Technical => Engine Tech => Topic started by: jpc647 on December 22, 2010, 11:53:44 AM
Title: Check Engine Lights Flashes-The Saga Continues 2/10
Post by: jpc647 on December 22, 2010, 11:53:44 AM
On the way to work this morning my check engine light came on. I was going up a large hill at 62mph. It comes on for 10 secs or less, the engine looses power, and then all is fine. When it happens, I usually floor it, just to get a little more out of it in case something bad happens, like the car shuts off.
Now this only happens going up hills at similar speeds. And it only happens once a month or so. If I pull codes, there is not any new codes, just the same ones which have been there forever. Is it possible the car isn't storing it? How can I determine which one it is?
I'm at work, shirt and tie job, so I can't be playing around with it at work, but I thought I would throw it one here just to see if anyone has advice.
Post by: 20thanniver-ls on December 22, 2010, 05:32:38 PM
I *think* I read somewhere that an o2 sensor could intermittently fail and cause CEL to come off and on.
Post by: Thunder Chicken on December 22, 2010, 07:18:40 PM
You sure the car isn't stalling? Usually a check engine light will come on any time the key is on but the engine isn't running. The spinning drivetrain will keep the engine turning even though it's dead and will restart it once things come back alive...
Post by: jpc647 on December 23, 2010, 08:28:53 AM
Quote from: Thunder Chicken;346568
Yeah its not stalling. The car has just shut off before while driving down the road. IT just seems to really stumble and almost act as if the car  was real cold and you stepped on it hard, it like "shutters" for those couple of seconds and then all is fine. Car is an 87 t-bird 5.0 with a factory AOD and a factory 3.08 rear(original to the v6 car).
Now where it flashes and goes out, and I ran codes last night, which was 4 starts/trips later, shouldn't the code be in the memory? Therefore does this mean this check engine light coincides with one of the pre-existing codes stored?
If the above statement is true, why doesn't clearing the codes remove any of the codes? If it doesn't flash, shouldn't the code not be present until it does.
Post by: jcassity on December 24, 2010, 09:58:39 PM
a check engine light usually means a hard failure.  flickering check engine light would be pointing to a hard failure to the oil pump if it happens when running.  is this a basic digital cluster with buttstuffog fuel / temp needle?
If i had a check engine light coming on, I would be checking and double checking things out.
Start by cleaning the coolant temp sensor, air charge temp sensor, check the tps voltage, and also put up the codes you have on now.
there are sooooo many things to think of but if your codes are available, post them in this thread.
If you have looked at them and nothing makes sense, then that would be the only time i would suggest shot gunning your approach to troubleshooting.
Perhaps you can set up a couple of monitoring circuits ..as an example...
find a rotary "selector" switch from like radio shack.
you can temporary tap into multiple devices and use your meter to monitor voltage levels.
If i were you, I would start at the ignition switch first.,, too hard to tell right now.
Post by: jpc647 on January 05, 2011, 11:46:21 AM
So a momentary flickering of the check engine light means a failure in the oil pump? Yes this is a standard gauge cluster with the buttstuffog fuel and temp gauges.
Post by: dragon574444 on January 05, 2011, 01:45:39 PM
I know that when my car had problems with "shuddering" or "bucking" uphills was due to my fuel pump. The in tank fuel pump has a rubber hose between the actual pump and the metal lines for the sending unit. That rubber hose disintegrated over time and had a fair sized hole in it. The car was fine in park, fine on flat roads, but going up hills was not fun. I don't recall watching the check engine light, I was usually busy mashing the throttle in hopes the car didn't stall out! I also don't think that the computer can check to see if the fuel pump is failing in such a manner, so that might explain why you don't have any new codes.
YMMV of course, this is just what happened to me.
Post by: hypostang on January 05, 2011, 02:02:04 PM
Quote from: jpc647;348468
Not necessarily, but it certainly could  ..aftermarket gauges can really be your friend
Post by: mcb82gt on January 05, 2011, 03:05:35 PM
I would guess the engine is missing.  Ignition or starving for fuel-too lean to ignite properly, or plugs.
Post by: jpc647 on January 06, 2011, 09:20:05 AM
Quote from: mcb82gt;348479
Plugs, wires, cap, and rotor and brand new. Like from 3 weeks ago. This is interesting. I'll change the fuel filter tonight, I've been meaning to for a while now. I hope it's not a fuel pump. It's too cold out to want to do that now.
Post by: jpc647 on January 06, 2011, 09:24:54 AM
Quote from: dragon574444;348474
Did the engine light flicker, or stay one?  Just curious. Fast blinks or slow ones?
Post by: Aerocoupe on January 06, 2011, 10:32:09 AM
It could be the oil pressure sending unit.  I had one go intermittent on me and then it finally died.  They are cheap and easy to replace.
You should be able to clear all of the stored codes in the EEC with the hand held code reader.  If you clear them and they show back up then you need to fix them.  From what I remember the techs at Ford had to fix the codes as they came up as other codes could be hidden behind it.  py way of describing it but if you did not clear one round of codes then the EEC may not be able to alert you to additional codes being covered up by the first one.  Its been a while since I have dealt with the older generation of the EEC's.
Darren
Post by: jpc647 on January 06, 2011, 12:54:02 PM
Quote from: Aerocoupe;348568
Darren
Wouldn't that make the oil pressure idiot light come on, and not the check engine lights?
Post by: Aerocoupe on January 06, 2011, 02:29:16 PM
If that was the case (I am pretty sure you are correct) then I would suspect the oil pump failing would do the same thing.  I was just throwing it out there as it was a cheap and easy fix on my car when it had the old TB injected 302.
Darren
Post by: softtouch on January 06, 2011, 03:54:32 PM
Quote from: jpc647;346691
Lets try to clear up some of this code mystery.
The codes come in three categories. The meaning of some codes change depending on which category it is in.
KOEO gives two categories of codes:
1. On demand codes. These read out first. They are the results of the self tests that run when you "pull codes". They are "faults" present at the time of testing. They are not stored in the KAM(Keep Alive Memory). The only way to get rid of them is to fix the problem.
2. Memory (or continuous) codes. These read out second, after a separator pulse or a 10 on the code reader. These are "faults" collected and stored during drive cycles.
These can be reset by disconnecting the jumper from the self test connector pig tail wire or disconnecting the pig tail wire from the code reader while the codes are reading out.
Rerun the KOEO to verify they cleared.
