Technical => Body/Appearance/Interior => Topic started by: BlackTHUNDA on April 28, 2012, 06:51:56 PM
Title: door doesn't close right
Post by: BlackTHUNDA on April 28, 2012, 06:51:56 PM
So how can I fix this, the driver side door looks open but it's not. It doesn't rattle at all and I can push it in to where it needs to be.
Post by: lakenheath24 on April 28, 2012, 07:11:57 PM
pics?  Can you pull up on the door when its open?  You may need to replace the hinge pins is all.  Check the striker for signs of wear.
Post by: BlackTHUNDA on April 28, 2012, 07:32:36 PM
Quote from: lakenheath24;388287
I cant move the door up, no door sagging. The striker looks in good shape for both sides. Is there a bushing that goes on the striker to allow for a tighter fit?
pics in a bit
Post by: vinnietbird on April 28, 2012, 07:40:05 PM
Yes, a gray plastic bushing.
Post by: daminc on April 28, 2012, 08:16:46 PM
you can buy new striker posts almost anywhere
Post by: vinnietbird on April 28, 2012, 08:27:42 PM
I ended up grabbing a few from a couple of Lincolns at the boneyard.
Post by: vinnietbird on April 28, 2012, 08:33:08 PM
They look like this.............
http://www.ebay.com/itm/Dorman-Help-38445-Door-Striker-Bolt-/290703235463?fits=Model:Thunderbird&hash=item43af435987&item=290703235463&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr
Post by: daminc on April 28, 2012, 08:35:50 PM
ours have the metal tab behind the post though
Post by: vinnietbird on April 28, 2012, 09:41:57 PM
What are you talking about Jerry? The one I posted has that tab.
Pay no attention to the "edit" note at the bottom.
Post by: daminc on April 28, 2012, 09:44:57 PM
lol.... never mind then. I must be seeing things
Post by: BlackTHUNDA on April 28, 2012, 09:50:01 PM
Here's a pic, and thanks for confirming about the bushing on the striker. I'll go visit a local pick a part to see if I can find a good used one. :D
Post by: vinnietbird on April 28, 2012, 10:21:56 PM
Quote from: daminc;388310
That's right you are !!! LOL. LOL.
Post by: vinnietbird on April 28, 2012, 10:23:14 PM
They are on late 90's Lincolns, Crown Vics...... That'll take out the slop. Just look at yours prior to getting one to make sure they are the same. I grabbed a few since the yard owner I go to rarely charges me for little tiny parts like that.
Post by: vinnietbird on April 28, 2012, 10:25:50 PM
I'll check my rolling toolbox tomorrow. If I can find where I have my extras, I can send you one. All I need is your mailing info.
Post by: T-BirdX3 on April 29, 2012, 01:04:09 AM
AutoZone and advance have them for like $8.
Post by: daminc on April 29, 2012, 08:42:25 AM
I think I paid under 20 for 2 new ones
Post by: TOM Renzo on April 29, 2012, 10:00:08 AM
Sometimes the door assembly wont lock in the second position. Make sure you check the door lock mechanism for a double lock. It may have a bad lock assembly. Just saying. Strikers normally wont hold the door that far out unless the bushing is completely gone. He did not post the striker so i cant tell. Just saying.
Post by: vinnietbird on April 29, 2012, 10:46:59 AM
That's true.
Post by: BlackTHUNDA on April 30, 2012, 08:51:19 PM
thanks for all the reply's
It is the striker, there is absolutely no bushing on either side. LOL
Thanks Vin, but I already ordered some. Much appreciated
Post by: sarjxxx on May 01, 2012, 12:54:22 AM
Yes the bushing will help. You should also notice that now when you shut your doors they'll go "CLUNK" and not "CLABLABAPPPPBBT" ;)
