Technical => Engine Tech => Topic started by: 88turbo on August 30, 2011, 08:40:00 PM
Title: O2 extension harness
Post by: 88turbo on August 30, 2011, 08:40:00 PM
just curious if anyone here has used these and if they are both included in the kit. BBK Performance Extracter Series - O2 Sensor Harness Extensions
http://www.oreillyauto.com/site/c/detail/BBK3/1676.oap?year=1988&make=Ford&model=Mustang&vi=1133929&pt=04651&ppt=C0018
Post by: 88turbo on August 30, 2011, 08:48:07 PM
http://www.summitracing.com/parts/BBK-1676/?rtype=10
guess I answered my own question.  lol
Post by: vinnietbird on August 30, 2011, 11:27:21 PM
I'm just going to lengthen the wires on my replacement O2 sensors for free. That's a chunk of money in the Sport's world.
Post by: mcb82gt on August 31, 2011, 08:35:26 AM
If you need new sensors, you can buy them with longer wires.  That is what I did.
Post by: TOM Renzo on August 31, 2011, 09:22:29 AM
[quot
Post by: vinnietbird on August 31, 2011, 11:18:33 AM
Tom, what special connectors? Got a link?
Post by: daminc on August 31, 2011, 11:21:36 AM
mine must not be the good ones then..I just lengthened mine last week
Post by: vinnietbird on August 31, 2011, 12:10:12 PM
What did you use Jerry? I was thinking about using the regular crimp connectors and shielding over it.
Post by: daminc on August 31, 2011, 12:17:00 PM
I soldered them, and used shielding... and I had some heat shield tubing that went over all of it near the header
Post by: vinnietbird on August 31, 2011, 12:32:38 PM
I'll try to solder them. If it doesn't work, I can always crimp them. Thanks.
Post by: thunderjet302 on August 31, 2011, 04:30:25 PM
You can extend the O2 sensor wires in the harness (which I did) but not the wires on the O2 sensor. The wires in the harness are regular wires but the wires on the O2 sensor are special and should not be lengthened. If you do you'll ruin the calibration on the O2 sensor and it will not function properly.
Post by: vinnietbird on August 31, 2011, 06:57:15 PM
Hmmmm, I never thought of that. Lengthening the harness is easy enough. Yes, I'll do it !!! Tomorrow.
Post by: hypostang on August 31, 2011, 07:06:01 PM
I made extension harnesses out of old sensors and part of the cars harness from the junkyard
Post by: TOM Renzo on August 31, 2011, 07:20:08 PM
Well i
Post by: vinnietbird on August 31, 2011, 07:44:57 PM
I'll pull the harness tomorrow,. That's an easy task. I'll first  install the replacement O2 sensors and see how much wire needs to be added to the harness, then, make it happen.
Post by: 88turbo on August 31, 2011, 08:13:07 PM
sounds easy enough!!! was going to make my own extension harness but Jerry told me no!!
Post by: Kitz Kat on September 01, 2011, 05:23:30 AM
I soldered my original ones a while ago and it worked,at least I thought they were original. Replaced them since then with longer ones.
Post by: daminc on September 01, 2011, 07:56:37 AM
Quote from: 88turbo;366504
Well you could.. but I think it will take the same amount of work to just lengthen the originals... your call on that one..
I'm also planning to get longer ones myself down the road sometime
Post by: vinnietbird on September 01, 2011, 08:53:45 AM
I'm TRYING to get motivated to get out there. It's been a long week. I REALLY want to work on the car, but the TV and couch sure seem like a good idea as well. I'll go to work on the Sport. Probably wait til it's a hundred degrees.
Post by: Slinky on September 02, 2011, 07:01:16 AM
I used the harness extension from summit.
Post by: thunderjet302 on September 02, 2011, 12:35:25 PM
I extended the harness because I have solder and wires in the garage that are *free* vs. paying for a harness extender. Besides I like playing with the soldering gun.
Post by: vinnietbird on September 02, 2011, 04:34:09 PM
Quote from: thunderjet302;366654
Same here, and I agree with you, soldering guns are fun. This Sunday after work I'll probably break out the stuff and extend the Sport's O2 harness.
Post by: hypostang on September 02, 2011, 06:26:32 PM
I used a soldering iron , but Yeah, this
