I got a friend who is parting his stang and I can get some stuff real cheap from him. If the PW track regulator, motor etc will swap that would be awesome but I don't know if the shorter doors will be a problem? Also I'm pretty sure the lock actuator would be the same but I've been wrong before...
Fox stangs have frameless windows so I'm almost certain the window regulators won't work. As for the lock motors, you might be able to use them but you'll probably need to use your Cougar-specific mounting bracket and actuator rod. When the lock motor on my T-Bird shiznit the bed I simply installed a $9 universal aftermarket motor...
I think the locks and motors will swap.
Ah well see then it wouldn't matter for me anyway b/c the whole reason I wanted them was for a conversion rather than a replacement... what I'm getting at is simply that I don't have the required mounting bracket to begin with... but it doesn't matter anyway cause he decided to keep the car lol
That's ok I'll just nab everything I need from a thundercat next time one shows up around here
How's the car coming along? Any progress? Haven't heard from you around here much lately.
check my thread in my sig. I "updated" it last night.
