Technical => Engine Tech => Topic started by: vinnietbird on February 13, 2012, 12:28:28 PM
Title: May have found the rough idle issue.....
Post by: vinnietbird on February 13, 2012, 12:28:28 PM
Alright...some time ago, I stated that I had a hard time starting the Sport, and a rough idle in the morning til I got to driving.
This morning, The Sport wouldn't even start at all. Finally, I had to go, so I took the Maxima, and did what I had to do. I was guessing the ignition module. Had that issue last year. I was prepared to pull the distributor. I pulled the wires, pulled the cap, and hey....what's this? The end of the rotor is...GONE !!! Like it melted and broke. I was sure I checked that a couple of weeks ago....maybe not. Anyway, I went down town, got the MSD cap and rotor kit and installed it. The Sport started fine, but I haven't had a chance to test drive it. I will later today and will report the difference. Anyway, thought I'd share my morning.
Post by: Beau on February 13, 2012, 01:14:56 PM
Reminds me of when I put the engine back in the 'Bird this past Spring...when I was lifting it and the T5 up, I had a come-along rigged up on the hoist to get the engine/trans to angle down so I could stab the tail shaft down in the trans. tunnel..apparently I tilted it a hair too far, and pushed in one of the plug wire towers on the distributor, and didn't know it....till it came time to start it. Had a no-start, but spark at the coil and none at plugs. Checked the distributor, and that's when I saw the busted tower. Pulled cap, and it had sheared off the little nipple that aligns the rotor to the shaft. Had some extras saved up, so all was well a couple of minutes later.
Hopefully the new goodies get yours running better :)
Post by: EricCoolCats on February 13, 2012, 01:16:42 PM
Vinnie, I've had that happen before as well. Better a rotor than a coil pack though. :)
Post by: vinnietbird on February 13, 2012, 01:17:21 PM
i'll know shortly. Right now I'm still driving the Maxima (easier to get out of the driveway). I'll test the Sport later and see how she does.
Post by: bryan163 on February 13, 2012, 01:49:44 PM
Haha, I too have a Thunderbird and a Maxima. Are you ever on maxima.org?
Post by: vinnietbird on February 13, 2012, 02:29:39 PM
Hmmmm, good question. I joined a Maxima site last year, looked around a bit, and asked a few questions, then never went back. Not as comfortable as this place, plus, the Max is primarily my wife's car.
Post by: bryan163 on February 13, 2012, 03:39:50 PM
Yeah, i know what you mean. There is some great info and some really intelligent people on there if you can weed through the bs though.
Post by: vinnietbird on February 13, 2012, 03:55:28 PM
I don't like weeding.LOL.
Post by: V8Demon on February 13, 2012, 09:32:13 PM
Reasons why my Mustang stays garaged...
Post by: vinnietbird on February 13, 2012, 09:45:59 PM
Well, not that a newer part can't go bad, but I installed a new MSD coil last year, and the MSD cap and rotor kit today. I STILL haven't had a chance to test drive the car since the cap and rotor swap, but I have to go to work in the morning, so, I'll find out and report in if there's any difference...or not.
Post by: bryan163 on February 14, 2012, 12:06:59 AM
I've heard of people having issues with MSD coils, including myself. Mine was leaking voltage through the plastic case and arcing to the chassis.
Post by: vinnietbird on February 14, 2012, 08:58:43 PM
The Sport is running a lot better. I think I need a new clutch though.
Post by: vinnietbird on February 17, 2012, 09:54:11 AM
Just bought a set of hardened push rods today. They should be here next week.
Post by: Bob on February 17, 2012, 10:18:52 AM
You still swapping the cam back to stock?
Post by: vinnietbird on February 17, 2012, 10:29:23 AM
Not yet. No time right now. Gotta get settled in to the new job and get through this "never know what the weather is going to do from hour to hour" weather over with.
Post by: thunderjet302 on February 17, 2012, 11:52:19 PM
Quote from: vinnietbird;380935
You have guide plates?
Post by: vinnietbird on February 18, 2012, 08:03:12 AM
Quote from: thunderjet302;381001
I do not. Do you think it's mandatory? And if so, why? (School me please.).
Post by: thunderjet302 on February 18, 2012, 11:28:41 AM
Quote from: vinnietbird;381021
Hardened pushrods are realy only needed with stud mount rockers and guide plates. With that set up the pushrods rub on the guide plates. They are hardened so they don't were out from rubbing on the guide plates. If you have pedestal mount rockers (which you do with the GT40Ps) then the non hardened push rods are fine. You won't gain anything with the hardened push rods. They won't hurt, but unless you need new ones it's a waste of money.
Post by: vinnietbird on February 18, 2012, 12:50:26 PM
I need new ones.LOL.
Post by: 88 Blackbird 5.0 on February 18, 2012, 02:01:20 PM
What's wrong with the pushrods that are in the car noiw Vinnie?  Do you think the "sewing machine" issue your engine has compromised them?
Post by: Beau on February 18, 2012, 03:23:45 PM
Quote from: thunderjet302;381028
Good to know. Thanks Lou :)
(Picked up some GT40P's last weekend, this will get put in my list of 5.0 info I'm compiling)
/thread hijack.
Post by: vinnietbird on February 18, 2012, 05:41:24 PM
Quote from: 88 Blackbird 5.0;381037
Not really....but not really sure. They have been revved over 6000 a few times, and for the price I got the hardened rods, (ha, ha....I said hardened rods.LOL), I figured that It can't hurt anything. Overkill? Probably, but not in a bad way.
Post by: vinnietbird on February 18, 2012, 05:41:58 PM
Quote from: ThunderbirdSport302;381039
/thread hijack.
Beau, I don't mind thread hijacking....I'll share.
