobucket.com/albums/t456/bodymann/IMG_0402_zpsu1gctz6c.jpg) (http://s1060.photobucket.com/user/bodymann/media/IMG_0402_zpsu1gctz6c.jpg.html)
Inside my version before the end was welded on
(http://i1060.photobucket.com/albums/t456/bodymann/IMG_0403_zpsvb4xjiqk.jpg) (http://s1060.photobucket.com/user/bodymann/media/IMG_0403_zpsvb4xjiqk.jpg.html)
Title: My 85 TBird
Post by: Aerocoupe on March 12, 2015, 08:03:22 AM
That is some terrible welding on the MAC unit for sure!  I'm starting to think their signature "box" is just a cover up for the py welding and lack of quality control.  I think I would rather have yours on my car any day of the week.  What diameter exhaust are you going with and what lers are you going to run?
Darren
Title: My 85 TBird
Post by: bodyman on March 12, 2015, 09:42:22 AM
It's 2 1/2" 304 stainless pipe. Considered going 3" but from what I have read the cobra guys seem to push some pretty big power #'s thru the bolt on 2 1/2" kits.
Have SLP power flow lers (pic on post #81). They are straight thru design and am hoping that they are not to loud. More concerned about in the cabin noise than out the tailpipe.  Going to band clamp them in for easy remove and replace if I don't like them.
Title: My 85 TBird
Post by: Clayton on June 29, 2015, 11:39:15 PM
Any updates on this project?
Title: My 85 TBird
Post by: bodyman on June 30, 2015, 10:22:08 AM
Nothing to update on the bird. Seems I can never focus on one project at a time. Have been getting things ready for the SHO wagon swap, revamped one shop hoist and since it turned out well going to do the other. Also working on a different wrecker chassis to replace the 85 F350, frame is about rusted out in a few places, cracking in others.
The hoist revamp will make it so I can get the drivetrain out of the bird without having to use the fork lift. Also makes it much easier to get to the lift points of everything else. Post 131 shows what the hoist did look like.
(http://i1060.photobucket.com/albums/t456/bodymann/IMG_0721_zpsrzkgzcpm.jpg) (http://s1060.photobucket.com/user/bodymann/media/IMG_0721_zpsrzkgzcpm.jpg.html)
 (http://i1060.photobucket.com/albums/t456/bodymann/IMG_0735_zpsyrszeq1l.jpg) (http://s1060.photobucket.com/user/bodymann/media/IMG_0735_zpsyrszeq1l.jpg.html)
(http://i1060.photobucket.com/albums/t456/bodymann/IMG_0751_zpsv5sg95fy.jpg) (http://s1060.photobucket.com/user/bodymann/media/IMG_0751_zpsv5sg95fy.jpg.html)
Title: My 85 TBird
Post by: Aerocoupe on December 12, 2017, 04:37:58 PM
So its been 2-1/2 years since an update on this.  Did you start another thread or did it die on a vine at some point?  I hope not as this was shaping up to be one hell of a car.
Title: My 85 TBird
Post by: bodyman on December 12, 2017, 07:48:31 PM
Aerocoupe
2 1/2 years...man time flies. It’s still in the works, been waiting for some major progress to update but here is how it sits today. Been working to get the sheet metal fit, I have a few left fenders to choose from and of course the one that needs the most work fits.
Also have been working on finishing up the exhaust. Which also means some rear bumper work. When I did the car the first time 23 years ago I ran supertrap lers out the rear bumper cover. I have a different cover but I think I’m going to go with the tips through again.
Title: My 85 TBird
Post by: bodyman on December 12, 2017, 07:56:06 PM
More photos
Title: My 85 TBird
Post by: 86caprirs on December 16, 2017, 07:32:39 AM
Great build. Nice to see a Terminator in a Thunderbird. Looks like home in there.
Title: My 85 TBird
Post by: bodyman on March 04, 2018, 11:32:54 PM
86caprirs
Thanks.
Little bit of progress. Finally finished up the exhaust and almost have the bumper covers ready for primer.
 Front cover in the blast cabinet. Used 80 grit on a 6” DA to strip as much as possible and sand blasted the hard to sand areas, the sand in cabinet is pretty worn out so wasn’t too aggressive.
There were already 4.5” holes in the rear cover from running super trap lers thru it back in the day. I used some s pieces of bumper cover so that I could add a lip to give the holes a finished off look. I used a 4” outside diameter pipe to keep the pieces in place while plastic welding around the outside. Then welded around the inside and ground the outside down and v grooved and rewelded.
Finished off with 3M 05887
Tips are 3.5” dual wall.
Also reworked the bumper end mods so they fit the quarter and fenders a bit better.
Title: My 85 TBird
Post by: Gydyup on March 05, 2018, 11:36:56 AM
The Coyote fit in there without notching the towers?
Title: My 85 TBird
Post by: bodyman on March 05, 2018, 04:28:20 PM
Gydyup
It's a DOHC 4.6 but yes it fits, there should be no issues with the strut towers for the coyote either. I moved the tops of my strut towers inward about an inch so I could relocate the camber caster plates inward for the 13" FLCA's to get the 275's tucked under the fenders. I did have to cut out the sway bar mounts and relocate them to under the rails.
Title: My 85 TBird
Post by: Drewstang on March 06, 2018, 03:23:07 AM
How thin is the material on the bumpers where it meets the fenders and quarters? I've always wanted to shave them like you did.
Title: My 85 TBird
Post by: Gydyup on March 06, 2018, 07:36:19 AM
Did you fab up and weld the UCA tabs onto the 9 inch?  Ive got the housing I took out of my Mustang when I shortened it some more. Its 50 3/8  to , would like to put it in the bird, and mini tub it. I am not sure about geometry and location for the UCA mounts though, any help on that would be awesome!
Nice work though, mine is going to be a drag car, but I am taking a lot in from your build.  Thanks.
Title: My 85 TBird
Post by: thunderjet302 on March 06, 2018, 04:32:56 PM
Well that's fancy.
Not worried about the exhaust staining the paint?
Title: My 85 TBird
Post by: bodyman on March 06, 2018, 09:48:49 PM
Drewstang
The bumpers are about 1/8” in most places. I cut the ends out, repositioned them, and welded them back in. Then finished them off with plastic repair products. The yellow urethane plastic is fairly easy to work with. I wish I would have went further with what I cut out and started tapering them in sooner. While the bumpers fit flush to the fenders/quarters, they bulge out just a little bit. I could have addressed this when reworking them, but was concerned about durability
Airless plastic welder works well with this type of plastic.
Gydyup
No, I supplied a 9” housing to a guy in West DesMoines, I think it was Rpm Automotive. He had a jig he made using a 8.8 axle. He narrowed it to a fox mustang width and attached the upper and lower control arm mounts. He also set it up to accept the Crown Vic rear disc brakes and set up the center section.
thunderjet302
Well that's fancy.
Not sure fancy was what I was going for. Lol.
As far as heat I’m not sure. The Super Trap lers never discolored the paint, and went with the dual wall tips to help with this issue. I can move the tips out some if it seems like the gases or soot are going to be an issue. I run these tips on my white wagon pretty flush and just touching the rear cover, I get some black soot but nothing that doesn’t wash off.
