Technical => Drivetrain Tech => Topic started by: Dan B. on November 08, 2011, 07:17:02 AM
Title: T5 pedal swap.......missing pieces
Post by: Dan B. on November 08, 2011, 07:17:02 AM
OK....time for the pedal swap!!
Automatic pedals are out.  So now that I'm ready to install the stick shift pedals I realize how little I know about the T5 cable workings!!  All the other sticks I worked on were the old mechanical style w/ the pivot ball and rods or Ranger style hydraulic.  The pedal assembly I have is from an early fox'stang and is bare, I mean bare!  So I have no reference to go by for where the quadrant goes or anything else that hooks to the rotating pieces.  My bro-in-law has a T5'stang so I tried to look under the dash of it to see how things worked.....couldn't see squat.
So, can anyone post a schematic or pics of what I need and what the heck goes where.  Or list the pieces I need and a pic of where they go....something, anything!!
About the only thing I located was where the cable goes through the firewall by the brake booster.  But under the dash I'm lost.  Thanks!!!
Post by: 5.0 tbird on November 08, 2011, 06:18:29 PM
If you put on an aluminum quadrant, it's really easy to install. The factory plastic quadrant has some springs that make installation a little more difficult.
Post by: TOM Renzo on November 09, 2011, 05:20:03 AM
[i
Post by: Dan B. on November 09, 2011, 06:14:18 AM
That helps!  Is there anything that goes on the clutch pedal side of the set up?  From looking under the T5 mustang I mentioned before, it looks like there is a small box of some sort...maybe a cruise cancellation switch or something similar??
Post by: TOM Renzo on November 09, 2011, 05:34:02 PM
Clutch S