3. KOER codes.
What codes do you have and what category are they in?
Post by: mcb82gt on January 06, 2011, 06:28:30 PM
I still dont see how this could be oil or oil pressure related, but Ive been wrong before.
Ignition is new, what is left to fall out under load....fuel??
Post by: Aerocoupe on January 06, 2011, 07:36:31 PM
Can you get a pressure gauge on the schrader valve and check the fuel pressure?
Darren
Post by: mcb82gt on January 06, 2011, 08:02:37 PM
Good call.  I used to do that on my Mustang turbo GT.  Hook it up on the schrader valve and route it under the hood and tape the gauge on the windshield.  It would allow me to see it under boost......also alow YOU to see it under LOAD....
It was a cheap setup I got from Harbor Freight locally.... cheap, like $20 or less. Its been awhile.
Post by: jpc647 on January 21, 2011, 12:29:37 PM
Quote from: softtouch;348587
3. KOER codes.
I retrieve codes by using the jumper style method. This:
How to Prepare for the Self-Test
To check for codes without buying a code reader is simple. If your EEC is wired correctly, the engine light works, and there are not any electrical faults in the vehicle you can get the codes out of your EEC.
1. Turn key to OFF.
2. Get a length of wire that can connect the STI to the negative battery terminal or body ground.
3. Ground the Self-Test Input.
4. Get some paper and a pen.
5. Get comfortable in the drivers seat.
6. Try to keep your self from getting distracted from here on.
7. Turn key to RUN.
8. You will hear some relays engage and the fuel pumps prime the system. This is the EEC beginning the test.
9. When the fuel pumps stop be ready to count!
And I get the codes 67, then 1, then 63, then 33.
Post by: softtouch on January 21, 2011, 02:48:08 PM
Quote from: jpc647;350377
1. Turn key to OFF.
7. Turn key to RUN.
This proceedure did the KOEO (Key On Engine Off) self test.
67 is an "on demand" code.
1 is the separator pulse.
63 and 33 are memory codes.
Run the test again, and while the memory codes are reading out, disconnect the jumper wire.
Turn the key off. Reconnect the jumper wire. Run the test again. The memory codes 63 and 33 should be gone. Remove the jumper wire.
Start the car and let it idle for 20 minutes. (warm up).
Turn the engine off. Install jumper wire. Start the engine and record the KOER (Key On Engine Running) codes.
Let us know what you get.
Post by: Aerocoupe on January 21, 2011, 05:59:26 PM
I looked up what each of the codes mean from the two sources I have and this is what they are:
Code 67 (KOEO) shows to be a Neutral Drive Switch (NDS) circuit failure, circuit open, or A/C input high
Code 63 (Continuous Memeory) shows to be a Throttle Position (TP) circuit fault, below minimum voltage
Code 33 (Continuous Memeory) shows to be the EGR vavle not opening properly
Clear the codes out like softtouch suggested above and post back with what you find.  On another note, a code scanner for one of these cars is about $30 at AutoZone and is a whole lot easier than the paper clip trick and it comes with a book that lists the codes.
Darren
Post by: jpc647 on January 21, 2011, 10:40:13 PM
Quote from: softtouch;350392
I have. That is how these three codes are the only ones left. I finally was informed how to fix the code 67, from Joel over at SBFTech. I'm going to do that tomorrow, hopefully. I have changed the TPS, with one I got from vinnie, and the code went away for like 2 days. So I'm not sure about that. I have also changed out the EGR valve twice, and I have not been able to get the code to not show up. However, with the KOEO test, the EGR valve not detecting might not be a problem.
Again, I have cleared the codes, and these are the three that have stayed.
Post by: softtouch on January 22, 2011, 12:49:53 AM
Quote from: jpc647;350446
Are you saying you cleared the codes and they reoccured after driving the car or they never cleared?
Post by: jpc647 on January 22, 2011, 10:02:24 AM
Quote from: softtouch;350454
Well the code 67 never goes away. The TPS one did, temporarily for a little while, and the EGR one did not go away. Someone posted on one of my other threads it might be because I did the KOEO test.
Post by: softtouch on January 22, 2011, 01:12:51 PM
Quote from: jpc647;350477
This statement is confusing. The reason I asked you to rerun the KOEO after resetting the memory codes was to insure the program in the EEC was working right and resetting the codes. I am gussing you are operating from memory or notes and did not actually do it.
The KOEO and KOER tests will not set any memory codes.
The KOEO test will set an "on demand" EGR code if the voltage from the EVP (Egr Valve Position) sensor is out of specs for a closed valve condition.
The KOER test will set an "on damand" EGR code if the voltage from the EVP sensor is out of specs for an open valve condition.
Memory codes are stored in the KAM (Keep Alive Memory) while driving the car.  If they only show up  as memory codes and not on demand codes, they are intermittent failures.
Post by: flylear45 on January 22, 2011, 01:16:55 PM
Symptoms kind of match up to an EGR problem.
Post by: jpc647 on January 31, 2011, 06:10:40 PM
Quote from: softtouch;350506
This statement is confusing. The reason I asked you to rerun the KOEO after resetting the memory codes was to insure the program in the EEC was working right and resetting the codes. I am gussing you are operating from memory or notes and did not actually do it. .
I actually did clear the codes. But again, immediately the code 67 one kept coming back, but that has been fixed.
I appreciate the information on the “on demand” EGR operations. The codes are always in the stored memory codes, or the KAM. Because the problem happened again tonight,  I ran codes when I got home, and I got 11, 11, then a 1, then 63, 33, 63, 33.
Now I’ve been told a couple of things on how to clear the stored codes. Some say remove the pin in the process of the test, other say disconnect the battery. So I did both last time (just over a week ago) when I fixed code 67. Therefore, these must have popped up again. Therefore they both showed up again. I have swapped them both, but I’ll go out there tonight and swap my last EGR valve and see. Could it be that the codes are not deleting? What else can I do to delete them?
Now the problem happened on the way home from work. This time, I was doing 83 on my speedometer, which is roughly 76mph. I started to ascend up a fairly steep hill, and when under load, the car sorta losses some ohmpf, but I think all stock 5.0’s probably do. Anyway, the check engine light comes on, and I feel a jerk, almost like a down shift, except it doesn’t downshift. If I push on the gas a little to accelerate, the light goes off and the problem goes away. But the light came on, so that means the computer should store a code, right!?
