Has anyone put 2003 Mach 1 springs (part#MCH 3r33 5310-AA) on a T Bird or Cougar ? I have a set I want to put on but they look like the car might sit too low . I have an 87 Cougar with a stock (no po ) 5.0 . I have 245/60r 15's on the front and I might have to put on some 225/50r 15's i have .
They'll for sure drop it down, but the tires should clear...are the wheels stock? If they have different-than-stock offset, the tires may rub.
Mach springs with 225/60R15's on 10-holes:
...And with 225/60R16's on snowflakes. These are both stock tire sizes available from the factory on these cars.
I had CHE adjustable rear lower control arms on the back, and had them adjusted up quite high. The rear might sit too low with stock LCA's and Mach springs - they're about 3" shorter than stock springs...
Thanks alot you provided exactly what I needed . After seeing your pics I think my 245/60's are going to be a little too wide and my 225/50's a little too short . I guess I'll buy some 225/60's . For the rear I have some custom springs by Coil Spring Specialties (320 lb inch 1" ) drop and I'll stay with my 255/60's for now. Thanks for both of your replies .
yeah, the rear sits waaaaay low without the adjustables. the front was also high for me as well, i guess due to the 5.0/4.6 weight difference.
High ? Do you have any pics?
without adj. lca's it will really drop it down. I have mine just about maxed out. Here is a link with mine.
http://www.foxtbirdcougarforums.com/showthread.php?31280-Before-and-after-with-mach1-s
I love your ride bro . The stance is awesome , just what I Want .
I just put one of my custom rear springs next to one of the Mach rear springs and it was the same length . Much thicker but the same length . I hope that doesn't mean I'll have to get new adjustable lower control arms . I already have the CHE non adjustable arms .
Another shot . You can see the difference much better in person .
The rears are easy, try one out and see. The customs look heavier you might get away without adj lca's
I did omfg !!! The springs are custom jobs by Coil Springs Sepcialties and the front was supposed to go down 1.5" the back 1" well this is how the back looks
The tires are 255/60r15's and the pic doesn't do justice to how low it looks . The shop is a mess and I don't have alot of room around the lift so that's the best I could do pic wise . The car's in primer so I don't care about the fingerprints . Even though the front was supposed to be lower it sits higher now so next I'll try the Mach front springs . Can a thinner spring have a higher rate (lbs/inch) than a thicker one ? The custom rears were supposed to be over 300 lbs/inch much higher than the stock springs ( 200 something ? ) but they were thinner . What's up with that?
Stock vs Mach (with tag )
All of those dead coils in the stock spring help keep the height. I think the rear sits about right, if you can get the front low enough to match.
I bought these on Ebay today (Selling used 1979-2004 Mustang H&R Front Lowering Springs. In good used condition.
Drop rate of about 1.5" and spring rate of 900 lb/inch.)
When they get here I'll decide between them and the Machs .
ricktjr... Can I see a picture of the front before you take them out ?
Are you useing Isolators ?
Also, I think its wise to say if the car is just sitting around it will be about 1/4 higher than when you drive the car for a week or so.
I had a friend swap SN95 springs and cut the front one coil. It looked even for a week in his drive way (without driving it). Then he drove the car for a week straight and it settled down 1/4"
Is your car a V8 or what?
Just in case. If you decide to get rid of the rears I'll be waitting :) I got dibs on the Coil Spring Specialties or the Mach 1s
Here ya go . No prob on the springs bro . I have polyurethane isolators on the front and rear . I might just put my 98 mustang spindle/brake setup on while I'm at it . Not sure yet .
With the back so low these (Mach Shocks ) fit .
ricktjr, it looks like the motor is out of the car. Is it? You didn't answer my question about if its a V8 or not. EDIT: I see its a 5.0 in the first post (sorry)
I was going to buy those H&R springs you got off ebay. I emailed the guy a few days ago. Its funny how we were thinking the same thing for the same application. Can't wait to see them on the car. Just curious what a 1.5" Mustang drop does on the Cougars & Tbirds.
Like I said I had a friend cut one coil out and it was too low after a week of driving. Then another guy did a 2/3 cut out of his fronts from a 94-04 Mustang GT with stock rear height as well and it looked good. The back was alittle lower than what yours is currently. This Tbird is a 4 cylinder so I don't recommend a 2/3 cut for your Cougar. The stock backs should do the exact same thing to your Cougar from what I've read (with Isolators ! ). I don't know for certain because I have a Tbird. I just read they do the same thing on both birds and cougars.
my car sit's to low in the back and way to high in the front also..... I'm going to have to do some spring changing myself
There was no way I was going to be able to use my Mach springs without also going to the CHE Adjustables
Yes 2tbirds it does have the motor in it it just looks goofy because the back is so much lower than the front . I hope the front spring swap will change that . Bigbada1 I should have purchased the CHE adjustable lowers when I got the non adjustable ones . Oh well I might end up with an extra set of lowers . Either way my little spring experment is turning out to be more fun than I thought it would be.