Title: My 85 TBird
Post by: bodyman on March 06, 2018, 10:11:32 PM
Covers are primed, light coat of 2330 plas-tick adhesion promoter and 3 coats of 33430 primer surfacer with 2350 flex additive. I will let them set a few weeks before block sanding and re-priming.  Axalta products
Title: My 85 TBird
Post by: bootleggers deluxe on March 06, 2018, 11:00:55 PM
.  Looks like i need to take a road trip up to Monona. You['re just over an hour north of me.
Title: My 85 TBird
Post by: bodyman on March 07, 2018, 12:07:38 AM
bootleggers deluxe
Well I’m guessing that puts you about 15 miles south of hwy 20. Come on up I’ll give you the short tour. Not that there’s a long tour.
Title: My 85 TBird
Post by: bootleggers deluxe on March 07, 2018, 12:16:38 AM
I'm in Delhi.  so like 3 miles south of highway 20.  Maybe i'll boogie up some weekend, i'm typically working 6 days a week, so Sundays are fundays for me.
You going down to Wild Wade's swap meet in Des Moines next Sunday??
Title: My 85 TBird
Post by: bodyman on March 07, 2018, 12:29:42 AM
Most likely no, going to bid on an antique tractor down by Kansas City next Wednesday. If I end up with it will be on my way home with it on that day.
Title: My 85 TBird
Post by: Gydyup on March 07, 2018, 09:11:15 AM
Cool, thanks, great stuff...I was gonna bite the bullet and grab a housing from one of the pre fab shops, like 300  to 400 bucks. Havent found anyone around here with the jig, but will keep looking. I will need to swap bearings ends from small to large and I know that usually costs me a couple hundred for narrow and bearing swap...so pre fab maybe just as economical.
Title: My 85 TBird
Post by: Drewstang on March 10, 2018, 03:55:26 AM
Wow, very nice work on those. I need to pickup one of those older plastic welders. My Harbor Freight is not very good for this type of work. Do you have any tips for working with wavy covers? My 03 Marauder has the yellow urethane and the rear cover is wavy on the sides and the paint has spider web cracks. I tried to redo the front using some Metal Kote filler but now the paint is popping off the filler.
Title: My 85 TBird
Post by: bodyman on March 10, 2018, 09:50:48 PM
Drewstang
Heating them up and pushing out and in where needed is about the only way. I use a couple of body dollies and spoons to "work" the plastic around when its warm, then hold it there until it cools down. I wouldn't attempt to do this unless you plan on repainting the cover, more than likely to get things hot enough to move you are going to burn the paint. I rarely fix bumper covers here at the shop, it has to have just very minor damage or it gets replaced. More often than not you end up with more labor in fixing and prepping than the cost of a new one. Your Marauder rear cover is about $1350 though, so it may be worth putting some time into.
By no means are my covers going to be what I would call straight, maybe it's possible to get them there, but to me would be an exercise in futility.
This is the heat gun I use at the shop.
http://www.autobodydepot.com/MRA-HG501A.html#.WqST7bmWy5g
Title: My 85 TBird
Post by: Gydyup on March 13, 2018, 07:51:50 AM
thanks on the plastic work, wondering about that myself.  I used a good old Wagner heat gun to strip my Mustang...worked great...maybe not the best for a dedicated shop, but got the job done for a lot less...
Title: My 85 TBird
Post by: Drewstang on March 21, 2018, 05:19:13 AM
Quote from: bodyman;464917
I appreciate the info, I hate asking about bodywork tips and tricks. I knew the rear covers were expensive, I just had to replace the front cover, header panel, grille, and impact absorber last year. I was an estimator for 3 years, and took a break but looks like I'm going back into the business as a shop manager.
Title: My 85 TBird
Post by: bodyman on June 11, 2018, 11:23:40 PM
Some body work photos. Decided to use the header panel from my parts car, too many broken mounts on original. Yellowish product is a sprayable polyester filler. Both fenders and header are ready for primer surfacer.
Title: My 85 TBird
Post by: bodyman on January 13, 2019, 09:25:28 PM
Found some ambition and made some progress the last couple of weeks. Stripped it back down to the shell and finished welding and grinding on the modifications. Needed a way to move it around so made some dollies that mount to the bumper supports. Did a little body work on the strut towers and cowl, and today rolled it out and blasted the engine compartment. Would of liked to blast some other areas but between running out of daylight and fogging up the helmet lens it was getting hard to see. Then back into the shop to warm up and spray a coat of etch primer so it doesn’t flash rust.
Title: My 85 TBird
Post by: Mikey97D on January 14, 2019, 08:04:52 AM
Wow!  That looks good.
Title: My 85 TBird
Post by: CougarSE on January 14, 2019, 03:11:26 PM
Fun project, glad to see progress forward!
Title: My 85 TBird
Post by: thunderjet302 on January 14, 2019, 03:16:06 PM
Good to see it's moving again!
Title: My 85 TBird
Post by: bodyman on January 14, 2019, 08:59:52 PM
Thanks guys.
Today while jambing parts I sprayed a couple of blanks, one code E4 (vermillion)and one PQ (race red). I like them both better than the viper red, but I’m pretty sure it’s going to be race red, the brighter of the two.
Title: My 85 TBird
Post by: Tbird232ci on January 17, 2019, 05:36:04 AM
So, seeing as you're from Iowa, I would choose Vermillion Red, but that's just me.
Title: My 85 TBird
Post by: bodyman on January 17, 2019, 06:09:46 PM
Tbird232ci
Ok I’ll bite, what’s Iowa have to do with Vermillion Red?
Title: My 85 TBird
Post by: Tbird232ci on January 18, 2019, 05:47:22 AM
It's a Slipknot reference. They're from Iowa and have a song called Vermillion.
Sadly, it's the only thing I know about Iowa.
Title: My 85 TBird
Post by: EricCoolCats on January 18, 2019, 09:18:16 AM
Quote from: Tbird232ci;468534
Part 1 or 2? ;) :mullet:
Title: My 85 TBird
Post by: thunderjet302 on January 18, 2019, 11:51:59 AM
Quote from: Tbird232ci;468545
Iowa had a battleship class named after it: https://en.wikipedia.org/wiki/Iowa-class_battleship
Now you know 2 things about Iowa.
Title: My 85 TBird
Post by: Tbird232ci on January 19, 2019, 05:43:26 AM
Quote from: EricCoolCats;468546
<3
Quote from: thunderjet302;468550
I think my fact about Slipknot was more fascinating.
Title: My 85 TBird
Post by: bodyman on January 20, 2019, 08:21:49 PM
AMTbird232ci
Quote Originally Posted by EricCoolCats  View Post
Part 1 or 2?
