Technical => Misc Tech => Topic started by: Dan B. on February 08, 2012, 05:50:19 AM
Title: Rear fuel lines
Post by: Dan B. on February 08, 2012, 05:50:19 AM
Back to working on the t-bird...dropped the gas tank last night and the rear metal fuel lines are in pretty rough shape.  When remove one of the nylon lines I pulled the end right off the of metal lines, they were corroded bad. So now I just want to replace everything from the fuel filter to the tank.
I've read a few other posts that are telling me that these are not available as a replacement item and are going to have to be fabbed. Really??  Dang.  Please let me know if I maybe missed something.  I kind of need the new ones ASAP to keep moving ahead.  Thanks.
Post by: SLEEPER T-BIRD 87 on February 08, 2012, 08:20:02 AM
ive  got a rust  free fuel pump hanger pm if interested
Post by: 1Bad88tbird on February 08, 2012, 09:10:12 AM
I've read the same thing Dan. Maybe you should add a small tubing bender to your collection of tools and start making some. I'm sure it would be cheaper for yourself that way plus you could make a few extra to sell.
Post by: 88 Blackbird 5.0 on February 08, 2012, 10:46:49 AM
Hey Dan.  Like you've found out, your options are pretty limited for new fuel lines.  Your best bet IS going to be bending your own lines.  Go to your local NAPA and buy a however much galvanized steel brakeline you need and bend that to shape.  Cut the flare nuts off the brake line, but leave the flared ends on it.  For the pressure side, I'd recommend avoiding the use of nylon flexible tubing (like the car came with) and using fuel injection hose instead.  Use fuel injection hose clamps to secure the hose to the tubing behind the flared ends and you ha ve good, secure connections.  It would be a good idea to get some Plumber's silicone grease and use a little to lubricate the tubing ends to make it easier to slide the hose onto it.  For the return side, you can use regular fuel hose for the flexible sections.
Bending the tubing isn't that hard to do.  Just take your time doing it.
Post by: Dan B. on February 08, 2012, 03:01:53 PM
Making new lines is not an issue but I'd like to replicate the stock style as much as possible.  If there is a better way though, I'll do that.  I'm not sure that I completely understand the fuel line orientation on the pressure side that you are describing.
Post by: Soul on February 08, 2012, 03:10:52 PM
Braided line is easy, get a compression fitting, attach to fitting coming out of fuel tank, run braided line to engine bay and connect.
Did my feed and return with -8 and -6. Was super easy. Just make sure you get all the fittings you need (the are what costs the most).
Post by: 88 Blackbird 5.0 on February 09, 2012, 11:21:09 PM
Quote from: Dan B.;380172
When you go to replace the pressure side of your fuel system, replace the metal lines with galvanized steel brake lines (after cutting the flare nuts off the brake lines) and replace the black, flexible nylon lines with fuel injection hose.  Use fuel injection clamps to secure the fuel injection hose to the new metal lines you install.
