Technical => Engine Tech => Topic started by: Blackbird1 on January 04, 2011, 07:06:27 PM
Title: 2.3 Ignition Issue
Post by: Blackbird1 on January 04, 2011, 07:06:27 PM
My 88 TC has an ignition break up problem above 11 pounds of boost. I have a boost control valve so I have set the boost at 10 psi and everything is normal. Timing is set at 12 degrees, plugs and wires are new. Dist cap looks good. Here's the kicker, if I shrink the plug gap below .030 and advance the timing, it runs good up to 15 psi or where ever it starts to detonate depending on air temp. I'm thinking a coil. Any suggestions would be appreiciated.
Post by: mcb82gt on January 04, 2011, 07:35:45 PM
Use only motorcraft ignition parts on the 2.3T  Sounds like youve narrowed it down, coil,plug wires.  What brand of wires?
Post by: Blackbird1 on January 04, 2011, 07:40:18 PM
I had a set of Taylor wires on it originally, but then put a brand new set of Motorcraft wires on it and it didn't change.
Post by: Cougar8775 on January 04, 2011, 09:28:16 PM
sounds like the boost is blowing out the spark. id say gap em down a bit and see how she runs.
Post by: gumby on January 04, 2011, 09:35:22 PM
Quote from: Blackbird1;348375
where were you trying to set the gaps? generally, there is no reason to be wider than .030" on these motors.
Post by: Blackbird1 on January 04, 2011, 09:50:18 PM
Plug gap spec is .032-.036. That would be my reason.
