I was working on my wiring under the hood and now my ABS system does not work. The manual says there is a fuse but I can't seem to locate it. Can anyone help me?
So I assume you have an 87-88 Turbo Coupe?
http://www.turbotbird.com/techinfo/TEVES%20II%20ELECTRO-HYDRAULIC%20BRAKING%20SYSTEM%2087-88%20TCs.htm
yes 87 turbo coupe
87 Fuse panel.
There is no fuse for the ABS.
There are two fuse links that are for the ABS.
I am guessing you did not disconnect the battery while working on the wiring.
Did you make sparks?
A yellow wire on the starter relay goes to six fuse links. Four blacks a blue and a brown.
Two of the black links are for the ABS.
Look to see if the one of the link's insulation looks like it overheated. If you can stretch it a little, that means the wire inside has blown.
Yes I made sparks. I know I don't know what I was thinking. But the Tech data worked. I had one of the wires in the relay plug out of location so we are back and running and stopping. Thanks for your help I knew it was something simple but without the tech data I would have been up a creek.
