Technical => Body/Appearance/Interior => Topic started by: V10KLZZ71S on January 30, 2012, 09:37:13 PM
Title: Reproduction interior pieces
Post by: V10KLZZ71S on January 30, 2012, 09:37:13 PM
Does anyone make new door panels or the top part of the dash or any interior replacements? My dash is , both of my armrests are off of the door panels.I am removing the rear seats due a roll cage, but would like to have a stock looking front cabin if possible. I will most likely do away with my digital dash readout because I will install mechanical gauges. But the dash is bad on top. I also need that rubber weatherstrip around the rear window. Im sure there is more to replace. TMI handles all the fox mustangs with interior stuff, but no tbirds.
Post by: vinnietbird on January 30, 2012, 10:17:08 PM
This is about all you will find for the dash....aside from finding a mint dash (good luck with that).....
http://www.ebay.com/itm/Ford-Thunderbird-Dash-Cap-85-86-87-88-/380296877442?fits=Model:Thunderbird&hash=item588b75d582&item=380296877442&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr
As far the rear window trim, it too is super hard to find. Every once in a while one will show up on Ebay, not cheap. Parts for these cars are getting super hard to find. No repro parts for the interior are out there that I have ever seen. You have to be patient, and also hone in on your treasure hunting skills. You'll need them.
Post by: Bruce M on January 30, 2012, 10:17:58 PM
I need a dashcap too and headliner.
Post by: V10KLZZ71S on January 30, 2012, 10:24:38 PM
Quote from: vinnietbird;379331
I am quite the ebayer!! I saw those covers, I would hate to do that. I'll come up with something to do with the dash.
Post by: vinnietbird on January 30, 2012, 10:42:05 PM
The caps actually look good when they're applied right, the dyed to match.
Post by: bryan163 on January 31, 2012, 12:29:36 AM
I have that cap on mine. I would recommend it.
Post by: beast50 on January 31, 2012, 05:37:34 AM
headliner can be done at an upholstery shop, Bruce.  I had an 88 Monte Carlo with the ever popular headliner sag, all I had to do was remove the old one, carefully, making sure not to damage the mold the cloth is adhesed to.  Tote it on down to a good upholstery shop thats been in the business for awhile, pick out your matching cloth and they hooked me up for about $100.  Looked great, I am sure the Ford headliners are the same way.
Post by: Bruce M on January 31, 2012, 05:53:56 AM
That what I planned on doing. My wife I bugging me pretty bad to get it done.
Post by: 50tbrd88 on January 31, 2012, 09:36:43 AM
I have one of the caps from I believe dashtops.com.  It takes a little time to trim it right and get it fitting good but once you do it looks great.  A lot better than a cracked-to-hell original dash!  The grain in the plastic is a tad different but unless you have a very keen eye (and most people don't when it comes to our cars) you would never know it wasn't original.
Post by: flylear45 on January 31, 2012, 09:55:45 AM
Quote from: 50tbrd88;379355
+1
Post by: Gdub on January 31, 2012, 10:12:04 AM
I went to Dashtops.com but it doesn't give installation instructions. Do the tops glue on? Do you trim them to fit? Does anyone have pics of one of these installed on their car?
Post by: lakenheath24 on January 31, 2012, 11:07:50 AM
Here is a pick of my dash.  You just have to trim the speaker grills.
http://www.foxtbirdcougarforums.com/showthread.php?29550-Interior-Restoration/page3
The headliners are pretty easy to do yourself.  Where are you in P-cola....I can always give you a hand.
Post by: thunderjet302 on January 31, 2012, 02:16:27 PM
Quote from: Gdub;379359
Yep they need to be trimed to fit. The tops come with glue as well.
(http://i198.photobucket.com/albums/aa33/thunderjet302/floor%20mats/DSCN2147.jpg)
Post by: EricCoolCats on January 31, 2012, 04:21:06 PM
Semi-instructions and lots of photos:
http://www.coolcats.net/modifying/dashtop.html
Post by: 50tbrd88 on January 31, 2012, 04:53:01 PM
Here is mine.  I ended up not putting enough glue in one spot in the dash (in between the tach and guages up top) and it got a air pocket in it.  Other than that it turned out pretty good.  Just take your time and it will look fine.
(http://i495.photobucket.com/albums/rr313/50tbrd88/car%20stuff/DSCF1917.jpg)
(http://i495.photobucket.com/albums/rr313/50tbrd88/car%20stuff/DSCF1918.jpg)
For the record I did not dye mine.  I had planned to but I though it matched close enough to work.
Post by: Gdub on January 31, 2012, 05:45:24 PM
Thanks everyone I think I will go that route. Lakenheath I am just off Davis hwy at the Interstate. I might take you up on the help when I get around to doing it.
Post by: lakenheath24 on January 31, 2012, 07:56:57 PM
Sure thing Gdub...I did the rear seat delete and everything so I'd be glad to help!
Post by: V10KLZZ71S on January 31, 2012, 09:42:34 PM
All of those look good. Mine looks like it had one on it, but it is gone because I can see what looks like glue on it.
Post by: Gdub on February 01, 2012, 02:56:02 PM
Just ordered my Dash cover from Dashtops but the new site is Dashtops.net and they take PayPal.
Post by: BlueBird1987 on July 16, 2012, 02:54:07 AM
I know this is sort of old...but as for the dash caps, how do you swap them?