Post by: jpc647 on January 31, 2011, 06:11:16 PM
Quote from: flylear45;350507
Interesting, I do get an EGR code. Maybe there is some merrit.
Post by: Aerocoupe on January 31, 2011, 08:09:04 PM
Have you tried a new TPS (read #21) or at least checking the one you have to make sure it is at a good starting voltage and when swept from idle to WOT that it reads smoothly and has no dead spots?  Another thing you could be dealing with is the black and white connectors between the main EEC harness and the injector harness.  I did not read where you have checked fuel pressure (posts #7, #17, & #18).  I would think the the fuel pressure would be something that you would need to eliminate quickly.
Darren
Post by: jpc647 on February 01, 2011, 09:42:10 AM
Quote from: Aerocoupe;351379
Darren
Yes, I have checked the TPS. A few times. I've swapped it to another one as well. I checked the new one for dead spots and voltages as well. I got nothing out of the ordinary. I checked the unit bone cold, and when the motor was warm (just to see if there was a difference). They seemed fine. However, I did have a problem with the engine revving up a bit when at a stop light, etc causing the car to lurch forward a little. The changing of the TPS seemed to fix this. I could be a coincidence, but after swapping it, it hasn't done it.
The EGR valve has been swapped. With two others. I was going to try one last EGR valve last night, but I was too cold. I'll try to get out there tonight.
I think the problem is I had a couple of different threads, each with one single problem, but in each I posted the couple of engine codes I have, so each thread sorta got intertwined. The fuel pressure was checked and appears fine. That was in this thread post 45:
http://www.foxtbirdcougarforums.com/showthread.php?30462-Fuel-Pumps-Anyone-who-has-bought-a-new-one&highlight=
Post by: softtouch on February 01, 2011, 02:45:45 PM
Quote from: jpc647;351361
I can see I am having difficulty explaining the difference between on-demand codes and memory codes.
The 67 was an on-demand code. It was not stored in the memory. It didn't "keep coming back" it was always there and the KOEO self test kept finding it.
You never mention running KOER self tests. Just getting home with the car all warmed up is the perfect time. Code 33 is an EGR valve not opening problem. The KOER will test the EEC's ability to open the EGR valve.
Yes disconnecting the battery will reset the memory codes. But it clears everything in the KAM, not just the codes. You will have erratic idling until the computer reestablishes some tables it keeps in the KAM.
Once again, if you rerun KOEO after clearing the codes and they are not there, then you have successfully cleared the codes from memory. If problem reoccures while driving, the EEC will store the codes in memory again.
Right
Post by: jpc647 on February 01, 2011, 08:36:22 PM
Alright. I think I understand the difference between the two types of codes now. I ran the KOER test tonight, got only code 33. I didn't floor the car though, went down between half and 3/4. I ran the KOEO test tonight and removed the jumper pin as the first memory code was flashing. Now both saved codes should be gone.
Post by: Haystack on February 01, 2011, 10:49:33 PM
My egr valve vacuum line broke, so I capped it. It no longer functions. It has not effected emissions or drive-ability in any way. If you still suspect the egr is bad, plug the line, and make sure the diaphram is not stuck open. Then you will not have to worry about the EGR code and will know if it is effecting anything. If you get the check engine light to come on at all while the car is running, your ECU is in failsafe mode and something is not working correctly. You should either get a code, or the computer is screwed, or you have a short somewhere.
I belive that having a bad ground to the ECU can not only cause problems like you have been describing, but it will throw a TPS code because the TPS is grounded by the computer. So if you have an intermitent ground, it will throw a tps code.
I have not been trying to sound rude, but over the internet it sounds that way. read here.
http://fordfuelinjection.com/?p=44
check everything it tells you to, and check grounds on the pins and resistance to those pins. It only takes one wire or connector to unplug or be loose to cause a problem. Also, check and clean the salt and pepper connections.
When you do a base idle reset, your supposed to drive the car immediately after plugging back in the IAC.
If this doesn't help you, try another computer. I'll bet someone has an SO one they will practically give away. Report back what you find with the resistance and voltages on each sensor and any/all codes. Then someone smarter then I can help you from there.
Post by: Haystack on February 01, 2011, 10:59:24 PM
http://fordfuelinjection.com/?p=85
What all your sensors look like, and what they do.
http://fordfuelinjection.com/?p=10
Actuators
http://fordfuelinjection.com/?p=11
A simplified version of what the computer is doing, and what sensors it is using.
http://fordfuelinjection.com/?p=64
There used to be a map of what voltages should be to test them. I cannot find it.
I am sure I have linked you to many, if not all of these in the past. Then you started a new thread saying it was a new issue.
Post by: softtouch on February 02, 2011, 12:32:01 AM
Quote from: jpc647;351505
So the 33 code is not an intermittent problem that only happens when you are driving. The KOER test found the problem and posted an on demand code 33.
The EGR valve is opened by vacuum. The EEC controls the vacuum to the EGR with the EGR Vacuum Regulator. This is a solenoid controlled vacuum valve. It should have a connector from the cable harness plugged into it and two vacuum lines on it. One vacuum line from the vacuum tree and one to the EGR valve.
The EGR Vacuum Regulator is on the back side of the right strut tower.
Post by: softtouch on February 02, 2011, 01:29:09 AM
If you are talking about the "goose" test, you momentarly floor it when you get the single pulse. It is testing if the TPS voltage can get up to WOT level.
Not all versions of the EEC have this test.
Other than that you should not have your foot on the gas pedal while KOER is running.
Post by: softtouch on February 02, 2011, 02:02:46 AM
Your 63 code is an intermittent TPS voltage too low.
This proceedure is called the wiggle test in the shop manual. It lets you wiggle cables and tap on stuff etc. to see if you can duplicate the problem.
If you have a helper, have them sit in the car and watch to see if you can make the check engine light flash. If not hook a test light or an buttstuffog meter between the self test connector pin 4 and positive battery post. This will in effect put the check engine light under the hood where you can watch it.
Run KOEO and clear the memory codes.
Run KOER. Wait for two minutes after it finishes outputing codes. It is now in "Continuous Monitor Mode"
Wiggle and tap stuff and see if you can make the check engine light flash. If you can, run KOEO and see if you stored a 63 memory code.
Post by: jpc647 on February 02, 2011, 08:17:23 AM
Quote from: Haystack;351540
Actuators
yes you have linked some of these. I did the 10 pin connector thing, I spread all the pins out, etc. I read through the sensors and the actuators page before, just for reference. There isn't any troubleshooting in them though.
