Technical => Engine Tech => Topic started by: 87tbird5.0 on February 22, 2011, 09:19:07 PM
Title: underdrive pulleys?
Post by: 87tbird5.0 on February 22, 2011, 09:19:07 PM
first of all what do they do? do you gain hp? and do they work with all the stuff on my car (smog,A/C)? its a 87 tbird 5.0
Post by: vinnietbird on February 22, 2011, 09:30:01 PM
Personally, I don't think they're worth the money unless you get them super cheap,and even then, I don't believe you can tell a difference. If someone installed them on your car, and never told you, I don't think you would pick up on it. They are pretty to look at if you get the aluminum, but the money could probably be better spent elsewhere.....my own opinion.
Post by: flylear45 on February 22, 2011, 09:40:50 PM
+1
The engineers designed your accessories optimized to run at the rpms they run based on the stock pulley sizes. Those guys are pretty smart. Not worth the trouble IMHO.
Post by: 87tbird5.0 on February 23, 2011, 07:21:31 PM
ok thanks i was just wondering cuz i always hear about them didnt know if they were worth it or not. might take that money and buy a x pipe or something
Post by: QUICKSHIFT on February 23, 2011, 07:43:42 PM
If you're going from a 2.73 gear to a 4.10 you will see a difference due to the fact that your engine is turning more RPM and the parasitic losses increase. Under drive pulleys on 2.73s or 3.23s and you're asking for trouble with cooling, charging and A/C functions.
Post by: 87tbird5.0 on February 23, 2011, 08:26:01 PM
i have a 8.8 with 3:31 gears
Post by: QUICKSHIFT on February 23, 2011, 10:59:19 PM
Quote from: 87tbird5.0;353754
 I'd pass.
