Car is an 88 TC, no mods to back end of it.
I have a whine coming form the back end when making low speed turns... I thought it was a brake dragging but thats all knew and greased slides now. Can it be a axle bearing or something?
Likely a wheel/axle bearing. Not entirely uncommon in these cars
Know what I'm doing this weekend.
If you are going to pull it down and take the axles out might as well get a clutch pack to rebuild the trac-lok if it has not been done.
Darren
How involved is that? I planned on running it on the lift and just popping c clips off and taking axles off, kinda new and unknown territory for the trac lock rebuild.
Go here:
http://www.corral.net/tech/drivetrain/gears.html
Chris lives close to Houston, TX and rebuilt my T-5 when I lived in Beaumont and this guy is really good at explaining things. Scroll down to the "Traction-lok rebuild:" section and its pretty straight forward if you have any mechanical inclination.
Darren
