Technical => Engine Tech => Topic started by: jcassity on May 21, 2005, 07:02:46 AM
Title: just great, oil light
Post by: jcassity on May 21, 2005, 07:02:46 AM
either i make an oil presure guage or i go and buy one,, maybe ill make one and , not sure.
my oil light gave the wife problems yesterday.  It stayed on and she said she didnt hear nothing clattering.
Ive had this darn engine see sawing on the brink of some oil issue i cant put my finger on.  I rebuilt it and the external oil pump gears are new.  I never changed the pluger thing a ma gig in the timing cover though and thats got me worried.
I could not change the plunger because the entire front and accy things were already mounted.
this  me off.
another thing, the new gears come to you and one is idiot proof, its drivin off the dizzy.  the other one however is marked with an "s" but i cant find any manual that describes which way this goes in so i flipped it around one day last year.
Ive often wondered if i dont have a clogged port in the block somewere,, now that would be a bummer.
man im itching for a change and i just drool over the wife's 351.
I was suppose to go out there today and gut the catalytic,,,, but ford did a number on that one.  Two big ass cats within 10 inches of eachother in a row and the piping is elbowed , smooshed and welded.
So ,,,,,,,was that you bird351 who did some research about the Fram oil filters?  Ive used them ever since they came out with the non skid grip.  are there defects lately with them?
anyone know if i boo boo'd by not changing that presure regulator plunger thing in the timing cover or not?
Title: Re: just great, oil light
Post by: V8Demon on May 21, 2005, 07:35:10 AM
Before you go tearin into the block:
How old is your oil pressure sensor?  These tend to go and are problematic on the 3.8 and 5.0's
Is the pressure low all the eime or just sitting at a light at idle?
Post by: jcassity on May 21, 2005, 07:52:02 AM
the sensor is as new as the rebuild, late 2003.
it did this right after the rebuild but went away. It sticks its ugly head out once in a while.  Yesterday she said it was on while driving,,not good.
i need to get out and go get a tester, i dont think i have anything lying around to rig up an "oil" presure tester.  I think those guages are harmonically sealed in oil themselves.
I'll bet it doesnt do it for me here in a bit.  Im gonna do an oil change as well.  I dont know why,, this will be my third this year. My oil always looks prefect when it comes out.,, slightly dull but you can stil see through it as it runs out.
Post by: Blown306Cougar on May 21, 2005, 08:12:03 AM
i've bin saying this to people for years..
STAY AWAY FROM FRAM OIL FILTERS!!!!!
i did find something for you to read though ;)
http://minimopar.knizefamily.net/oilfilterstudy.html
http://minimopar.knizefamily.net/oilfilters.html
Nick
Post by: TurboCoupe50 on May 21, 2005, 08:54:30 AM
Quote from: Blown306Cougar
Nick
Amen brother..... I use nothing but Motorcraft...
Scott.. unless there is contamination(mostly gas) in the oil, it cannot cause a pressure problem... The filter may not be your problem, but I'd change it and leave the current oil in the engine...
I get a $hit load of rattle on startup with the Blue Bird, and what brand of filter does it have??? Yup a fuggin' Fram...
Post by: cougarman on May 21, 2005, 09:04:14 AM
Nick
I'll third it!!!!!!!!!!!!!!    That's your problem right there!
Post by: Bird351 on May 21, 2005, 11:29:39 AM
Obviously I second (or third or fourth or..) the no-Fram thing stated above, but here's a little something else. A list over at BITOG of who makes what filter:
http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=6;t=002456
There appears to be a little bit of confusion on some of them, though.
Of course, if you're just going to buy a straight brand name (vs. a re-label) like Purolator, it doesn't really matter who makes what else.
I'm on my second SuperTech (Wal-Mart) filter on the 3.8, and no complaints so far. I get good oil pressure to the best of my knowledge, (one of my friends was amazed that an engine with almost 170k miles on it still got around 60 psi on cold startup and no less than 15 psi at idle) no odd noises I can detect, and with my current mix of oil in there I swear it actually seems a little bit quieter overall. Although, I see in one thread they're saying the newer (E-core) SuperTechs might be py. *shrug*
Poking around the rest of that forum I linked to, though.. I see a few thread titles like "another Fram failure", "two costly Fram failures", etc. Now I just need to talk the aforementioned friend into NOT using Frams on my old Escort.
Every time I go to that site, I end up feeling more confused than before I visited it. :dunno:
Post by: jcassity on May 21, 2005, 12:14:37 PM
i just got back and i took the coug out for the trip.  I figured if im gonna blow someithing up,, might as well be on a saturday,,right?
I plucked the old filter off and stuffed a motorcraft one in.
light is still on.  Ive never seen it this steady , it use to flicker a bit once and again but never stay on.  What bugs me is its like it has been building up to something.
how much you guys wanna bet i find low presure,,, my money is on low presure,, the sending unit might be a dud.  If the oil presure is low,,, im making a new rule about rebuilding engines with over 300kmiles.
im gonna pull the sending unit off here in a minute.
I could not find an oil pres tester but for 14 bux i found an oil guage. Good enough for me to use as a tool, ill just modify it a little to suit me and the place it will hand on the wall.
 i wish i could get to that oil presure relief valve in the timing cover.  I suspect that might be stuck or its low oil presure.
ill carb cleaner out the sending unit, it might have crud in it somehow, its just a switch.
