Technical => Suspension/Steering => Topic started by: jerry.cardona on May 11, 2011, 06:43:31 PM
Title: 1988 Mercury Cougar- Lowering spring- Help?
Post by: jerry.cardona on May 11, 2011, 06:43:31 PM
I need help?? do you think a 1988 mustang lowering spring will work on a 88 cougar?
Post by: Bruce M on May 11, 2011, 07:57:57 PM
Why did you start another thread? You could have asked this in the other thread. A 5.8 is not much heavyer than a 5.0. The srings in a 83 and 88 should be the same.
Post by: bigbada1 on May 11, 2011, 09:00:25 PM
I used mach springs all the way around and it lowered the car a lot I think that if I would have not went with the lower adjustable ride height arms in the rear I would be rubbing all the time now the only time I hear it rub is going threw a sever dip at high speed
