Technical => Engine Tech => Topic started by: Jmoore87 on April 12, 2012, 11:43:56 PM
Title: 3" exhaust with dual outlets
Post by: Jmoore87 on April 12, 2012, 11:43:56 PM
Im trying to think of a (sorta) buget friendly idea for my v6 cougar. I've given up on trying to get any real power from my engine so thats not the reason for this. I just want it to sound good. So i was thinking of trying the single 3" exhaust but dual pipes out the rear. Can anyone weight in on the pros ot cons of this idea.
Post by: Bruce M on April 13, 2012, 04:58:07 PM
2.5" is the most you'd need with a V6. If you go too big you'll lose bottom end.
Post by: Haystack on April 13, 2012, 06:41:11 PM
I knew a guy running dual 4" on a 98 v-6 stang. He said he gained all around, lost no power and increased gas mileage. Not sure how he mated it up to the 4", but he pulled the motor for a large stroker, then went back to 6 banger.
Post by: bullitt4514 on April 13, 2012, 08:27:12 PM
Dual 3's on a stock v8 would be bigger than needed IMO
Might be able to find a stock sn95 or new edge catback, have modified to fit, and would flow plenty for cheap.
Post by: T-BirdX3 on April 13, 2012, 08:58:58 PM
Save your money and buy two more cylinders. Outside of bragging rights, a 3 inch exhaust on a 3.8 is pointless. Not trying to be mean at all, just wanting to be honest with you.
Post by: Haystack on April 14, 2012, 01:18:38 AM
I would try to fit tail pipes and an h-pipe. I would try 86-93 mustang lx tails and h-pipe, then "headers" for a 94 up 3.8.  If you can make the h-pipe and tails fit, then you can use them on a v-8 car, or if you do the 5.0 swap later.
I don't see any point of running a single 3" then going to dual ler or tips. I would leave it 3" or bigger  the whole way.
Post by: kendoo130 on April 14, 2012, 09:01:59 AM
Quote from: T-BirdX3;386732
This
Post by: Jmoore87 on April 16, 2012, 10:15:51 AM
Thanks you guys for your input. Im gonna take T-BirdX3 advice and try to find a v8