Post by: jpc647 on February 02, 2011, 08:18:42 AM
Quote from: softtouch;351543
Yes, that must be what I was referring to. I printed off the instructions for this test off the fordfuelinjection.com website and did it when I went home. It states sometimes different models won't have certain tests, but I went through all the ones it listed anyway, just to see.
Post by: jpc647 on February 02, 2011, 08:19:57 AM
Quote from: softtouch;351544
Alright. I will have to do this tomorrow. It's another day filled with snow, so working on the car today is pretty much out of the question. I have a garage, somewhere in the backyard, under about 4 feet of snow.
Post by: Haystack on February 02, 2011, 07:31:05 PM
There is tons of trouble shooting in those links. Resistance and voltage is a function of electricity and your cars ECU. It lists the minimun voltage acceptable for some things, and the maximum resistance of others. It even shows you how to check grounds between your battery cable and the computer pins.
If you don't think thats important, I don't wonder why your having problems.
Post by: jpc647 on February 03, 2011, 08:44:39 AM
Quote from: Haystack;351605
I'm sorry. You are correct. I normally check the forum at work, and the sub links in the links you posted(like the EGR valve has it's own link to a separate page) do not show up as links. It's just the way the network configures things. Kind of glad you said something, because it m,made me look at it again because I couldn't for the life of me understand what you were referring to.
Post by: jpc647 on February 10, 2011, 06:54:18 PM
Well the problem is getting worse, way worse. Like every time I go up a relatively steep hill I have problems. I ran KOEO codes tonight, got a code 34 as an "active one". So the EVP is above it's limit. What could cause the whole EGR system to be all screwed up!?
In the continuous memory (after the 1 blick of the check engine light) I got a 63 and a 33.
Now I have swapped EGR valves(with the EVP's) a couple of times now. I have three. I also swapped out the lines which run from the regulator to the egr valve and to the back of the plenum. Mine has a pin hole in it that I found. The "new" one clearly had broken before, and it looks like someone used heat shrink tubing to fix it.
I'm going to swap out the regulator and reservoir tonight, see if it makes and difference. Other than this, I'm not sure what to do. I can hear a vacuum leak in the dash when the car is under load, mostly through 1st and second. When it shifts to 3rd, it goes away until a bout 40ish when it is about to shift into overdrive. Not sure if that means anything.
Post by: jpc647 on February 10, 2011, 09:01:39 PM
Well I tested out the regulator, it appears fine. The resitance checks out okay and the "mechanical test" vacuum from top slot was not there. So I think that should mean thats okay. I swapped out the little vacuum resovior, and then unplugged the EGR valve. I capped the vacuum line and unplugged the EGR valve. Not sure if thats how to "eliminate" the EGR valve or not. Please chime in if not.
In all seriousness I'm so fed up with this ed car, should I break down again tomorrow, I'm going to light the car on fire to stay warm while I wait for the tow truck. I don't know what else to do. I'm crazy, its 12 degrees outside and i'm fighting with a 24 year old car to make it to work another day. I need my head examined.//end rant.
Post by: sarjxxx on February 10, 2011, 09:13:11 PM
Time for a 4 barrel.
Post by: jpc647 on February 10, 2011, 09:14:25 PM
4 Barrel?
Post by: sarjxxx on February 10, 2011, 09:43:45 PM
:giggle: carburetor dude
Post by: jpc647 on February 10, 2011, 09:48:28 PM
Quote from: sarjxxx;352561
Yeah, I realized that after I walked away... But I think I have a more serious problem than that... Believe it or not, I probably have a bad head gasket on my 5.0. Which would explain a couple of things... The elevated temperature, the wierd goop in my oil fill cap, etc. I need a bomb, or a Gatling gun, is what I need.
Post by: sarjxxx on February 10, 2011, 09:49:54 PM
or a 3.8 :rollin:
Post by: jpc647 on February 10, 2011, 09:51:50 PM
Quote from: sarjxxx;352563
or a 3.8 :rollin:
been there, done that. Had a 3.8 that ate a head gasket. now I have a 5.0 chewing through one. I've had a 4 banger, it didn't idle all that great, but it sure did ride nice. I liked it.
Post by: Aerocoupe on February 10, 2011, 10:08:31 PM
You have to correct all of the mechanical problems first.  Kinda hard for the EEC to do its job if the engine is not up to par.  A head gasket job is not that bad if you have a garage you can pull the heads in.  I would stongly suggest that you take the heads to a shop and have them check them to make sure thay are flat.  Would suck to change the gaskets only to have it blow out again.  Do you know anyone with a leak down tester?  That would be the best way to determine if your problem is head related and which cylinder has the issue.
Darren
Post by: Haystack on February 10, 2011, 10:57:36 PM
So what were the resitances on the grounding pins to the eec and the battery cable? My bet is that your eec has something bad inside it, your missing one or more of the grounds, and I'm still sure you timing is off. But I can only guess from what you tell us.
The egr does not do anything as long as there is no vaccum to it. You will not get a check engine light, but you will get a code. When you get a code your egr is not finctioning to begin with.
The reason for checking your grounding resistance is to make sure you will check the wires. If the wires check out, then its the computer, or a sensor. So go and check your grounds. Report back your finding and I will send you my s.o. computer for free.
Post by: jpc647 on February 11, 2011, 06:42:24 PM
Quote from: Haystack;352573
I get the code and a check engine light though.  So it tried to function sometimes, right? I may be missing a ground to the computer. My nuetral safety switch wasn't grounded, so I spliced into that pin and grounded it. Got rid of code 67. But I had the EGR valve code before I grounded that pin. Can you explain the grounding the pins to the battery? Which pin? The pin 33 from the regulator?
Post by: Haystack on February 12, 2011, 01:02:33 AM
You do not ground to the battery. Any metal on the body of the car is grounded. First, rule out the wires by checking to see if they are even connected. Do a resistance test, as per the links I keep linking you to, and you keep ignoring. If all your grounds are good, then move onto the positive and do the same thing.
Ignore the egr code. If your getting a code it isn't working, so you don't have to worry about it if you capped the vaccum leak.
Then after that, check the sensors resistance and voltages to make sure they are good. If they check out too, throw a new computer in the car.
