General => Lounge => Topic started by: 1BDBIRD on December 07, 2010, 02:56:40 PM
Title: MPG!!! My 1987 Bird 3.8 gets 22mpg. Is this the Norm???
Post by: 1BDBIRD on December 07, 2010, 02:56:40 PM
I went 365miles on 16gallons gas in my ole 1987 3.8bird with 177,700miles on the odometer!!!  Is this pretty decent for a car this old. My 06 gt gets about 23mpg also if i keep my foot out of it but its 20years newer!!!
What do your cars get for mpg??? i run 89octane 10%ethanol.
Post by: Scott D on December 07, 2010, 03:07:49 PM
24 in the 'underbird
12 in the C-1500
35 in the Jetta
Post by: Thunder Bantam on December 07, 2010, 04:00:31 PM
i get 23 with my 5.0 bird
Post by: 1BDBIRD on December 07, 2010, 04:25:57 PM
So prob could be better then HUH?? I havent done a tune up or anything since i got it in October. Pretty much fixed the burned up alt wires,new alt,battery and changed the heatercore!!!
Post by: sarjxxx on December 07, 2010, 05:00:31 PM
wow those are good numbers....
when my 88 was running it was getting about 20 TOPS and about 18 average...
and my 96 gets about 18-20 most of the time too....
and their both 3.8's:dunno:
....course I do have a foot made of a certain poisonous heavy metal.....
Post by: Bruce M on December 07, 2010, 05:14:17 PM
When I first got my cougar it averaged 18-22 depending on driving. Now with 165K I average 14-16.5. That's after the 3.45 gear change, dual exhaust, and HO upper with HO TB. I think there is something wrong with it but it still runs good. When I sawped in the mustang AOD with shift kit is when I noticed the decrease in MPG. It does'nt slip at all, it works great. It's not rich eather. I thought that everything that I've done would increase MPG but the gear change.
Post by: mcb82gt on December 07, 2010, 06:09:53 PM
I get around 20-22 in my 88 5.0 Cougar.  More highway I do better than that.
Post by: tbirdsps on December 07, 2010, 06:11:02 PM
On my 85 Cougar I used to have the 3.8 generally gave me 28 highway and 19 in town  3.08:1 rear end.  My 92 Tbird with the 3.8 is 18 in town and 26 highway. 3.27:1 rear end.
Post by: CoogarXR on December 07, 2010, 06:17:37 PM
83 5.0 auto gets about 18mpg mixed town and highway driving (116,000miles)
85 2.3 turbo auto gets about 20-22mpg mixed driving (42,000 miles)
Post by: 50tbrd88 on December 07, 2010, 06:49:12 PM
When my car was dead stock with 5.0 SO and 2.73's it would knock down mid-20's regularly.
Post by: Thunder Bantam on December 07, 2010, 06:50:34 PM
Quote from: Bruce M;344870
my '88 has the HO 5.0 engine BBK 65 mm TB, headers with true dual exhaust, timing has been advanced and my AOD has a shift kit and i have 3.45 gears and i still get 23 mpg with it so i don't see why you can't get the same, what kind of tires are you running ? im running spoogeho ecsta's and i've always seen a lil increase in mpg with these tires.
Post by: mcb82gt on December 07, 2010, 06:57:48 PM
Quote from: 50tbrd88;344886
What does it do for mileage now?  If...... you can keep your foot out of it??
Mine is stock now and will be fairly modified later.:evilgrin:
Post by: mcb82gt on December 07, 2010, 06:58:51 PM
Quote from: Thunder Bantam;344888
Do they have flubber in them or something??
Post by: Bruce M on December 07, 2010, 07:16:55 PM
I'm running 215/65-15 BFG touring T/A at 32psi. They measure 26" tall. I'm going to pull the motor and replace the gaskets, seals, timing chain, oil pump, GT40 heads, and a HO cam. When I install the motor I'm going to replace all the sensors and cracked vaccum hoses. Maybe that will help. It's weird because it runs good. I havent checked tps voltage and the EGR is blocked off but if eather of those were the problem I would think it wouldnt run as good.
