Technical => Electrical Tech => Topic started by: FirstBird on January 18, 2012, 07:48:05 PM
Title: Turning back mileage
Post by: FirstBird on January 18, 2012, 07:48:05 PM
I purchased a buttstuffog cluster and I want to switch it for my base cluster that has stopped working. Is there any way to turn back the mileage on the cluster? Thanks
Post by: jpc647 on January 18, 2012, 08:18:13 PM
There was a thread a while back about it. I searched but can't find it. I remember it mentioning there is a clip you have to break to get it open. Sort of like on the electrical meter on a house, that metal ring.
Post by: FirstBird on January 18, 2012, 10:21:29 PM
Yeah I remember reading the same thread a while ago.
Post by: Thunder Chicken on January 19, 2012, 05:47:42 PM
There's no clip to break, you've just got to take the pin that acts as an axle for all the little gears, and you've got to reassemble them just right or nothing will work and/or the numbers won't line up properly. It's a PITA but is doable if you've got patience. Don't look for too much instructions on how to do it, though, for legal reasons (it's illegal for you to do it, and it's illegal to tell you how to do it, not that it would prevent me from changing mine to reflect the proper mileage, which I did)
Post by: FirstBird on January 19, 2012, 06:41:57 PM
Hmmm might have to do a little investigating, once i do the 140mph speedo.
Post by: vinnietbird on January 19, 2012, 10:31:08 PM
I've done every speedo I put in the Sport. The stocker, the BBK 190mph speedo, and the current Ford racing 140.
Post by: vinnietbird on January 19, 2012, 10:33:34 PM
If you get desperate, send me the gauge and I'll reset it for you.
Post by: FirstBird on January 19, 2012, 10:58:06 PM
Vinnie mind giving me a few tips on how to do it?
Post by: hypostang on January 19, 2012, 11:01:51 PM
I have set replacement ones too, however I am really unable to explain the process , but I'll make the same offer as Vinnie
Post by: FirstBird on January 19, 2012, 11:03:53 PM
I'll fiddle around with it I guess. Can't be too hard
Post by: vinnietbird on January 19, 2012, 11:27:23 PM
Not really that hard, but it can get aggravating. You have to GENTLY pull the speedo needle off by pulling straight up. CAREFULLY. Then remove the face plate by removing the two screws. Don't scratch the face. Then, remove the "motor" from the assembly (white box of gears). You;ll se the odometer numbers in black held in by a press to fot pin. From the right, I push the pin inwards towards the left side using a very small punch. Be VERY careful with those gears. I actually don't take them out, I just loosen the pin until I can move the numbers. When you start rotating the numbers, they will actually be slightly off (they should be rolled back just a hair), because when the gears all go in place, they will move the numbers a little. Trial and error. I've seen a couple of guys try this with their stock speedos and throw them in the trash because of the aggravation. Test fit the face plate to the "motor" to make sure everything lines up. push the pin back in place then re-assemble. Hard to describe it so you can "see" what I'm saying. next time I get a speedo, I'll do this process and take pictures. But, as i said, I'll be glad to do it for you. I did mine many times (different gauges). Everyone here knows me and knows I'll treat you right. No charge, just shipping. If you need me, PM me. I'm easy to find.
Post by: V8Demon on January 19, 2012, 11:46:41 PM
http://www.foxtbirdcougarforums.com/showthread.php?4855-How-to-change-your-buttstuffog-odometer-reading-%28lots-of-pics%29&highlight=
Post by: vinnietbird on January 20, 2012, 12:01:27 AM
Yeah....that's what I was trying to say.................Mostly.
Post by: dragon574444 on January 20, 2012, 03:28:22 PM
Do it the way Ferris Bueller would. It works on my 84 cluster, not sure about the newer ones. Just hook it up to a drill and have at it.
Post by: vinnietbird on January 20, 2012, 07:51:34 PM
Quote from: dragon574444;378244
Nope, won't work.
Post by: FirstBird on January 20, 2012, 10:41:39 PM
Got it figured out once you have it taken apart it's fairly easy just popped the little pin out and had my way with it. Thanks for all the help guys.
Post by: Thunder Chicken on January 21, 2012, 02:01:20 PM
Your '84 cluster is cable driven. 85-88 clusters are electronic
Post by: Romeo2k on January 21, 2012, 04:43:24 PM
A long time ago I got an buttstuffog '83 Coug (Silver) cluster and set it back. I don't remember the whole process, But I remember it wasn't very hard. Mostly just tapping out a metal pin, rolling the numbers as desired, and tapping the pin back in place.
Though it sounds like it's harder for an 87-88.
Post by: jpc647 on January 21, 2012, 08:03:16 PM
Quote from: V8Demon;378200
V8demon FTW!!!!!!
Post by: sarjxxx on January 28, 2012, 07:23:52 AM
now if we could just figure out how to do it with an electronic/ base cluster :giggle:
Post by: jpc647 on January 28, 2012, 09:25:58 PM
Quote from: sarjxxx;379065
Run it up to 200,000 miles, it;ll reset back to 100,000. I read that a long time ago.
Post by: daminc on January 28, 2012, 09:33:54 PM
but what if 100,000 is still to much