The codes litterly tell you what is wrong. If your getting a check engine light flashing and don't get a code for it, something is screwed up. I'm done holding hands. Everything is right infront of you. Take mine, and others advise, oe don't. Its up to you to figure out. Not me or anyone else.
If your having problems with the way things are explained, just say so. I really don't think I can paint any better picture of "prove" that something is worth doing if your not going to even look at it.
Post by: jpc647 on February 12, 2011, 01:28:29 PM
Read what you typed. I was asking for clarification on the first sentence. Hence why I asked about the battery cable.
I checked the resistance to the EVR selenioid. It was 39.5 ohms. If thats not what you were suggesting I check, then I apologize, I guess I don't understand.
Post by: jpc647 on February 12, 2011, 06:37:09 PM
Alright. Well I drove the car tonight, I didn't really have a choice. The car is bucking, hard. What I mean by this is when you let off the gas, the car seems to "stumble" as if you were applying the brakes and letting off, over and over again. I get a check engine light, I jumpered the plugs and got an on demand code 34. It did this on friday too.
[/B]34: PFE or EVP circuit above the closed limit of 0.67 volts.[/B]
Now I don't think I have a PFE, but I swapped the EVP, same error. So I know the unit is fine, It's something in the line. Haystack hasn't been back, I'm not sure what he was trying to tell me to check before. I made up an new vacuum line system today that is identical to the one one, I reused the old heads, but all new lines and connectors. So the problem is not the EGR valve or the EVP, or I don't think it could be vacuum.
I can see the TPs and the EVP have the same three colored wires going to them. So if there is a problem with either unit, possible a code for the other would come up. Where the EVP one is on demand, i'm thinking thats it.
I went here : http://fordfuelinjection.com/?p=35 Now the values I get, are they from the EVP wire to the SGN RTN or to the VREF wire?
Post by: jcassity on February 13, 2011, 12:57:18 AM
I think i know what the problem is.  Way back on the first page you specifically stated "check engine" adn for some darn reason I started thinking in the wrong direction.
DO this........
get the pry bar you use to remove your belt and put it in the back of the car.
when you pull in to home after driving , quickly jump out of the car and remove the belt just enough to clear the belt off the smog pump.
tell us if the smog pully isnt feeling tight or grindy feeling.
if so,,your engine is being robbed of power which answers a multitude of up hill power issues.
also,, just fyi
get a can of wd40 and plan on wasting it all.
un hook ever vac line you see going to a solenoid.
spray up in the solinoid and fill er' up.
spray up inside the lines getting plenty in there.
spray inside the vac tree
spray inside the brake booster line
spray inside everything you can think of.
this will lubricate the solinoids and the plastic / rubber orings and plungers ect.
but seriously, if that smog is going bad, and the problem is gettng worse like you said, it will eventually start throwing a belt.
as for the sensors and values,, see my diy link.
as for pulling codes, just listen to softtouch.  dont  pull codes on a cold moter either, it will have you chasing the wrong things.
Post by: jpc647 on February 13, 2011, 12:44:45 PM
Quote from: jcassity;352781
DO this........
also,, just fyi
Alright I drove the car around for a couple of minutes and took the belt off. The smog pump seems to spin freely. I mean It doesn’t spin free like the alternator does, but it’s not sticking or hard to spin either.  I will get out there with some WD 40 now, and start spraying stuff. I do pull codes on a warm motor.
If I’m driving down the street, and I put the car in neutral, the jerking/bucking stops.  Would this eliminate the possibility of the smog pump going bad? If it was binding, wouldn’t it do it all the time?
I also ran another KOER test. After doing the steering wheel jerk and the brake pedal depress, while waiting for the single flash for the "dynamic test" I get a readout for code 34. After that nothing. I did the gas pedal depress, and the idle kept changing for about 10 minutes, I never got any codes so I shut it off. It never used to take that long.
Post by: jcassity on February 13, 2011, 02:11:49 PM
dependnig on the wear, the smog pump may bind up only after the engine is hot.
sounds like its not the smog though.
sounds like something is simply robbing you of power.
wonder if the AC compressor is over charged or is binding up like I described on the smog.
Post by: Aerocoupe on February 13, 2011, 02:52:50 PM
Has anyone suggested pulling the MAF element and cleaning it?  This can be over looked and it will cause all kinds of havoc.  Scratch this if the car is not a mass air car.
Darren
Post by: jpc647 on February 13, 2011, 03:23:47 PM
Quote from: Aerocoupe;352832
Darren
not a mass air car. :(
Post by: Aerocoupe on February 13, 2011, 06:05:27 PM
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes.  Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.  Did you check the MAP sensor vacuum line to make sure it is in good shape and does not have a leak?  Did you ever put a fuel pressure gauge on the schrader valve and see what kind of pressure you are running under a load?
Darren
Post by: jcassity on February 13, 2011, 07:48:33 PM
he did the fuel press test under a load, readings were good from what he could tell.
its in another thread.
Post by: jpc647 on February 13, 2011, 08:19:49 PM
Quote from: Aerocoupe;352850
Darren
Yup. The ac is always off when these tests are done. The test is done in park. I do not generate a code 67. I used to because the pin for that was not grounded. That's a whole different issue, and that has been fixed. I believe it was 36lbs of fuel pressure under load.  I looked at the MAP sensor line, it looks okay. But I will try and find a testing procedure and test that tomorrow.
Jassity is right. It was in another thread. When I first believed this was all fuel pressure related, I started a thread about what fuel pump I should buy. Only to test it with the schrader valve to find out my fuel pressure is good.
Post by: jpc647 on February 14, 2011, 09:12:09 AM
Now this is interesting. I drove the car to work today. I had a couple of problems initially, on the highway, when moving at 45+. However, if I put the car in D, which is essentially 3rd gear, the car seems fine. At a stop light it idles a little rough, but that is only because the vacuum line to the EGR valve is disconnected. I have to find a plug for it at work today.
So this problem does seem to be EGR related, now I just have to determine(with the help of all of you I think) what could be causing the code 34. I'm going to go out and test the EVP lines to check them again tonight with a multimeter, but I had a spare EVP/EGR valve that I already put on and am still getting the on demand code, so I'm thinking it's something before the valves.
When trying to chase down the 63 EGR valve opening not detected code, I swapped the same EGR valve/EVP and didn't get a code.  So I believe I may be looking for an electrical gremlin here, either in the computer, or in the wires going to it.
I just don't know what pins/wires in the computer to check.
