Technical => Engine Swapping => Topic started by: 4eyed'Cougar on October 30, 2011, 02:58:32 AM
Title: 84 cougar carb swap
Post by: 4eyed'Cougar on October 30, 2011, 02:58:32 AM
i just pulled my stock "efi" 302 out and im dropping in my built 306. i have a few questions about the tranny kickdown rod, ingnition, fuel pump.
whats the best way to mount the TV rod to the carb? i have a high rise intake with a 750 holley.
ignition i was reading a few fourms and they said my ingnition system wouldnt work? i all ready have a new dizzy *vaccum advanced* but wondering why i couldnt just hook that up.
the 84 cougar has 2 fuel pumps a high flow in the tank and an inline pusher pump *low pressure* wondering if it had enough pressure to run a 750, also wondering how to run a line into the tank or could i just leave it in there? would it still pull fuel if i left it in there?
Post by: Chuck W on October 30, 2011, 09:16:36 AM
You have the fuel pumps backwards.  The in-tank is the low-pressure lift pump that feeds the high-pressure in-line pump.
Without a regulator, you can't use the EFI pumps for a carb application.  They're running about 35-40psi vs the 5-7psi that's normal for a carbed car.
Post by: 4eyed'Cougar on October 30, 2011, 01:58:52 PM
Yes, i was thinking i would have to get one, Also im pretty sure the low pressure is in the line lol but ill do some checking lol
Post by: Bruce M on October 30, 2011, 02:36:48 PM
Low pressure is in the tank. I doesnt make much since to boost the pressure if the tank pump is already high pressure does it?
The low pressure is in the tank and the in-line pump is the high pressure pump. I've heard of people using the low pressure in the tank with carbs, but you'd need a pressure regulator.
Post by: Chuck W on October 30, 2011, 05:32:26 PM
Quote from: 4eyed'Cougar;371512
No...low pressure is in the tank...I wasn't guessing.
Post by: QUICKSHIFT on October 30, 2011, 07:56:56 PM
I've done this swap on my 84 using the pumps with a mallory  4309 regulator and a dura spark ign. I have a very descriptive  post how I did it....I just have to find which forum I posted it on and I will post a link.
Post by: QUICKSHIFT on October 30, 2011, 08:09:33 PM
.....here's one but it's not the more descriptive one....I'll keep looking.
http://www.fordmuscleforums.com/all-ford-techboard/464848-fuel-system-help.html
EDIT.....can't see for looking  DUH!
http://www.foxtbirdcougarforums.com/showthread.php?31828-duel-fuel-pumps-to-single-high-pressure
Post by: QUICKSHIFT on October 30, 2011, 08:38:40 PM
.......found another one, hope it helps. Keep us posted on your progress as I may have forgotten something else along the way.    http://sbftech.com/index.php/topic,15112.msg146399.html#msg146399
