Technical => Engine Tech => Topic started by: hypostang on August 23, 2010, 08:50:51 PM
Title: HO conversion clarification questions
Post by: hypostang on August 23, 2010, 08:50:51 PM
OK, I have already upgraded my fuel pump and exhaust system and upper intake .
 I have a set  19LB injectors , a speed density HO ECM , a factory HO cam and a new timing chain .
I also have a timing gasket set  and intake manifold gasket set .
 I have 3 questions
  1. Do I "NEED" anything else?
 (I know E7 heads are in the list but I'm not swapping heads, if I were going to go through that much effort I would just swap the entire engine )
2. Has anyone done the conversion and kept the E6 heads?
 3. If yes to number 2 did you have decent results ?
 Back in 86 I had a brand new Mustang 5.0 LX coupe  and I seem to remember it having  enough pep to keep me happy for a while .
I'm assuming  what I am doing now will give me similar grins :D
Post by: vinnietbird on August 23, 2010, 09:08:33 PM
The E-6 heads are by no means "great", but, I did the conversion as you are years ago and even with those heads (which I later swapped to porter E-7's) the car was a blast to drive and you could feel the power difference in the seat of the pants. Compared to the SO 5.0, it will make you happy, and you'll enjoy it until you make more mods.
Post by: vinnietbird on August 23, 2010, 09:10:54 PM
Oh, as far as parts, you have what you need ( You need all of your gaskets, etc). It is a good time to swap on new water pump as well.
Post by: hypostang on August 23, 2010, 09:34:29 PM
Thanks Vinnie . I thought I had everything ,just wanted to make sure
Good idea on the water pump :D
 It will be happening in  the next week .
Post by: vinnietbird on August 23, 2010, 10:22:27 PM
Pics and updates.
Post by: 88turbo on August 23, 2010, 10:55:44 PM
the HO I put in my 79 cougar is awesome, makes the car move like never before.  I can only imagine what it would feel like in the lighter fox thunderbird.
Post by: Beau on August 23, 2010, 11:16:44 PM
What about exhaust? ;)
'Course, with E6 heads, exhaust really won't matter as much.
Post by: hypostang on August 23, 2010, 11:18:32 PM
I already swapped to factory  mustang shortys and a cat-less H pipe
Post by: Beau on August 23, 2010, 11:30:35 PM
Heck, at this point, should you DO decide to swap heads, I wouldn't even piddle with E7's....GT40's or some such...:rollin:
Post by: hypostang on August 23, 2010, 11:35:57 PM
I always keep my eyes open ;)
Post by: Watchdevil on August 24, 2010, 12:23:38 AM
All this engine talk is making me drool! I don't by any means need a street racer but I want my car to eventually be a good running street cruiser...
Post by: hypostang on August 24, 2010, 10:10:42 PM
Ok another question
I opened the box for my timing set and it is not a  double roller chain .
 It is just a standard run of the mill timing set ,
Do i need to go back to the parts store ?
Post by: Haystack on August 24, 2010, 10:15:29 PM
No, but I would. I got a double roller for my s.o.
Post by: hypostang on August 24, 2010, 10:20:28 PM
Quote from: Haystack;333326
Thanks , I will .  What was stock on the SO?
Post by: vinnietbird on August 24, 2010, 10:35:53 PM
What you have was stock on the SO engines.The H.O engines had a double roller.That's all I will use. Costs a few extra dollars,but worth it.
Post by: hypostang on August 24, 2010, 10:44:36 PM
Quote from: vinnietbird;333329
I just checked Oreilly's site it will be like 8 bucks more for the double roller ...I will be doing an exchange ;)
Post by: vinnietbird on August 24, 2010, 11:03:34 PM
Now...wasn't that easy ?
Post by: hypostang on August 24, 2010, 11:06:51 PM
LOL.. quick and painless , just how I like it
Post by: The Shredder on August 24, 2010, 11:40:50 PM
Are the SO 5.0's roller cams?  If not, then the HO cam won't work too well in your engine.  I just haven't messed much with the SO's.
If interested, I have two sets of E7's.  One is in the process of being ported.  The other pair are stock.  I'll sell them really cheap!
Good luck!
Post by: hypostang on August 24, 2010, 11:46:11 PM
86 and up SO are roller cammed so I'm good there :D
 and thanks for the offer on the heads but I'm not switching  on this engine , not to mention shipping would be brutal
Title: Im Sorry did I miss something
Post by: rocketman on August 28, 2010, 12:33:49 PM
Don't you need a Computer for the swap from non HO to HO.
I have an 88 XR7 Cougar and I am planning to do the swap, I already had new pistons (dished) installed in my motor during the prior rebuild.
I am purchasing an entire Mark VII "89" with H.O. Engine and from what I have been reading I can pull the Cam, heads, intake, and Computer from this Mark VII and put them into my 88 Cougar NON HO engine, change the firing order, Install Headers, and drive away.
Is this true? And if so what headers do I use, do the HO Heads have different Exhaust Ports than the Non HO Heads, or can I just throw in the headers that are recommended for my 88 Cougar?
Any help would be appreciated
Post by: vinnietbird on August 28, 2010, 12:48:00 PM
All of that is correct.Plug and play.Yes,you also need the Speed Density H.O computer.It too is plug and play. You can use the H.O factory Mustang/Mark VII headers,but,you'll have to alter the rest of the exhaust to duals (well,you need to anyway),and the stock pipes will not bolt right up to the headers,also,the O2 sensors don't screw into the headers like they do in the stock Cougar exhaust manifolds.Get the Mark VII H-pipe as well.
Post by: Haystack on August 28, 2010, 05:00:52 PM
Might be better off swapping the motor, and keeping your rebuilt one for down the road if you plan more mods/power.