Post by: jcassity on February 15, 2011, 12:39:51 AM
Quote from: jpc647;352897
yur killin me man,,,
click on the evtm link below,, its there for you to use.
Post by: softtouch on February 15, 2011, 02:05:51 AM
Are you sure you have vacuum going to the EGR valve at idle? If so this is a problem.
The EEC should only open the EGR when warmed-up and cruising. Not at idle, not while accelerating or not while decelerating.
Put your vacuum gauge on the vac line to the EGR. Run KOER and you should see a puff of vacuum when it tries to test the EGR.
Plugging the EGR vacuum line and preventing the EGR from ever opening will not cause any driveblity problems
EVP sensor wires:
1. BR/LG  sense wire to EEC pin 27
2. O/W  reference voltage 5v from EEC pin 26
3. BK/W signal return (EEC's logic ground) EEC pin 46
So somewhere along the way the KOER code 33 morphed into a code 34?
33 is pretty simple, the valve didn't open when told to.
34 is less clear. Means different things for different engines and years.
If someone with an 87 shop manual can look in the Emissions Diagnosis Manual and see what it means for an 87 5.0 it may help.
The 63 memory code is your TPS voltage too low. Did you try the wiggle test to see if you could create this code by tapping the wires and connectors going to the TPS?
Or by gradually revving up the engine to see if you hit a bad spot in the TPS?
Post by: Chuck W on February 15, 2011, 08:32:21 AM
No.
If it's a real CEL, it could care less about what the oil pressure is.  It's tied to the ECU, it wouldn't even know if there was oil in the engine.  If it's the idiot light "ENGINE" light, like in the older cars w/o full gauges, then it's tied to the oil pressure and coolant temp.
If it was an oil pump issue that was bad enough to cause a drop in power, that's the last thing it would do before making nasty noises and grinding to a halt.
You might want to fill us in on what codes are there, since we can't read minds.
You say it does it once a month.  Ever noticed what the fuel level is?  Perhaps the pump or intank hoses are going bad.  Perhaps there's some  floating around in the bottom of the tank that get's pushed onto the fuel pick-up.  Who knows.
Could be anything at this point.
Post by: jpc647 on February 15, 2011, 12:58:57 PM
Quote from: Chuck W;352990
No.
It is the real check engine light. The same one I pull codes from from jumping the wires on the drivers side strut tower.
You might want to fill us in on what codes are there, since we can't read minds. .
I did. Codes have been pulled multiple times. Both KOEO and KOER were done.  I had a 63 and 33 for a long time, but now have a 63 and 34.
In another thread(sorry) the fuel pump was checked. I attached a Schrader valve to the outlet on the fuel rail and drove the car around for a while. I drove it easy, and I drove it hard, harder than I normally do, and the fuel pressure was good. Lately though, it has happened more often, its almost an everyday occurrence.  Again, If I floor the accelerator pedal, the car seems okay, and very light throttle, not enough to accelerate are okay, but anywhere in between the car hesitates, (I think I hear a ping), and the check engine light comes on.
Quote from: softtouch;352968
No, there is no vacuum to the EGR valve when car is idling, I just though that because the end of the hose is open, it might cause a leak. That’s all. My mistake.
Alright, well judging on the code 34, being the active code, I’m guessing it’s trying to open the valve at wrong times. Is this correct?—I’m guessing here to try and troubleshoot.
I have a vacuum gauge buried in the garage; I will dig it out tonight and try that. Have you plugged the EGR valve personally? I should leave the EVP plugged in though, correct? Did you notice a drop in fuel economy?
Yes, somewhere along the way, the code 33 became a code 34. I’m positive I checked the codes right. Code 33 was always there, but I think there was a hole in the vacuum line I never noticed. Could explain the code.
Where did you get this information?
.[/QUOTE]
I haven’t tried the wiggle test. I think one problem, was I confused the code 33 and the 63. What I mean by that is I thought code 33 was the TPS one and code 63 the EGR valve one. This may have been part of the problem in communicating with haystack. I got a new TPS, I’ll swap it tonight, and do my best to reset the base idle. That should take care of code 63.
Quote from: jcassity;352957
I'm going to admit it, I can't read the schematics. Embarrassing as that is to admit, it's true.
I'm sorry if sometimes I am unclear of what I'm asking or saying. I don't know very much about cars, and am just trying to fix this one.
Post by: softtouch on February 15, 2011, 05:51:34 PM
There is another self test tool you may want to try. It is called "output state check". It allows you to activate and deactivate all the solenoids the EEC controls.
I am using 84 shop manual info which is before they had a check engine light. It says it also toggles the self test STO circuit. In your case it should also toggle the check engine light on and off.
Run KOEO. Wait until it has finished outputting codes. Now you push the throttle to WOT to activate the solenoids, push it again to deactivate etc.
Your EGR Vacuum Regulator has a red wire which is hot with the key on and a green wire that the EEC grounds to activate the solenoid.
See if you can back probe the green wire without disconnecting it from the regulator. It should show 12v when deactivated and ground when activated.
The solenoid in the regulator operates two valves. One to apply vacuum to the EGR vacuum line when the solenoid is activated, and one to let air into the EGR vacuum line when the solenoid is deactivated.
So it is important that the vacuum lines at the regulator not be reversed.
Get a spare piece of vacuum line from your junk collection to test with.
Take both vac lines off the regulator.
With the solenoid deactivated:
You should not be able to suck air through the regulator from the vacuum tree side.
You should be able to suck air through the EGR side. Put your finger over the Vac tree side to verify the air IS NOT coming from over there.
With the solenoid activated:
Suck air through the EGR side and put your finger over the vac tree side to verify the air IS coming from that side.
Hope this is not too confusing.
Oh yeah, I ran my 84 3.8 with the EGR vac line disconnected and plugged with no ill effect. Don't know about gas milage, not something I worry about.
Post by: jcassity on February 15, 2011, 09:15:27 PM
Quote from: jpc647;353005
It
well,, ,,
I didnt know that.
Dont feel bad, it not easy until you have someone show you how to read them.
sorry,
Post by: Haystack on February 15, 2011, 11:06:59 PM
Hey guy, now we are getting somewhere. Instead of checking resistance on the ground, let's do this. Take your volt meter, put it in the resistance setting. When your two leads are touching each other, it should read 1.0 or just one. Your resistance will go down the longer the wire travels, or disappear completely if the wire is bad/cut. Extend one of your leads so that it will reach the plug to the sensor, and check your resistance when you have the wire long enough to reach, by touching the regular length lead to the wired extension. Once that reading is read, try to use that as a baseline. This is now 100% accurate, but if you have a bad wire, you will know.