<3
Quote Originally Posted by thunderjet302  View Post
Iowa had a battleship class named after it: https://en.wikipedia.org/wiki/Iowa-class_battleship (https://en.wikipedia.org/wiki/Iowa-class_battleship)
I would have never got the Slipknot reference, Willie, Waylon, and Johnny are more my speed.
https://medium.com/iowa-history/iowa-a-history-as-a-first-in-the-nation-state-a4bf7c911a58 (https://medium.com/iowa-history/iowa-a-history-as-a-first-in-the-nation-state-a4bf7c911a58) For some “fascinating Iowa facts”
Last week got the headers sandblasted, sprayed with a coat of etch, and sent off to Swain Tech for coating. Also more filling and sanding in the engine bay. The cowl and front of the strut towers got block sanded, the rest just used a 6” DA to smooth out grinding marks from welding holes up. Engine bay is close to being ready for more priming, but going to wait until the rest of the tub is ready and prime it all at once, hopefully in a couple of weeks.
Title: My 85 TBird
Post by: bodyman on February 10, 2019, 12:14:48 AM
Got all the jambs, rockers, and lower quarters stripped over the past couple weeks. Also reworked a few areas, patched one small rust thru on the driver floor, and metal bonded the spacers for the k member to the rails. Today got everything wiped down, masked up, and primed. Etch primed all the bare metal and prior etched areas, then 2-3 coats of primer surfacer depending on the area. Now it’s let it cure a week or so, block sand and re-prime, then probably repeat that one more time.
Title: Re: My 85 TBird
Post by: bodyman on March 07, 2019, 11:05:49 PM
Still moving forward. Round one of block sanding finished up tonight, hopefully re-prime this weekend. Seam sealed a few spots that show so they can get some primer. Headers are back from Swaintech, got some blue valve covers, and rounding up everything to get the brakes plumbed.
Post by: Vintage on March 08, 2019, 07:23:23 AM
 :bowdown:   Nice work!  I almost hate to ask, but how many labor hours would you estimate you have in stripping and prepping so far?  I guess throw the disassemble time in with it, or not.
Post by: Mikey97D on March 08, 2019, 08:28:31 AM
Looks great.  Thank you for the updates.
Post by: bodyman on March 08, 2019, 06:33:47 PM
I would guess since the second week in January I've got about 80 hours in on it. Stripping the jambs was pretty tedious to say the least. I would have liked to sandblast most of those areas, would have been ten times faster, the weather just did not permit it. I was lucky to get the engine bay blasted when I did.
It's getting there. Thanks for following along.
Post by: bodyman on March 13, 2019, 10:10:40 PM
I did get the shell re-primed last weekend. The engine compartment is ready to sand for paint, and possibly the roof. The quarters and rockers will get one more block sand and re-prime for sure. I also dug out the deck lid and it is about ready for primer. The previous owner sprayed the inside of the original deck lid full of some kind of foam for his subs, must have added 20 pounds to it.
Any bare metal got some etch prime spotted in
Goofy had to go
Post by: Chuck W on March 13, 2019, 10:57:27 PM
Goofy had to go
(http://i68.tinypic.com/6t0cc6.jpg)
I have no words...
Post by: Mikey97D on March 14, 2019, 09:12:44 AM
I've seen that trunk lid mural before.  I can't remember where and maybe in a past life but I have definitely  seen that somewhere before.
Post by: Aerocoupe on March 16, 2019, 02:44:04 PM
Holy shiznit...I’ve seen some murals before but that was just, well bad. You did the 80’s a favor by deleting that “art”.
I’m gonna go to hell because it was probably something very meaningful to the past owner. Hell here I come...it was aweful.
Post by: bodyman on March 18, 2019, 10:39:35 PM
I have been trying to remember just where I found that deck lid. I am pretty sure I picked it up 20 + years ago when I set out to do this the first time. It's possible I posted a pick of it somewhere back then.
Saturday afternoon started with lightly block sanding the roof. All went well and its ready to sand for paint. Then blocked the quarters and rockers and  finished up the filler work on the deck lid and hood. Sunday afternoon got everything cleaned up, masked, and in primer. Now the shell is ready to sand for paint, but a few things to do before that can be done.  I will need to reinstall the rear end and motor/trans. I ended up getting some braided rear brake hoses and need to relocate where the rear brake hose mounts to the body and where they will meet the hard lines on the axle. I also bought a Killer Chiller for the intercooler system and want to mount and route the hoses for that.  While I have all that back in going to bend up and fit the hard brake lines. Then before the engine compartment gets paint I want to get the underside cleaned up, painted, and undercoated.
Post by: Aerocoupe on March 19, 2019, 02:17:30 PM
Have you got the doors, fenders, header panel, and bumper wraps all ready for paint or will those be done after the body, hood and trunk lid?
Post by: bodyman on March 19, 2019, 03:09:47 PM
Those will be done after. As time allows I may be able to whittle away at some more of the body work.  The bumper covers are in primer, but need to be sanded and re-primed a time or two, as does the hood and deck lid.  The fenders and header are pretty much ready for primer. The doors and spoiler need more serious attention. Right now my main goal is to get the engine compartment in paint and get the drivetrain/suspension installed for the last time.
Post by: Aerocoupe on March 19, 2019, 05:42:43 PM
Oh man, you have got a lot of it knocked out then.  Great work and thanks for sharing the project.
Post by: bodyman on March 21, 2019, 11:09:06 PM
Last night was able to get the motor/trans/k member installed. Tonight found a spot and mounted the Killer Chiller and routed the a/c lines to it. I wanted to mount it behind the bumper rebar, but the heat exchanger was in the way so had to come up with plan B. Ended up behind the cold air intake mods. I made sure to test fit the fender and fender inner liner and everything clears ok.
First had to remove a little bracket so it would sit somewhat flush. A finger belt grinder works well to remove spot welds if you never intend to reinstall what's being removed.
The K/C came with a bracket to hold it and just needed a way to hold that to the body. Welded on 3 studs to the back side and used 2 holes that were there and made a 3rd where I thought it needed it.
That upper little tab is a bracket for the air cleaner cover, so all of these fasteners will be hidden behind that.
The ac lines were also supplied in with the kit, just needed to cut the ends to length and crimp the clamps. The fire wall connection was correct for the 85 bird, but I ended up using the line I had originally modified because it cleared the valve and coil covers better. Now it just needs a few feet of heater hoses and that little project is done.
Post by: Aerocoupe on June 25, 2019, 05:14:35 PM
Been a couple months and was wondering if you had any spare time to work on it?
Post by: bodyman on June 26, 2019, 12:26:43 AM
Things came to an abrupt halt not long after my last post. Had some machinery and tractor repairs to do for spring planting for my Dad, and then my old Case tractor hobby has been getting in the way.
Post by: Tbird232ci on July 03, 2019, 04:37:46 AM
Tell me more about this tractor hobby. We had a guy selling a 50's Farmall tractor and I wanted it badly...for no reason.
Post by: bodyman on January 02, 2020, 12:32:09 AM
Well it’s been awhile since I worked on the bird or looked at this thread. Apparently tinypic is no longer so I spent some time removing the bad links and getting some photos attached. Relocated the brake line mounts on the rear axle and bent some lines up today.
Post by: bodyman on January 03, 2020, 11:40:54 PM
More brake line bending. Fronts are done, rear still needs some work. I have to move the mount on the rear diff back a couple of inches, when all the way up the hose hits the body.
