Technical => Electrical Tech => Topic started by: c_bass16 on April 28, 2011, 12:26:58 AM
Title: blinkers and dash cluster
Post by: c_bass16 on April 28, 2011, 12:26:58 AM
OK, so I've been reading about others that have had some electrical problems and I don't know if they were quite the same as the issue I'm having.  I'm beginning to think it may be a short, and not just a fuse.  (although I don't have the car with me today, and won't be able to check fuses till this weekend)
1987 Cougar XR7
SO, anyway. I went home for Easter break and as it began to get darker...I flipped on my head lights.
As I did, my digital instrument panel immediately went out.  There is still an illuminated panel, but it's the digits that don't light up.
The only other thing I have noticed is that the turn signals don't work either.
Does this sound like a short circuit or a simple fuse issue?  Since it happened as I turned on the lights, I would assume it to be a fuse, but again...I won't be able to check till this weekend.
Thanks
Post by: Trinom on April 28, 2011, 09:29:14 AM
And what about bad grounding? Do the turn signals work (outside)?
Post by: 88CougarGT on April 28, 2011, 09:35:56 AM
I've had this happen.  For me, it was the crummy connectors in the back of the cluster.  Mine has been out a few times and may have contributed to the problem.  I just pulled it out, cleaned the contacts, and put it back in.
Post by: c_bass16 on April 29, 2011, 12:00:52 AM
Quote from: Trinom;358859
Nope, they don't work inside or outside
