Technical => Drivetrain Tech => Topic started by: dudeman351 on October 22, 2011, 01:03:31 PM
Title: please can anyone answerthis one?
Post by: dudeman351 on October 22, 2011, 01:03:31 PM
i did a search and didn't come across the info i was looking for. if i change chunks between 8.8s do i keep the shims with the housing or the chunk?:dunno:
Post by: vinnietbird on October 22, 2011, 06:52:47 PM
What do you mean by "chunk"? They don't swap like a 9 inch rear does.
Post by: dudeman351 on October 22, 2011, 07:33:05 PM
the carrier and pinion assys. the mustang has 2.73 and the old merc has 3.55. so basically do the shims and crush sleeves stay with housing or carrier andvgears.
Post by: TOM Renzo on October 22, 2011, 11:31:53 PM
No
Post by: Shadow on October 22, 2011, 11:54:32 PM
like tom said.. there's a 99.9999% chance the housings are machined differently.. it's about a 1 in a million chance of them being the same.. you just need a shim kit and know-how with the right tools
Post by: 1BadBird on October 23, 2011, 11:34:09 AM
Tom, What do you use instead of a crush sleeve?? I've built a few 8.8's & 9"'s and a couple Mopar axles and have always used them. I'm just curious what the advantage would be.
Post by: TOM Renzo on October 23, 2011, 07:51:22 PM
Their a
Post by: 1BadBird on October 23, 2011, 09:46:36 PM
Cool deal. Where would one get those and what's the process for measuring the depth ?
Post by: TOM Renzo on October 24, 2011, 05:57:43 AM
Randys
Post by: 1BadBird on October 24, 2011, 08:05:39 AM
Cool Thanks Tom.
Post by: Chrome on October 24, 2011, 08:34:47 PM
Shims from housing should put you close, but Tom is right. Measurements must be taken or diff will shell for sure. Crush sleeves can be re-used if you take the crush out of them. Experts say to never do this, and I don't suggest doing it either. Crush sleeve eliminators sound great. I have never heard of them until now. That is the way I would go.