Post by: BCA on January 04, 2020, 10:45:24 AM
Nice work.
Have you considered putting a 45° fitting on the rear diff connection?
Post by: bodyman on January 04, 2020, 02:14:27 PM
Nice work.
Thank you.
I did not.  I think moving it rear ward is my best option, it will allow the mount for the hard line connection to be up above the diff and out of the way, but I will have to make some new lines, which may be needed anyway. After getting the axle back in the car I’m now concerned about exhaust pipe clearance with the brake caliper hose mounts.
Post by: bodyman on January 05, 2020, 03:30:33 PM
Made the mods to the hose mount and found a spot for the hard line mount that allowed for the hose to flex, it’s tight up there when the axle is all the way up. If I could go back 20 years I would tell myself to just use an 8.8.  After closer inspection the exhaust won’t be an issue with the axle hard line mounts, but the springs will be. Shouldn’t take much to get those moved around a bit.  Finished plumbing the brake lines on the body, so I think it’s ready to take back apart and start getting the underside cleaned up and ready for paint/undercoating.
Post by: bodyman on January 06, 2020, 11:22:29 PM
With the help of my brother and a couple of forklifts was able to give the bird some legs tonight. A rotisserie would be nice but this will have to do.
Post by: Chuck W on January 07, 2020, 06:49:06 AM
Oof! That is messy overhead work.
Post by: bodyman on January 07, 2020, 11:10:12 PM
Oof Indeed! Did some power washing this evening. My attempt at staying dry was futile, but it cleaned up pretty good. Planning on some spot sand blasting and refinishing before undercoating. Might get started on that this weekend.
Post by: Aerocoupe on January 08, 2020, 07:56:37 AM
Before you get crazy on the undercoating I would suggest that you tie the rear of the front subframe into the subframe connector.  This is how my Global West units are which those look very similar to.  Believe it was just angle iron 1/8" thick and the width was what was close to the width of the subframes by about 4" long.
https://www.foxtbirdcougarforums.com/index.php?action=dlattach;sa=tmpattach;attach=post_tmp_1511_998bcc970ca2d1be625b73b9033cbaf2;topic=33763
Post by: bodyman on January 08, 2020, 12:51:53 PM
Thanks for the heads up on this. I was using your photos back when I built those, it’s been so long I don’t know if I forgot to add them or if I even noticed they were there.
Post by: Aerocoupe on January 08, 2020, 04:51:01 PM
You bet.  My thinking is it just keeps the subframe connector from deflecting thus stiffening the car a little more by tying it to the rear of the front subframe.
Did you give any thought to putting in upper subframes like the ones Griggs Racing has?  I have them in both my Fox body cars and that is all the black paint you see on the bottom of the floor pan along the front subframe and around the bulk heads of the rear subframes from the welding burning the paint off.  I have the drawings for those as well.
Post by: bodyman on January 09, 2020, 01:02:28 AM
I have considered them, I think I even messaged you a time or two about them. You may have sent me the plans, I’ll have to check my shop emails. How bad am I going to regret not having them? Did you have the global west connectors before the Griggs, if so how noticeable was the difference?
Post by: Aerocoupe on January 09, 2020, 10:47:14 AM
The difference is huge. I had the Global West Units in my car for several years before I added the uppers. Added the uppers and ran the car with them for a couple of years. The car is so stiff chassis wise you can jack the car up on the driver front corner and pick that tire up along with the passenger front and the driver rear and the doors will open and close. For reference it did not feel like the car got any stiffer with the welded in six point cage.  Realize I also have the torque boxes welded up and tied into the rear bulk head with additional plate.  Saw this in an old MM&FF magazine article years ago and did it. I think I have that article scanned and can send that to you.
On a side note the ride improved with the subframe connectors installed.
Post by: bodyman on January 09, 2020, 11:29:04 PM
I figured as much. Back in the spring of 2018 you sent me the info on those. I’d like to take a look at that other article, I’ll send you an email if it’s the same as it was when you sent the other info.
I kept talking myself out of installing them because I didn’t want to cut up the floor, but with everything else I’ve had to cut up I really don’t know why.  I either measured from the wrong spot or they are wrong for the 85. Should have been an inch shorter.
Post by: BCA on January 10, 2020, 07:19:20 PM
With the uppers installed, is it still possible to retain fully functioning power seats?
Post by: Aerocoupe on January 10, 2020, 08:50:39 PM
I would say it would be tight to a no go but I’m not sure where things hang down and where on a power seat.
Grigg’s website does say that on ‘94+ street driven Mustangs you will have to run a manual seat track on the driver side or modify the upper subframe tube to clear the power track. Might suggest the Fox style will clear it. I do know the lower seat frame just about touches the upper subframe tube when all the way back with the seat track bolted to the rear seat of holes on the lower seat frame of a Fox Mustang seat on a manual 83 Bird seat track.
Post by: BCA on January 10, 2020, 10:01:57 PM
Thanks.
Will probably just have to bolt my seat back in, put some power to it and do some measuring to see how much clearance there and see what is possible. I have a friend who is an amazing fabricator and I've always considered doing proper "through the floor" sub frame connectors and with the interior currently gutted, now is the time.
Post by: Aerocoupe on January 11, 2020, 05:36:53 PM
So I looked through all my  (electronic and physical copies) and cannot locate that article in MM&FF where they welded up the torque boxes.  I followed the article on welding them up on my Bird but for the Coupe I just welded everything up that was a seam.  The Coupe was welded up back in 2000 has seen waaaay more torture than the Bird ever has and to this day zero issues.
I would just weld up everything where the parts were spot welded together and if I would have know these existed I would have put them on my Coupe:
https://www.ebay.com/i/191676321000?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=191676321000&targetid=474173633709&device=c&mktype=pla&googleloc=1024240&poi=&campaignid=6469750549&mkgroupid=79220335322&rlsatarget=pla-474173633709&abcId=1141176&merchantid=6296724&gclid=EAIaIQobChMIuNm3_s385gIVs41bCh2tTAbQEAQYBCABEgKi7PD_BwE
Post by: bodyman on January 11, 2020, 11:47:04 PM
Thanks for looking.  I think I remember reading somewhere from Jack Hidley that if you keep the correct RUCA  in place there was no need for all that welding and reinforcement back there. Most A/M RUCA don’t flex like the stocks and end up pulling the body apart. So not sure what I’m going to do there yet.
Got started on the upper subframe connectors this evening. I remember another reason I kept talking myself out of installing them, welding on this bird is a pain in the ass.
Post by: Aerocoupe on January 12, 2020, 11:44:27 AM
So Jack is a very smart guy but I’m running a full MM setup with panhard bar and torque arm in my Coupe and do you think any of it is bolted in? The answer is no sir. It literally takes an hour per side to weld up the torque boxes. The USF and LSF connectors do nothing to strengthen these areas. With the stiffening of the chassis more power will he directed to the place of least strength so my suggestion would be to weld ‘em up and then not have to deal with it later. Good insurance if you ask me.
The uppers look great man!! Keep pushing through as they are so worth it.
