General => General Fox T-Bird/Cougar Discussion => Topic started by: Vito324 on April 22, 2012, 08:42:10 PM
Title: 88 turbo coupe
Post by: Vito324 on April 22, 2012, 08:42:10 PM
I just bought a 88 turbo coupe tbird. I was wondering if any of you knew the wheelbase, and what rearend was in it? I was told it's a limited slip 8.8, and it's 104 inch wheelbase. Just checking to be sure. Thanks in advance.
Post by: Tbird-fanatic on April 22, 2012, 09:02:31 PM
I dont remember the wheel base for sure, but yes the rear end is an 8.8 limited.
Post by: Vito324 on April 22, 2012, 09:13:18 PM
Ok cool, I hear it has a borg warner t5? It had a 3.8 turbo in it too.
Post by: Tbird-fanatic on April 22, 2012, 09:18:15 PM
A Turbo Coupe would be a 2.3 Turbo and it is a T5
Post by: Chuck W on April 22, 2012, 09:32:54 PM
Quote from: Vito324;387526
No, no it doesn't.  2.3T I4.
Wheelbase is 104.4"
Post by: TOM Renzo on April 22, 2012, 10:53:38 PM
It had a turbo 2.3 and the tranny is a WORLD CLASS BORG WARNER T5. And the final drive is an 8.8 ford POSI.
Chuck is correct on the WB and engine. The rear axle is 61 inches wide DISC TO DISC
Post by: Vito324 on April 23, 2012, 10:15:48 AM
Ok, Thanks guys. Just wondering, How much is the T5 worth? I may not sell it.
Post by: Beau on April 23, 2012, 07:25:11 PM
Quote from: TOM Renzo;387537
It had a turbo 2.3 and the tranny is a WORLD CLASS BORG WARNER T5. And the final drive is an 8.8 ford Trac-Lok.
Fixed for ya ;)
To the OP: did you pick it up to resell, or what? Or are you just selling the 2.3 T5?
Post by: Vito324 on April 24, 2012, 09:36:26 AM
Actually, I picked it up to put my stroker 347 in it.
Post by: The Shredder on April 24, 2012, 02:13:07 PM
Nice.  I have completed the swap.  If you have any questions, please let me know.
Post by: Clayton on April 24, 2012, 03:33:48 PM
ahem.... :ttiwwp:
Post by: 1Bad88tbird on April 25, 2012, 12:40:46 AM
I was wondering how long it would take. lol!
Post by: TurboCoupe50 on April 25, 2012, 09:26:56 PM
It's a WC T5 for sure but is 4cyl spec, which means it a bit on the weak side(240ft lb I believe) and has a stump pullin' 3.97 1st gear... Input shaft is slightly different than the V8 T5, requires a Probe pilot bearing to use... None of the gears interchange with the V8 pieces, even the case is machined differently due to having a larger gear size on the input shaft...
A '88 TC with T5 will have a 3.55 ratio, 8.8" Traction-Lock rear with disc brakes... The disc setup are unique to the '87 & '88 TC, At one time Ford Racing offered this setup as a conversion for the Stangs but it's long been discontinued...
Post by: Vito324 on April 25, 2012, 09:52:03 PM
^^^Thanks for the info. I'll post pics when I get into the project.
Post by: Vito324 on May 09, 2012, 11:19:22 AM
How much is the T5 worth in these?
Post by: Chuck W on May 09, 2012, 12:29:31 PM
Quote from: Vito324;389495
Depends on condition.
I'm actually looking for a 4 cyl T5 for my Volvo.
