Technical => Body/Appearance/Interior => Topic started by: mcb82gt on May 05, 2011, 09:36:28 PM
Title: dead pedal install
Post by: mcb82gt on May 05, 2011, 09:36:28 PM
First off the search function either sucks or I cant use it correctly!
It seems where I want to bolt the dead pedal to the sheetmetal, there is the bracket for the push plug for the trim piece.  I cant seem to fit it closer to the firewall, there is not enough room for it.  What the hell have you guys done?  It just bolted right in on the Mustangs. :shakeass:
Post by: gumby on May 05, 2011, 10:40:22 PM
I was hoping I had a pic w/o the panel in place, but no luck. You can see mine is below the push pin though
(http://i25.photobucket.com/albums/c73/gmby23/87%20turbocoupe/67e14546.jpg)
Post by: hypostang on May 06, 2011, 01:04:50 AM
I bolted mine right to the push pin bracket
Post by: vinnietbird on May 06, 2011, 08:33:56 AM
Mine is also a little under the push pin hole.
(http://i216.photobucket.com/albums/cc205/Vinnietbird/000_0924.jpg)