Post by: bodyman on January 18, 2020, 11:47:54 PM
This is from Maximum Motorsports Website
Stop Torque-box Damage
Torque-box damage is often blamed on "too much power". Wrong! It is usually the result of metal fatigue caused by a poor rear lower control arm bushing design.
Not saying it wouldn’t be good insurance while I’m at it.
Finished up the top side of the USF connectors.
Post by: Aerocoupe on January 19, 2020, 10:04:42 AM
Looks good!!
Post by: bodyman on January 19, 2020, 08:40:08 PM
Got the car back up on the tall stands today for some more welding. Made the brackets to connect the rear subframe to the bulkheads of the USF connectors. Also tied the rear of the front subframe to the LSF connectors. Then finished welding the floor pans to the USF where needed.
Post by: Chuck W on January 20, 2020, 07:46:25 AM
I really should consider some of these through-floor SFC's and take the cage out of the car.
The wife gives me a nasty look every time I suggest it, though. :giggle:
Post by: bodyman on January 20, 2020, 04:43:31 PM
If she’s against taking out the cage leave it in and add the SFC’s.  :toothless:
Post by: bodyman on January 23, 2020, 11:08:47 PM
Got a few things done this week. Built a whatchamacallit to use with the engine hoist to lift the engine off the k member. Then I could get the headers bolted up. Used Stage 8 header bolts and locks with ford exhaust gaskets. One issue with having to cut one bolt so short to get installed that there was not enough thread engagement into the head and it pulled the threads out. So I ended up using a stud and metal lock nut in that location. It only messed up the threads about 1/4” into the head and I added some threads to the stud so there is at least an inch of good thread engagement. Tonight I washed off 8 years of dust.
Post by: Aerocoupe on January 24, 2020, 08:47:34 AM
Would you hurry up and get that  motor started already????  That is just engine bay candy right there...who doesn't love a Terminator motor?
Post by: bodyman on January 26, 2020, 07:46:05 PM
Got the underside in paint this weekend. Saturday afternoon I did some masking to protect things and try to keep some sand out of it. About 4 o’clock a friend stopped in to help me get it back up on stands in the booth, then the blasting started. The plan was to hit a few bad spots and the areas that were affected by welding. Once the bad spots were done the rest of it didn’t look so good so I just kept at till I couldn’t take anymore, that was about 9:30.
(https://i1060.photobucket.com/albums/t456/bodymann/Thunderbird/83544B0E-014A-4F85-83E1-A2DC265979A2_zpsvm2jfe4m.jpeg) (https://s1060.photobucket.com/user/bodymann/media/Thunderbird/83544B0E-014A-4F85-83E1-A2DC265979A2_zpsvm2jfe4m.jpeg.html)
(https://i1060.photobucket.com/albums/t456/bodymann/Thunderbird/58404E95-2F61-4153-B7A2-F91E8E06559D_zpsz070ezt5.jpeg) (http://s1060.photobucket.com/user/bodymann/media/Thunderbird/58404E95-2F61-4153-B7A2-F91E8E06559D_zpsz070ezt5.jpeg.html)
This morning I cleaned up the mess and blew as much sand out of it as I could. After dinner I sprayed it with etch, sealer, and some single stage black. If there is ever a next time doing an underside there will be a rotisserie involved.
(https://i1060.photobucket.com/albums/t456/bodymann/Thunderbird/3942C136-1D50-437D-8284-7BF7BC4556BB_zpseslll0ei.jpeg) (http://s1060.photobucket.com/user/bodymann/media/Thunderbird/3942C136-1D50-437D-8284-7BF7BC4556BB_zpseslll0ei.jpeg.html)
(https://i1060.photobucket.com/albums/t456/bodymann/Thunderbird/4F9141D7-31B6-41C9-8B7B-C048C57816D4_zpsa2vwgg58.jpeg) (http://s1060.photobucket.com/user/bodymann/media/Thunderbird/4F9141D7-31B6-41C9-8B7B-C048C57816D4_zpsa2vwgg58.jpeg.html)
(https://i1060.photobucket.com/albums/t456/bodymann/Thunderbird/DE8C4F63-2B66-40A3-8E6A-71C1E2C6B9FD_zpsbyldp6xb.jpeg) (http://s1060.photobucket.com/user/bodymann/media/Thunderbird/DE8C4F63-2B66-40A3-8E6A-71C1E2C6B9FD_zpsbyldp6xb.jpeg.html)
(https://i1060.photobucket.com/albums/t456/bodymann/Thunderbird/ED2974BE-183E-4829-A16B-D1CFD93A8A34_zpsozfexyqd.jpeg) (http://s1060.photobucket.com/user/bodymann/media/Thunderbird/ED2974BE-183E-4829-A16B-D1CFD93A8A34_zpsozfexyqd.jpeg.html)
Post by: Aerocoupe on January 26, 2020, 11:22:07 PM
I can only imagine how that overhead work sucked and then combine it with sandblasting. Looks really good and you will be happy you went the extra mile.
That is the one thing I regret not doing when I had my car painted in ‘98 was doing the underside. Wasn’t an issue then but now I’m seeing very small areas of surface rust. Only a few but that’s how it starts. Having the car in the shop year around and not driving it in wet weather has helped.
Post by: Chuck W on January 27, 2020, 09:02:56 AM
Man, oh, man, that looks nice.
Kudos on going the extra mile there. I'm not sure I'd want to go through with that.
Post by: mcb82gt on January 27, 2020, 09:35:31 AM
More than nice!  That is friggin beautiful.
Post by: bodyman on January 27, 2020, 11:09:02 AM
Thanks guys. It looks better in the pics than it is, some sand got in it here and there and it’s a little fuzzy and dry in some spots, but it should keep it protected. Most of it is going to get under coated anyway. The worst part was holding the sandblasting nozzle at or above shoulder height for so long.  I taped my dewalt work light to it, which now needs a new lens, so I could see what I was doing which made it even heavier. I hope to get it under coated later this week so I can get it down and start prepping the engine bay for paint.
Post by: 85CougarCobra on January 27, 2020, 12:00:05 PM
Wow, that looks awesome.  Nice job!
Post by: thunderjet302 on January 27, 2020, 02:35:34 PM
Sounds like it was a PITA but the results were worth it. Looks great.
Post by: bodyman on February 02, 2020, 12:12:59 AM
Pulled the supercharger off to get the coolant crossover pipe out to weld a fitting in for the head cooling mod. Also installing all new idler pulleys, belts, and a 2.8” pulley on the supercharger.
(https://i1060.photobucket.com/albums/t456/bodymann/Thunderbird/DDAD74A0-34F9-41B5-915E-C1B653342270_zps01prt5yy.jpeg) (https://s1060.photobucket.com/user/bodymann/media/Thunderbird/DDAD74A0-34F9-41B5-915E-C1B653342270_zps01prt5yy.jpeg.html)
This evening got the undercoating sprayed.