Post by: jcassity on May 21, 2005, 04:38:59 PM
startup- 52psi
fully warm-13psi
at 2krpm-35psi
what to do :mad:
Post by: TurboCoupe50 on May 21, 2005, 05:45:32 PM
I like to see 20 lbs or so idling hot, but 13psi ain't the end of the world... Your 2000 rpm psi is fine... If you're getting a low pressure light with 35psi something is wrong with the sender...
Post by: Bird351 on May 21, 2005, 07:38:56 PM
http://www.autozone.com/servlet/UiBroker?UseCase=C001&UserAction=performMoreDetail&Parameters=TRUE%7C%7EOIL+PRESSURE+SWITCH%7C%7ENONE%7C%7ENIEHOFF%7C%7ENONE%7C%7EFALSE%7C%7EFALSE%7C%7E123901%7C%7E1280%7C%7EOP23081%7C%7ENONE%7C%7E%245.49%7C%7EFORD%7C%7ETHUNDERBIRD%7C%7E1986%7C%7ENONE%7C%7ENONE%7C%7ENONE%7C%7EB
$5.49 according to AutoHole. I checked 'cause I thought about offering to send ya my old idiot light sender from my '86.. (I use a 1 1/2" mechanical gauge) but they're cheap enough that it's probably not worth shipping a used one off.
Post by: jcassity on May 22, 2005, 12:16:46 AM
the sender got a good bath with carb cleaner.
i still suspect that presure relief valve is the cause.  I swear to god i cant remember anything going wrong with the rebuild.
i tried to actuate the plunger with a flat blade screwdriver up in the sender hole but i guess its not within reach especially since i dont bend that way :giggle:
if i had it to do over again, i would have changed that thing.  It bugged me back then and it bugs me now. Its probably in a bind.  Its probably gonna roll my mains over if i dont watch out.
no, 13 psi isnt the end of the world ,,thanks for the pat on the back but i know that presure is not worth a dime.  Im only hopeful that the driving at an avg of 2k rpm saves me for a while.
till then, maybe ill dump in some heavy oil.  sound good to anyone?
Post by: CougarSE on May 22, 2005, 03:01:29 AM
hmm, I never know were to go in a situation like that.  will the higher viscosity oil be pumped less easily and lower your pressure and will thinner oil be even worse with it seeping through internal leaks.  I guess you could only try.  I would start with 20w-50.  But what weight have you been running anyway?
Post by: jcassity on May 22, 2005, 10:54:44 AM
10w40.
Post by: Thunder Chicken on May 22, 2005, 01:59:07 PM
I'd try some thicker oil, as you've suggested. Hell, it kept my old Cherokee on the road for two years and my old Dakota is still going with 20W50 (yeah, it's REALLY thick, but the engine is REALLY worn)
Post by: Clayton on May 22, 2005, 08:52:16 PM
Quote from: Paul Flockhart
dude mine does it in idle,  step on the gas its fine...... drop it in gear in idle it comes on.... ive been wondering this question would 8 yr+ oil damage anything over time?  (i changed oil allready)  ive had the valvecovers off and there is a lot of sludge in there (allready cleaned them)  im wondering if that could clog the pickup and or damage anything  clog pushrods blagh that would lead to engine damage
sorry for the hi-jack jcassity
Post by: jcassity on May 23, 2005, 12:33:10 AM
imho,, its pretty hard to clog a pushrod or a lifter.  There just not much room for that to happen unless your oil filter decides to internally expode :giggle: and allow stuff that made it through the sump to enter oil ports.
k,, so 20/50 its gonna get.
well,, heres my new rule of thumb
with an engine over 300k miles.........
dont skip out on..........
pistons
piston pins
crank
broach the rods
new brass rod bushing(where piston pin goes)
line bore and broach the block
completely overhaul the heads totally (no bs lapping on the valves.)
did i miss anything?
Post by: jcassity on May 23, 2005, 01:21:19 PM
time to load up with some cheap 20/50.
if that does not do the trick, im pulling off the external pump , out with the gears and ill manually actuate the presure relief valve.  I only hope this works.
btw,, 4.2 liter stuff is hard to find,, cant get the crank/rods/pistons at advance.  Advance quoted me a couple days ago but the said they goofed.
Post by: jcassity on May 24, 2005, 09:30:31 AM
20/50 oil is in and light is still on.  Ill probably find some time to pull the pump gears and see if i can move the relief valve.  if it moves fairly easy, the problem is elsewhere and it must be my fault.
wonder if they sell higher volume oil pump gears for the 3.8?
maybe the gears from any old high volume pump kit on a ford will fit?
ill bring my old gear set to advance and size them up to a high vol pump kit at advance and see if they do and let you guys know.
Post by: jcassity on May 25, 2005, 01:15:21 AM
i feel like a dumb ass.
I went to advance and they pulled the high volume pump off the shelf for an 88 5.0
as i take the pump out, i say out loud,,"leme see what these gears look like"
the sales guy (manager) just leaned over and watched as i pulled out my own tools to take the cover off.
As the last bolt came out, i said,,, "see, all i want is the gears if they will fit into my 3.8"
His reply,,"i dont really care as long as you buy that pump cause you just voided the warrenty"
I walked out taking the path of least resistance cause it wasnt really that much money.  so anyone wanna by a high volume oil pump?  the gears are useless to my oil pump housing configuration.
i pretty much think he was being an ass.  Come on guys, dont you take the cover off the pump and fill it with assembly grease right off the bat before installing it?
whats all this warrenty  for taking a cover off anyway,, gezz the bolts were hand tight to start with.
Post by: TurboCoupe50 on May 25, 2005, 07:56:26 AM
Return it to another store.... problem solved....