Now, unplug the computer and test the pins to the connector wire and check you resistance. This will tell you if you have any broken wires. There is also a chance that the wires could be crossed, or touching each other. This is why you check voltages on sensors.
So, on your car, find the pin that connects to your egr. Check resistance between those wires and there corresponding pin. If you have a bad wire, you will at least know what you are looking for. Then we can explain the evmt to you and help you from there.
Do not be afraid to ask. We would like to help you. I will not rake you over the coals as long as you are willing to learn.
Post by: Haystack on February 15, 2011, 11:17:11 PM
Also, to check the tps, test the voltage while it is hooked up. Peirce the wire with a small finishing nail and keep your lead one thenail or pin or what ever you Peirce the wire with. Slowly run the throttle up by hand ans it should gradually increase in voltage. You can read other threads, probably one of your own I already link the small block ford tech article to you in. If your voltage checks out, do the base idle reset. The only real problem with this, is you should not have any vacuum leaks. Id you have any, it will not stick or it will rev up and down at idle.
Sorry if I have not been alot of help, and please excuse my spelling. I have only been able to get online here with my cell and it has a bunch of auto spelling features, and how hard it is to use the forum with 10 buttons and a 3 inch screen.
Post by: jpc647 on February 16, 2011, 04:17:52 PM
Quote from: Haystack;353064
Thank you. I understand. I was worried you were mad at me for well being dumb. It's not that I disregard what you say, I just don't understand certain things, and when I ask questions, I seem to make everything more confusing. Part of the problem is a do a lot of the responses at work, and I have to be quick. I got another TPS now, and hopefully tonight I can do the idle reset. The only potential vacuum leak I think I fixed. We'll see.
Post by: flylear45 on February 16, 2011, 08:57:54 PM
Knowledge is power. Don't be intimidated by the schematics because they tell all. I spend hours looking at them!
Post by: Haystack on February 16, 2011, 09:56:13 PM
The internet is bad at getting the point crossed. I was not upset, but it is difficult to understand cirspoogestances through black and white text. Best way to learn is to jump right in. Nothing is better then hands on, which some direction so you are not wasting money needlessly.
Post by: jpc647 on February 18, 2011, 12:23:47 PM
Quote from: Haystack;353144
I understand. I have a hard time following some of the instructions myself.
But on a good note, I swapped out the TPS and am no longer getting a check engine light! Now all is not well yet. I was not able to reset the base idle because I don't have a tachometer of any kind, therefore when idling at a stop light, etc, the car is a little shakey and sometimes when letting off the gas today I can feel the engine sort of idle too low. If that makes sense. It stumbles, not bad, but it is noticeable. My father thinks he has a timing light/rpm light at his work, and he is going to bring it home.
So we are on the right track. I will clear codes tonight, and go from there... :)
Post by: jcassity on February 19, 2011, 02:51:13 AM
you really need to pick up one of those cheapy buttstuffog meters they sell anywhere, tiny little meters with a needle.
if you had one of those, you would have found the tps was bad long ago.  You would have literally seen the intermittant open ckt.
Post by: jpc647 on February 19, 2011, 09:42:51 PM
Quote from: jcassity;353304
You are right. The digital ones, although typically better, don't allow for a person to see quickly at a glance that there is an open circuit, or something else.
Now to figure out the EGR portion of this.
Post by: TurboCoupe50 on February 19, 2011, 10:26:56 PM
Quote from: jpc647;353237
The IAC is "supposed" to regulate idle speed... As long as base idle is a little less than the target speed the ECU & IAC are striving for it should be fine... Neither should cause a rough or low idle...
Every code 34 I've seen was caused by the sensor on the EGR actuator...
Post by: Haystack on February 20, 2011, 12:39:33 AM
when you reset the base idle, you clear codes, unplug the iac and start it up. If it won,t stay running, throttle up you idle with the throttle stop screw until it will stau running. You can throttle your idle up or down, then when you get it to a low rpm's without it stalling, plug in the iac. The computer will set the idle where it needs to be. Go out and drive the car for 10 to 20 minutes under "normal" conditions. Making it sit to learn the idle is a myth.
Post by: jpc647 on February 20, 2011, 10:39:58 AM
Quote from: Haystack;353396
Sounds easy enough. I thought I had to set it with the RPM's at an exact-ish value. I can do this today. Awesome! Does the car have to be warm, cold? Probably warm seeing I have to clear codes, lol.
Post by: Haystack on February 20, 2011, 11:57:56 PM
I would do it warm. Basically, you can modify where the computer will set the idle, but if everything is working correctly and the idle screw is not adjusted too far, it will automatically set it to, or close enough it will not matter.
Post by: jpc647 on February 28, 2011, 06:45:26 PM
Quote from: Haystack;353506
Well I reset the base idle according to the procedure above. I turned the idle screw up until the car didn't stall. I drove the car around and at first noticed a stumble in the engine when coming to a stop. Gradually it cleared up, for the most part as I was driving. But when coming to a stop, the engine will slightly stumble on and off, every few seconds. Not enough to sound like it'll stall,but it's a little noticeable. I don't want to turn the idle screw up anymore, as in park the car seems to idle fairly high, well compared to what I was used to. Not enough to where the car jerks into gear or anything, but I would guess it's probably at like 1100 rpms or so. It's not as high as the car would idle when it's cold and you first start it, but more than I would expect from an idle.
Maybe now I'm looking for a vacuum leak? I checked the brake booster, I unplugged the line and put my thumb over the suction line, it didn't go away; so I think the booster is okay. I did spray penetrating oil into vacuum lines last week as jcassity suggested. I did notice the EGR vacuum regular make a "humming, or rattling" noise when I was setting the idle. When I pushed the throttle up a little to turn the screw, I could hear it. It wasn't loud loud,  but I could hear it. There was vacuum going to the Top port of the unit. Fordfuelinjection.com says this is not normal. Now I replaced all of the vacuum lines in the EGR system with softer ones, as I could not find the hard plastic lines with connectors, etc. So I know there are no vacuum leaks, and I matched them up exactly to what was there. So how do I figure out why there is vacuum there when it's not supposed to be? I know there is a code 34, the EVP above closed limits. It's an ondemand code. I changed the EVP and it didn't go away, so something is wrong before there. I wiggled the wires in the plug too, to no avail. It's looks like the TPS and the EVP are spliced into the same section of harness so I unplugged the TPS, and cleared codes. The EVP one stayed. So now I need suggestions on how to fix the EVP code.