(https://i1060.photobucket.com/albums/t456/bodymann/Thunderbird/5840D20F-D1FD-45AE-B998-CB6A12DE6159_zpsoxrvgter.jpeg) (https://s1060.photobucket.com/user/bodymann/media/Thunderbird/5840D20F-D1FD-45AE-B998-CB6A12DE6159_zpsoxrvgter.jpeg.html)
(https://i1060.photobucket.com/albums/t456/bodymann/Thunderbird/9E968E14-0923-4DF5-80CC-4C0F58E24E2E_zpslnzbdjrb.jpeg) (https://s1060.photobucket.com/user/bodymann/media/Thunderbird/9E968E14-0923-4DF5-80CC-4C0F58E24E2E_zpslnzbdjrb.jpeg.html)
(https://i1060.photobucket.com/albums/t456/bodymann/Thunderbird/AD7D74FC-3C67-41BA-B29E-28B8109D96E5_zpssvks2v8l.jpeg) (https://s1060.photobucket.com/user/bodymann/media/Thunderbird/AD7D74FC-3C67-41BA-B29E-28B8109D96E5_zpssvks2v8l.jpeg.html)
Post by: Mrjody on February 02, 2020, 08:32:58 AM
Awesome man! Love what you're doing here
Post by: bodyman on February 09, 2020, 09:14:07 PM
Thanks!
Most of Saturday was spent prepping the engine bay and then a couple hours sand blasting the k member and some other misc brackets. This morning  I hung up the blasted parts, masked up for paint, and did a little seam sealing. This afternoon did some spraying.
Ready to go.
(https://i1060.photobucket.com/albums/t456/bodymann/Thunderbird/B58F350D-3E1F-4A1D-B03E-B5F35FAF6BE6_zpsgp4lhhlq.jpeg) (https://s1060.photobucket.com/user/bodymann/media/Thunderbird/B58F350D-3E1F-4A1D-B03E-B5F35FAF6BE6_zpsgp4lhhlq.jpeg.html)
Etch primer
(https://i1060.photobucket.com/albums/t456/bodymann/Thunderbird/AB075858-84F5-4BDA-980C-84BFE66A05BC_zpsgojpwimy.jpeg) (https://s1060.photobucket.com/user/bodymann/media/Thunderbird/AB075858-84F5-4BDA-980C-84BFE66A05BC_zpsgojpwimy.jpeg.html)
Sealer
(https://i1060.photobucket.com/albums/t456/bodymann/Thunderbird/63DD1BCB-0E5C-4DD1-A321-3C5F22B6B0A7_zpsgb7vld9v.jpeg) (https://s1060.photobucket.com/user/bodymann/media/Thunderbird/63DD1BCB-0E5C-4DD1-A321-3C5F22B6B0A7_zpsgb7vld9v.jpeg.html)
Ford Race Red
(https://i1060.photobucket.com/albums/t456/bodymann/Thunderbird/E40F7062-77FE-41BE-86B2-A2B608418280_zpsgaoexxd7.jpeg) (https://s1060.photobucket.com/user/bodymann/media/Thunderbird/E40F7062-77FE-41BE-86B2-A2B608418280_zpsgaoexxd7.jpeg.html)
(https://i1060.photobucket.com/albums/t456/bodymann/Thunderbird/A0BFC52B-FDD1-48E1-9E05-6C133C3E4877_zpswyjefyzc.jpeg) (https://s1060.photobucket.com/user/bodymann/media/Thunderbird/A0BFC52B-FDD1-48E1-9E05-6C133C3E4877_zpswyjefyzc.jpeg.html)
(https://i1060.photobucket.com/albums/t456/bodymann/Thunderbird/6E0B8FB1-943E-4B9C-8B9D-2A159AAFB1C0_zpstlvobc59.jpeg) (https://s1060.photobucket.com/user/bodymann/media/Thunderbird/6E0B8FB1-943E-4B9C-8B9D-2A159AAFB1C0_zpstlvobc59.jpeg.html)
Post by: Aerocoupe on February 09, 2020, 10:51:23 PM
DAAAAAAAMN!!!!  Now you are gonna have a feeding frenzy with all of us wanting to see the whole body with color. Looks fantastic man, you have to be stoked!
Post by: bodyman on February 09, 2020, 11:12:55 PM
Thanks. Stoked for sure. It’s going to be awhile before anymore sheet metal gets color. The plan is to get the drive train in and get her moving under her own power for a change.
Post by: Mikey97D on February 10, 2020, 08:38:53 AM
WOW!
Post by: mcb82gt on February 10, 2020, 10:38:14 AM
SHHHHINEEEEYYY!  WOW!
Post by: Chuck W on February 10, 2020, 10:47:03 AM
Nice work!  :like:
Post by: thunderjet302 on February 10, 2020, 02:57:22 PM
Awesome! Nice work!
Post by: bodyman on February 15, 2020, 01:24:34 PM
Thanks guys.
Thursday night  was able to get the engine/trans/kmember assy bolted in. Friday started getting wiring and things cleaned up and installed. Getting to the point I need to get more stuff painted up before I can go much further.
(https://i1060.photobucket.com/albums/t456/bodymann/Thunderbird/F97F0B38-FA9C-454B-A1F9-2920ADF57181_zpshm7srvhk.jpeg) (https://s1060.photobucket.com/user/bodymann/media/Thunderbird/F97F0B38-FA9C-454B-A1F9-2920ADF57181_zpshm7srvhk.jpeg.html)
Post by: Aerocoupe on February 15, 2020, 02:06:11 PM
Please post a video when you get that Terminator motor fired up.
Post by: bodyman on February 15, 2020, 02:42:44 PM
Will do.
Post by: Clayton on February 15, 2020, 05:55:29 PM
That looks amazing! Hell of a good job man I can't wait to see it finished
Post by: Tbird232ci on February 17, 2020, 07:01:46 AM
I still wish it were Vermilion red...for my own reasons.
That paint laid down so  nicely.
Did you get an NOS washer tank? That has to be the nicest washer tank I've ever seen.
Post by: bodyman on February 17, 2020, 09:43:20 AM
That is indeed a NOS washer tank.
Post by: bodyman on February 23, 2020, 11:15:42 PM
In the process of trying to get the 03 mustang gauges in the bird dash I hacked a bit too much and pretty much destroyed it. That was the main reason for the purchase of the parts car though it’s been useful a couple times already. This weekend I got the parts car pushed in and de-dashed, cleaned up and repaired the wiring from the misadventures of my youth, and swapped it over.
(https://i1060.photobucket.com/albums/t456/bodymann/Thunderbird/C6F8EB30-1CCF-49B1-AD7D-99F844ABF654_zpspdtt7dyc.jpeg) (https://s1060.photobucket.com/user/bodymann/media/Thunderbird/C6F8EB30-1CCF-49B1-AD7D-99F844ABF654_zpspdtt7dyc.jpeg.html)
(https://i1060.photobucket.com/albums/t456/bodymann/Thunderbird/4B41177A-1D3A-4F17-A368-3104D078F970_zpskgbmyrzx.jpeg) (https://s1060.photobucket.com/user/bodymann/media/Thunderbird/4B41177A-1D3A-4F17-A368-3104D078F970_zpskgbmyrzx.jpeg.html)
Post by: bodyman on March 01, 2020, 07:45:31 PM
Making some progress here and there. Have a bunch of new bolts on order, hopefully they start showing up so I can get some suspension parts attached.
