Text only
Text with Images
Technical => Engine Tech => Topic started by: Smkn600ctd on September 22, 2011, 02:55:25 AM
Title:
2 questions...Where is the pcm located on a 83 Bird and CFI Injector removal tips
Post by:
Smkn600ctd
on
Where is the pcm located and how do you get it out?
Can you remove the injectors with the TB on the car? What's the trick to remove the injector from the rail/TB?
Text only
Text with Images