Now I did ground the pin for the nuetral safety switch. Would this has inadvertently grounded the whole computer harness? The code didn't show up until after I changed the tps though. And it's been a few months since I grounded the nss wire. I think it would have come up before.
Unplugging the EVP does yield a code 21, EVP below minimum voltage, which makes sense.
 I know I can try some carb cleaner and spray around, but it's raining now, and I thought I would post up, and get some ideas for when it's a little drier out.
Post by: jpc647 on February 28, 2011, 08:59:34 PM
I found this thread. This kid had a code 34, and it turned out to be his engine computer.
http://mustangforums.com/forum/5-0l-general-discussion/512388-got-me-an-obd1-scanner-this-mornin-5.html
Post by: Aerocoupe on February 28, 2011, 09:33:50 PM
Try another EEC and then do the base idle reset.  I have followed this method to reset the base idle on my coupe after changing the heads, changing the cam, changing the injectors, etc.  Joel is very knowledgeable and this procedure has worked on hundreds of EEC-IV cars.
http://www.my5oh.com/forum/viewtopic.php?t=1078
Darren
Post by: jpc647 on March 01, 2011, 01:42:29 PM
Alright. I'll do that, I just have to find another EEC.  I'm assuming one from an 86-88 tbird 5.0 will work?
Post by: softtouch on March 01, 2011, 05:26:57 PM
Did you try the trouble shooting proceedure that I suggested in post #70 ?
Post by: jpc647 on March 08, 2011, 11:12:04 AM
Quote from: softtouch;354328
Question regarding that.I can only test it while running the KOEO test right? I'll run it, wait till its done, floor the accelerator pedal, then seeing the actuators are active, I can test by sucking air, the floor it again to check it without it activated. Tha'ts what you were trying to describe?
Now I contacted Joel over at SBFTech.com in regards to this too. The EVP wire runs through the white 10 pin connector. I have a correct VREF of 5.0 volts, and as SIG-RTN of 3.8/3.9. The SIG-RTN should be less than .67v. Therefore, I have a short somewhere.  I unplugged the 10 pin connector and got 0v for SIG-RTN and VREF which according to Joel means the problem is after the 10 pin connector, which is sorta good news.
I cut the loom back last night to find one orange wire running from the harness spliced into two orange wires, one going to the TPS one going to the EVP. At first I thought this was my problem, but it appears to be how it's supposed to be. Now for the heck of it, I grounded this wire, and tried to run EOEO test, and the check engine light just stayed on and I could hear some actuator near the trunk clicking away. So I'm probably not supposed to ground that.  But now I'm wondering if this orange wire is tied to the orange wire that we've had threads about, the one that some people ground, others dont, etc. I may try to temporarily ground it and see what happens. I'll attempt to look at the EVTM tonight and see if I can make heads or tails of it.
Post by: softtouch on March 08, 2011, 07:52:12 PM
Quote from: jpc647;354852
Yes. This tests whether the EEC can open and close the valve in the regulator.
Having 3.8/3.9 volts on the Sig-Rtn is definitely a problem.
The 5v VREF wire is [COLOR="darkorange"]orange with white stripe[/COLOR] . Do not ground this, there is a good chance you will ZAP the EEC.
The SIG-RTN wire is Black with White stripe.
Post by: Haystack on March 08, 2011, 08:47:14 PM
Pulll apart your computer and see if anything is fried, bypass vacuum lines to everything but the map sensor and see if it gets better or not.
Post by: softtouch on March 09, 2011, 01:32:49 AM
The Sig-Rtn wire goes to the self test connector without going through the 10 pin connector. Check what the voltage is there.
(http://mysite.verizon.net/vzetk5cc/sitebuildercontent/sitebuilderpictures/87EECPage60.JPG)
Post by: jpc647 on March 09, 2011, 11:02:32 AM
Just so anyone following can be aware of what I did, to eliminate confusion.  The following is what Joel over at SBFTech told me. What I did, in regards to testing from the 10 pin connector is:
EVP wire is also routed through the 10-pin connectors (salt & pepper)......
(http://i478.photobucket.com/albums/rr148/jpc647/harness02.gif)
You can disconnect the white one and check the EVP voltage at the EEC harness IGN ON. If the voltage at the EVP terminal is 0 vdc.... the short is somewhere past the 10-pin connector..... if not, need to trace back the 10-pin connector towards the EEC.
(http://i478.photobucket.com/albums/rr148/jpc647/mustangMainHarness.gif)
Post by: jpc647 on March 09, 2011, 11:03:37 AM
Quote from: Haystack;354892
I will do that. Last time I was in there(2 weeks ago) nothing was, but I will check again.
softtouch- I will check the SigRtn at the self test connector too.
Post by: softtouch on March 09, 2011, 03:58:45 PM
Quote from: jpc647;354926
Check with the 10 pin connector both plugged and unplugged.
Post by: softtouch on March 28, 2011, 05:23:19 PM
Did you ever check the signal return voltage at the test connector?
If you have the 3.8 volts there check 88cougarGT's thread in the Electrical Tech forum.
He found an open land pattern in the EEC circuit board and shows how to fix it.
The open land is the sensor ground (signal return).
Post by: 88CougarGT on March 28, 2011, 06:49:12 PM
This is what I saw when I fried the SIG-RTN line during my trans swap.  SIG-RTN was floating.  I burned it out because I had used a 5spd computer in an automatic harness.
You can read about my misery here (http://"http://www.foxtbirdcougarforums.com/showthread.php?31025-Fix-for-poor-idle-rich-mixture-and-poor-performance-after-HO-T-5-mass-air-swap").
I had temporally grounded the line going to the ground pin on the TPS using a tombstone crimp and a spare piece of wire.  It ran better, but still got  fuel mileage and hanging idle issues.  It only got better when I repaired the trace inside the ECM.  You could theoretically do this on a non-swap car if you accidentally sent +12v directly to SIG-RTN without a load in-between.  I thought it was only a problem with the EEC-IV mass air computers.  I would run a continuity check between the ground on say the TPS and Pin 46 on the computer.