The new springs are even shorter than the machs !! around 11"(give or take) compared to around 13"(give or take) .
The new (SN95) spindle seems to fit and now I can put things back together .
Well I now have one quarter of a 5 lug swap done lol . Actually I still have to mess around with the tie rods and I might end up switching up both inners and outers to SN95 specs because I think the Fox parts are going to be a little too short. I know the pic's terrible I'll try for a better one after work tommorrow. Also the pic is deceiving because i switched tires to 225/50r15s which are shoter than the 245/6015s (23.85/26.57)
Pretty sure that Sn95 inner tie rods won't work on a Fox rack...and an SN95 rack won't work with a stock Fox steering shaft...I was looking into all this myself...too costly and no real gain, unless you're building an all-out race car...
I've got SN95 spindles on mine, with SN95 balljoints, a Fox rack and inner/outer tie rods...no problem with the length. Remember, if you lower the car, basically, you'll gain a small amount of tie rod end length, or at least, that was my experience, I think it amounted to about a 1/4" on each side. I switched from the stock Sport springs, to TC springs (no difference, really) and then to '97 Stang springs...seems like it has came down a little bit..hopefully a little more.
Thats still too high in my opinion. When I seen the coil spring specialties on there I thought they may have messed up and made the spring too long. Now I'm thinking what in the world is going on? I mean, shouldn't it be sittling alot lower than that?
I've seen late model T.Cs with one coil cut out of SN95 front springs and the tire sits just inside the fender. Shouldn't the same apply on the Cougar?
I agree completely . I'm going to do the other side and takev it from there .
Here you go this is how we do it. It increases the spring rate a lot and it lowers the car 1-1 1/4"
http://i600.photobucket.com/albums/tt88/tomrenzo/Kitties244.jpg
Makes the ride even rougher though.
If mine doesn't sit how I'd like it to when the rear is finished, I'll probably cut my TC springs and try those.
i'm still very happy with my SN-95 springs. Now, I got them for free. If I had to pay, I may still have the stock springs under there.
Any new pictures?
I'm having my springs put in today or tomarrow.
I just want to compare the tbird and cougar stance. I'm also useing Mustang front springs @ 1.25" drop from Steeda.
I went back to work so I took some time off but I should be done this week and than I'll post some more pics .
Before....
(http://i216.photobucket.com/albums/cc205/Vinnietbird/DSCF0379.jpg)
After the SN-95 front springs...
(http://i216.photobucket.com/albums/cc205/Vinnietbird/DSCF3639.jpg)
About 1.5 inches in droppage.
Hey Tom, what spring is that? Is 1-1 1/4" after the car settles? Thanks, Herb.
I stopped for a little while to wait for my buddy to plumb my brakes . With the extra time on my hands I installed an 87-88 Turbo coupe 8.8 rear and CHE control arms. I'm going to have the rear rebuilt with a 31 spline Detroit locker which I already have, 4.10 gears which I already have, 31 spline axles and 99-04 brakes which I don't have yet . My buddy who's going to do the rear end work said it did'nt matter to him if the rear was installed or not so I put it in . My only problem now (besides a lack of funds :mad:) is that my fox tie rods are too short to fit my 99 spindles ( I thought I had 98 spindles but they must be 99s) . I called AGR who made my rack and they said 94+ tie rods (inner and outer ) will fit so we'll see in a few days .
Call me 267-625 6054 about the springs I'm not using when you get a chance .
I DO know fox outer rod ends won't work with SN95 inners, or the other way around....no idea if SN95 inner rods will fit a Fox rack.
Turns out the sn95 inner and outer tie rods fit the fox rack and the length is just what I needed .
I already got mine lowered. I used Steeda Sport front spring (1.25" drop) and stock 94-04 Mustang rears. Its totally low as can be. However, I'm considering converting to coil overs on the rear so I can bump up the rate and play with the ride height.
I need rear shocks and since Bilsteins are $120 or so a piece, if you buy from Maximum Motorsport the coil over kit is only about $70 more on top of that. So, thats probably what I'm gonna do. Thanks anyway.
Heres my car with the current set up I listed above.
