Technical => Misc Tech => Topic started by: Trinom on August 25, 2011, 04:19:32 PM
Title: Cold water from air dryer leaks to interior
Post by: Trinom on August 25, 2011, 04:19:32 PM
Hi, I have a problem with leaking water to interior. I think, it is condensed water from air dryer. If I make a sharp right turn, it begins to leak cold water directly to the gas pedal area (on my right foot :beatyoass:). I never noticed this problem before, although I use AC almost every time I drive my car in this unbelievably hot summer.
Here is the photo of the "leaking black box" (in the middle I think).
(http://www.abload.de/img/img_0066p7c4.jpg)
I have an idea, but I need your help. Can be cloged the hole under the AC reciever (dryer) on the engine side of the firewall? How to clean it?
Thanks
Post by: The Shredder on August 25, 2011, 05:18:54 PM
Yep.  Clogged drain hole in the firewall.  It should drain out there instead of on your foot. :)
Post by: 88turbo on August 25, 2011, 06:43:19 PM
use a small nail or wire to poke in the hole to clear of debris
Post by: TOM Renzo on August 26, 2011, 09:48:27 PM
I take it you are talking about the EVAPORATOR??? That would be a clogged drain hole as posted above. Clear it out and you will fix that issue. Then do not park it under a TREE any more!!!!!
The receiver dryer is under the HOOD. Your post was interesting because i had no idea what an AIR DRYER WAS. Now i know you were referring to the EVAPORATOR.
Post by: Trinom on August 27, 2011, 05:05:03 PM
Please delete this post (double post). Thanks.
Post by: Trinom on August 27, 2011, 05:05:47 PM
Thanks, I cleaned the hole and there was something like one liter of water (1 qt). I can't believe how fast it get cloged.
The reciever dryer dries the coolant, not air, it does the evaporator :-)
Post by: jrad235 on August 27, 2011, 05:17:06 PM
Quote from: Trinom;366158
Thanks, I cleaned the hole and there was something like one liter of water (1 qt). I can't believe how fast it get clogged.
The receiver dryer dries the coolant, not air, it does the evaporator :-)
You are correct Trinom, the Evaporator core removes the moisture from inside your car(Dries the air), and the Receiver/Dryer takes care of keeping the refrigerant clean and dry(Of moisture).
  Glad to hear it was a simple fix. It is somewhat amazing how much liquid the HVAC housing can hold!