Post by: Beau on August 28, 2010, 05:32:57 PM
Rocketman, you've got it pretty well taken care of, but as Vinnie mentioned, grab an H pipe from either the Mark 7, or from any '87-'93 V8 stang. If your standard 5.0 was rebuilt recently, may as well swap the HO parts onto it, unless you KNOW the jy block is fit for reuse.
The stock stang/mark 7 headers will work just fine for you...I have those on mine now, but am upgrading to some equal length shorties soon.
Got pics of your car? ;)
Post by: hypostang on August 28, 2010, 05:58:54 PM
Well I'm late getting here , looks like they all answered your questions.
Remember that you need an HO fuel pump too.
If you have a complete Mark VII you should have everything you need
Post by: Beau on August 28, 2010, 07:00:10 PM
Quote from: hypostang;333934
Absolutely, good lookin' out Wolverine..I mean hypostang :D:rollin:
I had the stock SO5.0 in mine, then it failed, so I swapped in a Walbro 255 pounder from a nice guy on The Corral, and it runs stronger and better, idles better and doesn't seem to have a "falling off" at higher RPM.
Post by: vinnietbird on August 28, 2010, 08:13:52 PM
Yes,a new fuel pump is in order,but,your stocker will work until you can get a replacement.
Post by: jandmmustangs on August 30, 2010, 08:37:22 AM
Daryl, I have a set of E7's lying around.  Let me see what kinda rates I can get on shipping.  I can usually get good prices through work.  If the cost is decent let me know if ya want em.  I dont want anything for em, just want em outta my way.
Justin
Post by: hypostang on August 30, 2010, 10:45:45 PM
Well, I "MIGHT"have an HO conversion engine :hick:
I started on it last night , worked from about 9 till midnight , then again tonight from around 8 to 10  Got it all back together .
I put my battery in and it was stone dead :mad:
 Its on the charger right now
 It did crank over about three times real slow and farted through the intake, and then the exhaust .
 wen the battery gets some juice I'll go spin it over with my remote stater and a hand on the dizzy
.. Oh btw more good news I took pics during the whole process and none of them saved to my SD card:punchballs:
Post by: vinnietbird on August 30, 2010, 11:15:58 PM
An early pre-start congrats to you.You'll love it. I have always loved the H.O in a T-Bird,and watching the Stang guys get really confused when you lay down a couple of real pretty black stripes.Stangs are the car of choice around here.
Post by: hypostang on August 30, 2010, 11:21:31 PM
Thanks Vinnie , I'll let ya know how it runs when I get it all set .
I just hope I didn't screw anything up . This is actually my first venture into  a roller motor, but it all seemed pretty straight forward  .
Post by: vinnietbird on August 30, 2010, 11:32:53 PM
It is straight forward.I remember my first one.Tom (turbocoupe50) was my tech center.At that time,I couldn't have done it without him.I was NEW at all of it.A lot has changed since then.He answered questions that probably seemed stupid,but at the time,I was basically starting from scratch. This forum has been more than I could ever ask and I doubt any other forum would be as happy to answer those "silly" questions about everything. Now,when it comes to big mods,Kitz is my main source of peer pressure.Without him,I wouldn't have installed Mass Air,the E303 in the other engine,and more.Basically a drill Sgt. over the net.LOL. Daminc for primary parts support through "ONYFTA" (Oklahoma New York Free Trade Agreement), and others that I have dealt with over the years,projects,troubles,and progress.Sorry for the lengthy pledge of thanks I had to pass out,but it's because of the people here that the Sport is what it is now. Always gotta remember what it took and those who helped to get to where you are.
Post by: hypostang on August 30, 2010, 11:44:41 PM
I have been wrenching for as long as I can remember , but I only got my first computer in 2005.
 I gotta say this forum is right up  there with my favorites .
 I was on another forum late last night and I just shake my head at the level of arrogance and condescension from some people .
 On that particular forum if someone asks a  "stupid " question the name calling and insults are unbelievable, and apparently nobody on any other forum knows anything about building engines :hick:
Post by: hypostang on August 31, 2010, 01:39:12 AM
Whoo hoo !!
It runs well.
I have to re-stab the dizzy, I appear to be a tooth off, cant get my 10 degrees without hitting the thermostat housing .
More updates tomorrow :D
Post by: hypostang on August 31, 2010, 12:13:29 PM
Got it timed, warmed up,  no CEL ,,,, no license so I cant test drive yet ..
 It sounds healthier for sure :D
Post by: vinnietbird on August 31, 2010, 12:21:12 PM
Nice work.Now while you're waiting on the license,clean everything up real nice.
Post by: hypostang on August 31, 2010, 12:22:04 PM
Quote from: vinnietbird;334243
Will do boss ;)
Post by: vinnietbird on August 31, 2010, 12:27:58 PM
Carry on.
Post by: jandmmustangs on August 31, 2010, 01:49:28 PM
Rock on Daryl, Rock on:roxor:
Post by: hypostang on August 31, 2010, 03:45:13 PM
Now I could "accurately" list it on Craigslist  lol :hick:
1988 Thunderbird LX , Black,  ....{"5.0 HO"}.....  engine :burnout:
Post by: hypostang on August 31, 2010, 03:46:29 PM
Quote from: jandmmustangs;334254
Thanks Justin , I couldn't have done it without the good deal you gave me on the  parts :D
Post by: thunderjet302 on September 01, 2010, 12:30:47 AM
Quote from: hypostang;334228
Whoo hoo !!
It runs well.
Just make sure the dizzy is right on because the EEC uses the little vanes on the distributor to time injector firing.;)