Post by: Thunder Bantam on December 07, 2010, 07:26:10 PM
Quote from: mcb82gt;344891
nope just nitrogen lol
Post by: RunninWild on December 07, 2010, 07:48:30 PM
My Explorer gets 16-17 (4.0 OHV), and My Tbird gets about 19ish. However, I once managed to get 29 on a 100-ish mile trip.
Post by: Bruce M on December 07, 2010, 08:05:08 PM
My explorer was about the same. The best I ever seen from the cougar on a road trip was 28.
Post by: sarjxxx on December 07, 2010, 08:06:18 PM
Quote from: RunninWild;344904
However, I once managed to miscalculate on a 100-ish mile trip.
oh yeah? thats cool;)
Post by: 20thanniver-ls on December 07, 2010, 08:39:02 PM
My old Explorer got around 11 MPG's....... That thing had issues.
Post by: daminc on December 07, 2010, 09:04:37 PM
My E-250 goes through about 40 gallons (1 tank) on a 6 hr trip....... Just thought I would toss that in there
And that's with it empty... It's about half with the 2000 lbs of tools in it
Post by: crystal on December 07, 2010, 09:25:45 PM
I eat up about 2 tanks of gas a week but I also drive like 700 miles/week. Not sure on the mog but it's not good, running rich and trans is slipping. All I know is the second that aod goes, it's getting a 5 speed!
Post by: 50tbrd88 on December 08, 2010, 11:28:59 AM
Quote from: mcb82gt;344890
I've never checked it to be honest.  I will find out this summer when I take it on Hot Rod Power tour....should be a 800+ mile trip.
Post by: blain_gatterdam on December 08, 2010, 11:56:17 AM
I averaged 32 once in my 5.0 going to pittsburgh a few times in a row. Its a highway car runs maybe 8-900rpm at 65mph. My uncle only drove it between the wal mart stores he operated which was hundres of miles a day, by the time I got it, it has like 263k miles, all highway.
'twas the days before my cell phone camera, noone ever beleives me.
Granted around town, its like 16-19
Either way is better than my 4.0 explorer, it maxed out 21mpg going to cincinatti a couple times in a row...
Post by: 87cougar on December 08, 2010, 01:04:37 PM
I got 35 mpg in my 87 cougar with a 3.8L bone stock.  That was driving like a granny and 55mph(1500 RPMs).  That was just to prove I could get good mileage.  But most of the time I'm getting any were from 30-23mpg highway.  But my car only has 35,000 miles on it now.
Post by: jpc647 on March 10, 2011, 02:34:17 PM
Quote from: 87cougar;344965
My 3.8 could get 33-34 on the highway. Driving it sparingly. The 5.0, well it gets 26-28 on the highway driving it carefully.
Post by: mcb82gt on March 11, 2011, 08:45:25 AM
Quote from: blain_gatterdam;344960
Its a highway car runs maybe 8-900rpm at 65mph. ...
So...... you idle down the hwy??  LOL
I always heard idleing was wasting fuel??
Post by: Haystack on March 12, 2011, 01:20:42 AM
Driving real careful, I got 35mpg a couple of times according to the computer. My overall best averages were when I was sticking to 60-65mph and way loaded down. Best calculated from the pumps was about 33mpg on a 100 mile round trip, about 90% freeway.
Generally, 22-28mpg freeway, and 14-19 city. I did alot of driving city using my thunderbird for pizza delivery for about 8 months.
This crown vic  me off. It has lower gears, and weighs slightly more then the bird, but with the same engine and tranny combo, I would still think it would get close. Itshiznitting about 14-16 city and best so far of about 22mpg freeway. I basically average about 18mpg no matter how I drive it. There is something not running right with it, but it passed emisions with flying colors. Just haven't gotten around to it.
