Technical => Electrical Tech => Topic started by: Hutch on October 10, 2010, 01:29:57 AM
Title: Help Can't Figure Out this Electrical Issue
Post by: Hutch on October 10, 2010, 01:29:57 AM
The Charging System warning light (AMP Light on Dash) had been coming on intermittently on my '83 5.0L Bird for a couple of months. Last weekend it was on, then later on wouldn't start. A jump got it started and so I replaced my alternator and charged my battery. I've started it a couple of times now and the "AMP" Light is still on. So: do I need to reset something after having replaced the Alternator or does anybody have any ideas on what I should check next. If the latter applies how do I go about checking said device.
Post by: turbo_88_XR7 on October 10, 2010, 02:29:05 AM
not sure what these cars had for an alt, so i'll give my idea(s) for both internal and external voltage regulators..
if it's internal, it's probably the py pigtail connector.. they're known for going bad
if it's external, it may be the regulator itself or the charging wire going from the alt to the solenoid.. i've had both problems with my bronco.. it's also possible(but not likely) that the regulator got stuck 'closed', as if it were sensing a fully charged battery, thus stopping the alternator from charging
Post by: Hutch on October 14, 2010, 09:53:01 PM
I replaced the regulator and so far so good so hopefully its fixed
