General => User Rides => Topic started by: ramair351 on March 26, 2012, 08:50:07 PM
Title: a new life for an 88 turbo coupe
Post by: ramair351 on March 26, 2012, 08:50:07 PM
Hi all, i just joined this great forum.
  i have wanted one of these TC's since high school and they were brand new, well it only took 25 years and i finally found a good comprimise of decent shape and affordability. I actually bought this 88/auto TC from a junkyard, the owner has a pile of these cars and almost never sells any parts or cars. He finally relented when he saw i was serious about maintaining it and fixing it up.  it runs well, although a bit slow, maybe a wastegate issue he said as i left, only makes about 4lbs of boost. has some small surface rust in places, but bottom side of the car is spotless.
this is a pic when i first got it home. its all stock except for a bent up K&N filter. i want to find an original air cleaner setup.
(http://i300.photobucket.com/albums/nn27/ramair351/7c991a6d.jpg)
Post by: FirstBird on March 26, 2012, 09:29:33 PM
That car doesn't look like it belonged in a junkyard, it looks very clean More pics please.
Post by: T-BirdX3 on March 26, 2012, 09:45:00 PM
Great find! The maroon color looks so good on these cars!
Post by: 88turbo on March 26, 2012, 10:23:46 PM
Nice TC!! I have a few air boxes if you're interested.
Post by: ramair351 on March 26, 2012, 11:25:16 PM
Quote from: 88turbo;385313
i may take you up on that.  are those factory oval air filters still available? or is there a K&n version?  the dingbat who put this one on just has the VAM flopping around on the fenderwell.
 I do have some more pictures, i just have to get them loaded.
Post by: 88turbo on March 26, 2012, 11:34:36 PM
both a stock replacement and a K&N should still be available.  I'm pretty sure I still have the brackets as well.  also if you find that you have a bad wastegate actuator I have one of those too.  BTW the A4LD in those cars are weak...  you might plan the funeral now and gather some 5 speed swap parts ;)
Post by: 1Bad88tbird on March 27, 2012, 12:52:08 AM
Looks good! Welcome to the forum.
Post by: beast50 on March 27, 2012, 06:09:50 AM
nice find, saved from the almighty crusher!
Post by: ramair351 on March 27, 2012, 06:35:56 PM
more pics
(http://i300.photobucket.com/albums/nn27/ramair351/e19e2c22.jpg)
(http://i300.photobucket.com/albums/nn27/ramair351/04fd330f.jpg)
(http://i300.photobucket.com/albums/nn27/ramair351/d66f8d9e.jpg)
Post by: TurboCoupe50 on March 27, 2012, 08:13:16 PM
That's nice!!! Looks like the 1st one I owned back in '96, 'cept it was a 5speed...
Generally if the wastegate is inoperative you'd be in overboost... Check it's actuator rod to see if the gate is partially open not allowing boost to build... Also you can try disconnecting the BCS(boost control solenoid) by jumping the two ports on the turbo together with a short piece of hose, a automatic generally boost's 10-12psi with this mod...
Post by: turbotrav on March 27, 2012, 10:04:57 PM
What Tom said....
All turbocoupes need a manual boost controller.....even auto ones.  Your cat might be plugged.
Enjoy the TC.....really nice cars.
Travis
Post by: daminc on March 27, 2012, 10:11:10 PM
Welcome
Post by: 50tbrd88 on March 28, 2012, 11:16:35 AM
I can't believe that car was in a junkyard.  It appears to be very clean!  Good luck with it.
Post by: 88turbo on March 28, 2012, 12:06:12 PM
I would almost trade my 5.0 TC for it...
Post by: Soul on March 28, 2012, 12:44:27 PM
CLEAN car, Why in the world was that in the junk.
Post by: sarjxxx on April 05, 2012, 12:04:56 AM
Look at that dash!!! Wow that whole car is so nice. How about a good pic of the engine?