Modified the secondary hood catch brace for more room around the inter cooler.
(https://i1060.photobucket.com/albums/t456/bodymann/Thunderbird/783BA3EB-58BF-482D-931D-E7EB9AA10D87_zpsxjcego2j.jpeg) (https://s1060.photobucket.com/user/bodymann/media/Thunderbird/783BA3EB-58BF-482D-931D-E7EB9AA10D87_zpsxjcego2j.jpeg.html)
Making a black out for the instrument cluster
(https://i1060.photobucket.com/albums/t456/bodymann/Thunderbird/4F7D3E75-4EE8-4E58-A6BA-A828C6C31546_zpsygn1dmuk.jpeg) (https://s1060.photobucket.com/user/bodymann/media/Thunderbird/4F7D3E75-4EE8-4E58-A6BA-A828C6C31546_zpsygn1dmuk.jpeg.html)
(https://i1060.photobucket.com/albums/t456/bodymann/Thunderbird/00EF9F49-44DC-4A19-BC34-4D91793C36D6_zpsa5ogrqn5.jpeg) (https://s1060.photobucket.com/user/bodymann/media/Thunderbird/00EF9F49-44DC-4A19-BC34-4D91793C36D6_zpsa5ogrqn5.jpeg.html)
Relocated the rear brake line mount again, third time is the charm.
(https://i1060.photobucket.com/albums/t456/bodymann/Thunderbird/919FBCB6-1798-4831-AC5A-5E975B7C4760_zpselbh57xt.jpeg) (https://s1060.photobucket.com/user/bodymann/media/Thunderbird/919FBCB6-1798-4831-AC5A-5E975B7C4760_zpselbh57xt.jpeg.html)
Painted the rear axle, fuel tank, and a bunch of brackets
(https://i1060.photobucket.com/albums/t456/bodymann/Thunderbird/0B1D80C6-BD7D-4EF1-B6EB-6125BE799114_zpswr7tbrz7.jpeg) (https://s1060.photobucket.com/user/bodymann/media/Thunderbird/0B1D80C6-BD7D-4EF1-B6EB-6125BE799114_zpswr7tbrz7.jpeg.html)
(https://i1060.photobucket.com/albums/t456/bodymann/Thunderbird/14582EB1-3332-484D-97DA-B9F6D5256CE5_zps8qoupufm.jpeg) (https://s1060.photobucket.com/user/bodymann/media/Thunderbird/14582EB1-3332-484D-97DA-B9F6D5256CE5_zps8qoupufm.jpeg.html)
Post by: bodyman on March 15, 2020, 10:33:36 PM
Not much post worthy stuff going on, mostly block sanding and re-priming. Everything I ordered to get the suspension bolted up is not being shipped until some back ordered bolts are available.
Some photos of reworking the spoiler mounts to match the deck lid and level it up. Used some 2” tape on the deck lid so the 3M 8115 would release, and a couple of washers to get the height matched to the other side.
(https://i1060.photobucket.com/albums/t456/bodymann/Thunderbird/11E7376D-7C0F-4ADF-88F8-67BF0795F3E9_zpstbmahxwk.jpeg) (https://s1060.photobucket.com/user/bodymann/media/Thunderbird/11E7376D-7C0F-4ADF-88F8-67BF0795F3E9_zpstbmahxwk.jpeg.html)
(https://i1060.photobucket.com/albums/t456/bodymann/Thunderbird/F7126688-86EA-4ADE-8CBE-17FFD6824E5C_zps6chfgqew.jpeg) (https://s1060.photobucket.com/user/bodymann/media/Thunderbird/F7126688-86EA-4ADE-8CBE-17FFD6824E5C_zps6chfgqew.jpeg.html)
(https://i1060.photobucket.com/albums/t456/bodymann/Thunderbird/6A7775BD-02D4-41E2-BF7B-8C2D0DC46294_zpsokhzu76v.jpeg) (https://s1060.photobucket.com/user/bodymann/media/Thunderbird/6A7775BD-02D4-41E2-BF7B-8C2D0DC46294_zpsokhzu76v.jpeg.html)
(https://i1060.photobucket.com/albums/t456/bodymann/Thunderbird/97C42775-E1E3-471A-8373-8C5D7C1AF93F_zpsqeopjxin.jpeg) (https://s1060.photobucket.com/user/bodymann/media/Thunderbird/97C42775-E1E3-471A-8373-8C5D7C1AF93F_zpsqeopjxin.jpeg.html)
(https://i1060.photobucket.com/albums/t456/bodymann/Thunderbird/C221565E-932D-47DF-92C5-5B13A87A5C49_zps94jckknp.jpeg) (https://s1060.photobucket.com/user/bodymann/media/Thunderbird/C221565E-932D-47DF-92C5-5B13A87A5C49_zps94jckknp.jpeg.html)
(https://i1060.photobucket.com/albums/t456/bodymann/Thunderbird/581BE5A0-F471-4039-8FBB-579DB155E4FA_zps2z7podg8.jpeg) (https://s1060.photobucket.com/user/bodymann/media/Thunderbird/581BE5A0-F471-4039-8FBB-579DB155E4FA_zps2z7podg8.jpeg.html)
Post by: bodyman on December 12, 2024, 07:32:17 PM
Back to working on the bird some. Last week or so got the dash installed and the fuel gauge sender switched over to the correct ohm range for the 03 cluster. Painted up the rebars and a few things for under the hood.  Installed the fuel tank, rear axle, some of the front suspension, and enough other stuff that I was able to get it running again. If I can figure out how to post a vid here I will. Going to try to keep at it enough to get it on its wheels and drivable. Keep running into little things needed to keep forward progress going.
Post by: bodyman on December 12, 2024, 08:12:38 PM
I was worried it was going to be way too loud with the homemade o/r prochamber and the slp powerflo lers, its a bit louder than the vid lets on, but am pleasantly surprised it should be a manageable decibel level.
https://youtu.be/PTSyEulOSpM
Post by: Chuck W on December 13, 2024, 07:12:57 AM
Nice!
It sounds good!
Post by: Mikey97D on December 13, 2024, 07:58:02 AM
Beautiful work!
Sounds great!
Must be very satisfying to hear it run?
Post by: bodyman on December 13, 2024, 07:19:16 PM
Thanks guys. I am pleased enough with the sound, hopefully its quietish in the cabin at cruising speeds.  So very satisfying to hear it run again, haven't fired that motor since Feb of 2013, and never thru the current exhaust. The car has not moved under its own power since the fall of 1998, hoping to change that here in the next week or so.  Got a few more things done today, mounted the front sway bar and got the end link situation figured out, put the drive shaft in, did some plumbing on the intercooler, rerouted the clutch cable and started to make a bracket to hold it out of the way. Also ordered some Linear sanding blocks today for final block sanding, should be here end of next week.
