Technical => Electrical Tech => Topic started by: rdg2010 on February 07, 2011, 02:23:50 PM
Title: 1988 cougar 5.0 idles high after using cruise control
Post by: rdg2010 on February 07, 2011, 02:23:50 PM
after using cruise control the car will idle at about 2000 rpm for a few days then return to normal, i replaced the trottle position sensor no change any help would be great
Post by: jpc647 on February 07, 2011, 03:38:32 PM
Tps?
Post by: cougarcragar on February 07, 2011, 06:20:53 PM
It almost sounds like the cable from the cruise servo is binding, and in turn, holding the throttle blade open a small amount.
It's easier to eliminate the other variables. You've already replaced the TPS, so why not remove and clean the IAC valve. They tend to get carbon build-up and have negative effects on the idle quality. If that checks out, you can look into the cruise servo and/or its cable to the throttle body.
Post by: 87tbird5.0 on February 07, 2011, 07:40:38 PM
clean the IAC made a huge difference in my car somtimes it would idle fine and then it would idle at 1400. make sure you buy a new gasket because i tryed reusing mine with some rtv didnt work that well.  when i cleaned mine i took it off and let it soak in a gallon can of carb cleaner and then cleaned it more with a spray can then put it back on and it makde a world of difference.
also take the intake tube off and start the car and shoot some throttle body cleaner in that too at the very top of the throttle body i found alot of junk
Post by: jcassity on February 08, 2011, 12:02:40 AM
pull your codes with a paper clip.
you can also pop the cruise cable off the throttle body and see if the cable slipps easy in and out.
