Technical => Suspension/Steering => Topic started by: SR71blackbird on October 06, 2011, 10:37:26 PM
Title: more power= broken parts
Post by: SR71blackbird on October 06, 2011, 10:37:26 PM
Soon i'll have around 350-360RWHP. All i need is the stand alone computer from stinger to have that power. With more power, I know things can break. My question is what parts should I look at replacing with upgraded parts to prevent any bad situations.
Post by: Haystack on October 07, 2011, 12:38:41 AM
Driveshaft saftey loop, you probably don't want to catipult from a bad u-joint. Depends on how hard you are on it and what your doing.
Post by: daminc on October 07, 2011, 07:57:13 AM
torque box reinforcing would be good. along with SFCs
Post by: SR71blackbird on October 07, 2011, 10:12:22 AM
whats are SFCs?
Post by: jangus on October 07, 2011, 12:27:40 PM
SFC = subframe connectors. They're used to tie the front subframe into the rear subframe to enhance chassis stiffness.
I don't see any mention in your signature of an aftermarket clutch. If you're running a stocker, it won't hold up to that much power.
Post by: QUICKSHIFT on October 07, 2011, 07:46:52 PM
If you're going to run "stickys", the extra traction will raise hell with your U joints as well as that T-5.
Post by: SR71blackbird on October 08, 2011, 03:10:50 AM
Jangus: Oh alright, I believe iv read that mustang ones should work correct? Also i have a spec stage 3 clutch hiding under my bed ; )
Post by: Haystack on October 08, 2011, 09:19:26 PM
Buy just regular square tubing. Mustangs have a bend in them. Ours do not. Check out coolcats.net