Post by: bodyman on December 18, 2024, 10:55:26 PM
It moves, stops, and stays.
https://youtu.be/BF8LRyRnNuY
Post by: Haystack on December 19, 2024, 02:32:32 AM
That thing is going to be killer when it's done. Looks really good man, and congrats on it moving, big milestone.
Post by: bodyman on December 19, 2024, 10:39:03 AM
Thanks. Still have a long way to go, but it’s so nice that it moves under its own power again.  Before I left the shop last night I moved it to another bay, just because I could.
Post by: bodyman on December 21, 2024, 12:02:21 AM
Hardware to mount coil covers showed up today.
(https://lh3.googleusercontent.com/pw/AP1GczOKA-01dB1mzEtu32smcKkOrYr3mU5x2wCNixElZenIKt1p7-qVj2WJkCyHg3GcyEdImeyWIe1JtSeFHDv9QOHLiEccWGkvGkOe54ZI3FEJueBp3TU=w2400)
(https://lh3.googleusercontent.com/pw/AP1GczNGrJrYDMxNs85RxZqvmTwu5ux_593djpg1MkMvICCnuDOt_eWAYjMP4PQpP0ToIROYVWDKKRND37hRPGfAsp9AZ_0niz_xvbZImhnLvHGhZp-qhyg=w2400)
Post by: gtbird on December 21, 2024, 06:13:38 AM
What’s the tank behind the bumper support?
Final body color to be that red? Looks like the red of my ‘03 Terminator: Torch Red.
 I miss my 88 “Super Coupe”
Post by: bodyman on December 21, 2024, 09:43:34 AM
The tank is to increase the capacity of the intercooler system a bit.  The color is ford code PQ, race red.
Post by: bodyman on December 29, 2024, 10:04:01 PM
Been in body work mode the last week. The Linear sanding blocks and sand paper showed up a couple days late but was worth the wait. For block sanding large flat surfaces I think they would be hard to beat.
Got the doors primed tonight so everything is in primer surfacer except the spoiler. Hood, deck lid, and right fender are ready to sand for paint, as is the chassis. Everything else will need blocked and reprimed a time or two depending how they sand out.
(https://lh3.googleusercontent.com/pw/AP1GczMnGNyEvxy1I2JeBMAWptuY6pXoabHvy_rop9hAYQFEV3Ehjv_IWSUnOjZZB7EplivR1oRjbBkiPcGTLZUXFz_r-UxnAY3gis8Z3BGZ-oaTSzFm-WA=w2400)
(https://lh3.googleusercontent.com/pw/AP1GczMgaFiwU3DFF92HXZL6ftWEzUAVf8kKOPDaMfTx-T8H4XqL7hbYVH0dbEWTBvbiwwCHELYp9PNbkxA7Xv6tWxsudr9zvv1Iycxxoxcw8BHQz_N-kNE=w2400)
Post by: bodyman on January 18, 2025, 02:00:17 PM
Took advantage of the 40 degree day yesterday and sprayed the hood, roof, and deck lid. I’ll be sanding and buffing clear coat the next couple of days. Still have a little bit of bodywork to do on the header, spoiler, and bumper covers. Going to try to get those caught up before painting any more.
(https://lh3.googleusercontent.com/pw/AP1GczOHJ_Tz2_GveSD3enC1i7nsDdUjl9aknCSqrsE3uUBPa794XZO9_NB4j4Yx5b7rvFSNgcamkWbIMWPD09vJjTyYTjfb2ChmWgcGma3PEsvNeKW5xoA=w2400)
Post by: Mikey97D on January 24, 2025, 03:04:11 PM
Those valve covers look phenomenal with the Thunderbird on them.
Hope it stays warm for you.  We've been in a deep freeze in the northeast.
Post by: bodyman on January 24, 2025, 07:44:50 PM
It cooled right down below 0 a couple days after I sprayed and stayed there,  just today getting back to normal with some above normal temps again next week.
My friend that did the instrument cluster milled those coil covers and powder coated everything for me. First time I saw them I told him I was afraid I wouldn’t be able to make the rest of the car worthy of them.
Post by: bodyman on February 07, 2025, 04:59:20 PM
Just a progress photo, quarters, rockers, and jambs painted and buffed.  Working on some window trim and interior stuff. Things have slowed a little but still digging.
(https://lh3.googleusercontent.com/pw/AP1GczMUlEPhAa0SpKoAIKwNfmJSyMBQBrvlt5QAkcU3s0LQPOEw-nzdvg1PUBoAZUI4cMzj1wXEu4oiltHy8d3XE3tDrHQEYhJ06JL5pqNJWzn5wNpik8k=w2400)
Post by: Clayton on March 11, 2025, 07:26:41 PM
I'm so glad  it's getting somewhere. I don't come on the board that much anymore, but when I do I always check to see if you've updated anything.
Looks awesome man!
Post by: bodyman on March 14, 2025, 05:16:24 PM
Looks awesome man!
Thanks!
No real progress since the last update. I am no longer in the auto collision business. I grew very tired of dealing with insurance companies on a daily basis and 4 years ago the opportunity to rent my dads and an uncles farm came up.  It’s that time of year to get my 20 to 40 year old equipment ready to go so the bird will have to wait some more. Hopefully I can keep at it here and there and get it on the road this summer sometime.
Post by: Mikey97D on June 11, 2025, 08:32:42 AM
How is the farm?
Hopefully you get time to drive the car this summer.
Post by: bodyman on June 15, 2025, 01:13:27 AM
How is the farm?
Things are looking pretty good right now, could use some rain in are area.
Have a couple other projects to take care of before I get back to the bird, hopefully they don’t take me too long.
Post by: bodyman on November 25, 2025, 12:19:27 AM
 Back to Bird things.
Carpet showed up today. Got a good start on it. I think I’m going to try and find some close matching carpet to wrap the sub frame connectors with.
In the last week or so painted most of the window trim, installed what I could. Put the deck lid on and fit,  got the wipers working, installed the front turn lamps and a horn, moved the cruise control cancel relay from under the dash to the under hood relay box. The relay clicking was a little loud for inside the cabin. I have the rear glass scheduled to get installed, and I think I found a new windshield, but it’s not in my possession yet.
Next on the list is to redo the headliner and install some interior trim.
(https://lh3.googleusercontent.com/pw/AP1GczMTrEitaoL06PI7Nip49-FCX9EP6oDxabo5PMl8mBhIZF7hD0HInOuf1NYAlhdUsu4HA5b-W_BHDQt0fRE8zA4Kb6goRnLDnBcDvqCK3hCw4t4XYZ0=w2400)
(https://lh3.googleusercontent.com/pw/AP1GczPtTl5rI8_MQtaqxkhZKlzkORJiP7Y-W5Lu-Gg_rwDvihKoEjYQTYcBswfOBi43kAQpeyXbhvv3OKelDB2qofITVjVNfDni50oShpJZeXcmO8efnjY=w2400)
Post by: Chuck W on November 25, 2025, 08:24:10 AM
I think the blackout trim is going to look pretty good on there.
I bet ACC would have the matching carpet you need in a bulk roll.
Post by: bodyman on November 25, 2025, 09:20:01 AM
Yes they do. Thanks!
