Marketplace => T-Bird/Cougar Parts & Cars WANTED => Topic started by: 50tbrd88 on April 27, 2011, 09:58:12 PM
Title: Center Console for 5 spd
Post by: 50tbrd88 on April 27, 2011, 09:58:12 PM
I am gathering parts for my 5-speed conversion.
I bought a TC center console many years ago but now that I have pulled it out of storage, its a little rougher than I remember and has a few parts missing.  The tabs that mount the shifter bezel are broken, console lid is rough, etc.
I would be interested in a complete, NICE, console for a 5-spd or console shift car with all bracketry,etc.  I have grey interior (not raven, the lighter grey) and  power mirror, power windows, and power driver's seat switch (the TC console I have now has the correct switch panel for my car so I could just use it if necessary, but it is also a little beat up).
After reading Eric's coolcats writeup, I am also now realizing I don't have all three of the brackets to mount the console correctly, so at the least I would be interested in those if no one has a complete console available.
I am going from a digital dash, column shift car so I hope I'm not getting into a nightmare swap here.  Any helpful hints from veterans of this swap would be appreciated.
Post by: sarjxxx on April 28, 2011, 04:32:18 PM
I think I know what bracket you're missing... probably the one that is under the radio? If its that one well unfortunately I can't help you out as I had to pull that one from the console equipped JY car at the yard but if you need one of the other two I can help you out. Also if you need the upper bezel for the shifter I can provide you with that too as I mistakenly bought one thinking it would work for my auto conversion:dunce: All the rest of the stuff is pretty much useless but If you end up piecing together a set and still need something PM me and maybe I can send you a couple pieces.
Post by: 50tbrd88 on April 28, 2011, 06:13:21 PM
Quote from: sarjxxx;358891
Thanks man.  You are right, one of the ones missing hooks the console to the lower part of the dash below the radio and HVAC controls.  I have found some people parting out TC's on eBay and have sent them messages.  I think I have the right shifter bezel already, but I may have to take you up on the other two brackets.
I kinda need to get started on this ASAP but I have to have the brackets to properly mount the console before I cut the hole for the shifter.  If I don't hear anything from these eBay guys soon, I will PM you.
Post by: vinnietbird on April 28, 2011, 06:23:19 PM
I think I have the console brackets in the garage all zip-tied together. If so, they're yours for shipping costs. I'll let you know tomorrow morning.
As far as the console, Mine was tan, I dyed it to match my interior, and it turned out excellent, and if done right, the dye is very durable and can be treated like a factory piece.
Post by: 50tbrd88 on April 28, 2011, 07:32:57 PM
Quote from: vinnietbird;358897
Thanks Vin!  You are the man....just let me know!
I have never used dye on interior stuff but I may end up going that route eventually if I find a nice console in another color. Has anyone had an upholsetery shop re-cover their console lid?  If I had a nice console lid and a new decal for the switch panel (didn't someone on here used to make those?) I'd be in decent shape.
Post by: vinnietbird on April 28, 2011, 09:14:15 PM
What color is the console lid? I have decals for the control panel (PM me for a "how-to" on them. Mine turned out great. As far as using the dye, nothing to it. Surgically clean the console (dis-assemble it first). I used isopropyl alcohol. Then, I sprayed the whole thing with adhesion promoter, let it dry, then applied light coats of the dye, letting it dry between coats until I got the color and coverage I wanted. Been great for a couple or so years, and is tuff.
Here's my console plate....I did it last year and it still looks excellent, even after the wicked hot Oklahoma summer....
(http://i216.photobucket.com/albums/cc205/Vinnietbird/DSCF8275.jpg)
Post by: 50tbrd88 on April 29, 2011, 08:46:38 AM
Console itself is the lighter grey, the lid itself is more of the dark grey or raven color.
Post by: vinnietbird on April 29, 2011, 09:24:51 AM
Sent a PM to you. It should make you happy.
Post by: 50tbrd88 on April 29, 2011, 02:16:41 PM
Quote from: vinnietbird;358953
PM'd you back dude.:bowdown::bowdown::bowdown::bowdown:
(and yes I am happy)
